[swak4Foam] Contrib/swak4Foam
Like Tree3Likes
Old   June 15, 2012, 11:51
Default Contrib/swak4Foam
Julien
Djub is on a distinguished road
sorry for that very low skilled question, but I don't succeed on myself...
How to install and work with the library swak4Foam ?
Hot link: http://openfoamwiki.net/index.php/Contrib/swak4Foam
I just don't what to do. I tried on my own but nothing really good...
Can anybody "give me his hand" with a step-by-step help ?
Djub is offline   Reply With Quote
Old   June 15, 2012, 14:39
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by Djub View Post
Could you please be more specific where you're having the problems? Download it as described in http://openfoamwiki.net/index.php/Co...am#Downloading Then go to the README-file as indicated there (Basically all you've got to do is say ./Allwmake in the right directory)
gschaider is offline   Reply With Quote
Old   June 18, 2012, 04:09
Julien
After executing
svn checkout https://openfoam-extend.svn.sourceforge.net/svnroot/openfoam-extend/trunk/Breeder_2.0/libraries/swak4Foam/ ,
I typed ./Allwmake
The first lines were:
No 'swakConfiguration'. Python etc won't work
Checking swak4Foam-version and generating file
Bison is version 2.4.1
OpenFOAM-version: Major 2 Minor 0 Patch 1
The last lines were:
/opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::writeStats(Foam::Ostream&) const'
/opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::clearOut()'
collect2: ld returned 1 exit status
make[1]: *** [/home/meteodyn/OpenFOAM/meteodyn-2.0.1/platforms/linux64GccDPOpt/bin/replayTransientBC] Error 1
make[1]: Leaving directory `/opt/openfoam201/Telechargements/swak4Foam/swak4Foam/Utilities/replayTransientBC'
make: *** [replayTransientBC] Error 2
make: Target `application' not remade because of errors.
Old   June 18, 2012, 05:32
Assistant Moderator
Bernhard Gschaider
After executing
I typed ./Allwmake
Let's accentuate the positive : the stuff in Libraries compiled and linked OK?
Yours is a fairly recent Linux, right? There has been a change in the linker where dynamic links are not implicitly linked anymore and my suspicion is that this is the case here.
Try the following: in Utilities/replayTransientBC/Make/options change the line
-lmeshTools
to
-lmeshTools -ltriSurface
and see if anything changes
Old   June 18, 2012, 05:45
Unhappy not better
Julien
Nothing better:
No change to swak4FoamParsers/foamVersion4swak.H
'/home/meteodyn/OpenFOAM/meteodyn-2.0.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so' is up to date.
'/home/meteodyn/OpenFOAM/meteodyn-2.0.1/platforms/linux64GccDPOpt/lib/libgroovyBC.so' is up to date.
SOURCE=swakCodedFunctionObject.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100    -I../swak4FoamParsers/lnInclude -I/opt/openfoam201/src/finiteVolume/lnInclude -I/opt/openfoam201/src/meshTools/lnInclude -I/opt/openfoam201/src/sampling/lnInclude -I/opt/openfoam201/src/triSurface/lnInclude -I/opt/openfoam201/src//postProcessing/functionObjects/utilities/lnInclude -I/opt/openfoam201/src/lagrangian/basic/lnInclude  -IlnInclude -I. -I/opt/openfoam201/src/OpenFOAM/lnInclude -I/opt/openfoam201/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/swakCodedFunctionObject.o
and at the end:
/opt/openfoam201/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::reduce(double&, Foam::sumOp<double> const&)'
/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::addValidParOptions(Foam::HashTable<Foam::string, Foam::word, Foam::string::hash>&)'
/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::exit(int)'
/opt/openfoam201/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::UOPstream::write(Foam::UPstream::commsTypes, int, char const*, long, int)'
When I run my case, it does not work:
--> FOAM FATAL IO ERROR:
Unknown patchField type groovyBC for patch type patch
Valid patchField types are :
Some help?
Old   June 18, 2012, 06:14
Assistant Moderator
Bernhard Gschaider
Nothing better:
and at the end:
Some help?
In fact that IS better because there is a new error (which means we're on the right track). Try adding "-lPStream" to that line.
Anyway: what kind of Linux are you using (my prejudices say "Ubuntu") and could you check which versions are the dynamic linker and the compiler ("ld -V" and "gcc -v" give you that information)
For the groovyBC-problem: there must be something about a dynamic-lib not loading further up in the output
Old   June 18, 2012, 07:05
Julien
Bernhard , thanks a lot. I don't know what I'd do without your kind help.
About my installation:
Linux version:
SUSE LINUX
Release 11.4 (Celadon)
Kernel Linux 2.6.37.1-1.2-desktop
GNOME 2.32.1
ld -V
GNU ld (GNU Binutils; openSUSE 11.4) 2.21
gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib64/gcc/x86_64-suse-linux/4.5/lto-wrapper
Target: x86_64-suse-linux
Configured with: ../configure --prefix=/usr --infodir=/usr/share/info --mandir=/usr/share/man --libdir=/usr/lib64 --libexecdir=/usr/lib64 --enable-languages=c,c++,objc,fortran,obj-c++,java,ada --enable-checking=release --with-gxx-include-dir=/usr/include/c++/4.5 --enable-ssp --disable-libssp --disable-plugin --with-bugurl=http://bugs.opensuse.org/ --with-pkgversion='SUSE Linux' --disable-libgcj --disable-libmudflap --with-slibdir=/lib64 --with-system-zlib --enable-__cxa_atexit --enable-libstdcxx-allocator=new --disable-libstdcxx-pch --enable-version-specific-runtime-libs --program-suffix=-4.5 --enable-linux-futex --without-system-libunwind --enable-gold --with-plugin-ld=/usr/bin/gold --with-arch-32=i586 --with-tune=generic --build=x86_64-suse-linux
Thread model: posix
gcc version 4.5.1 20101208 [gcc-4_5-branch revision 167585] (SUSE Linux)
About ./allMake :
Beginning:
No swak4FoamParsers/foamVersion4swak.H. Generated
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file printSwakVersion.C
Making dependency list for source file SurfacesRepository.C
Making dependency list for source file SetsRepository.C
Making dependency list for source file GlobalVariablesRepository.C
Making dependency list for source file ExpressionDriverWriter.C
Making dependency list for source file ExpressionResult.C
Making dependency list for source file StoredExpressionResult.C
Making dependency list for source file swakRegistryProxySurface.C
Making dependency list for source file swakRegistryProxySet.C
Making dependency list for source file FieldValueExpressionParser.yy
could not open file FieldValueExpressionParser.tab.hh for source file FieldValueExpressionParser.yy
could not open file FixedValuePointPatchField.H for source file FieldValueExpressionParser.yy
could not open file ZeroGradientPointPatchField.H for source file FieldValueExpressionParser.yy
could not open file CalculatedPointPatchField.H for source file FieldValueExpressionParser.yy
Ending:
SOURCE=replayTransientBC.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam201/src/cfdTools/lnInclude -I/opt/openfoam201/src/cfdTools/general/lnInclude   -I/opt/openfoam201/src/finiteVolume/lnInclude   -I/opt/openfoam201/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam201/src/OpenFOAM/lnInclude -I/opt/openfoam201/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/replayTransientBC.o
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam201/src/cfdTools/lnInclude -I/opt/openfoam201/src/cfdTools/general/lnInclude   -I/opt/openfoam201/src/finiteVolume/lnInclude   -I/opt/openfoam201/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam201/src/OpenFOAM/lnInclude -I/opt/openfoam201/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed Make/linux64GccDPOpt/replayTransientBC.o -L/opt/openfoam201/platforms/linux64GccDPOpt/lib \
     -lfiniteVolume -lmeshTools -ltriSurface -lPStream -lOpenFOAM -ldl   -lm -o /home/meteodyn/OpenFOAM/meteodyn-2.0.1/platforms/linux64GccDPOpt/bin/replayTransientBC
/usr/lib64/gcc/x86_64-suse-linux/4.5/../../../../x86_64-suse-linux/bin/ld: cannot find -lPStream
Just to ckeck: you meant "lPStream", with an l like lambda (lowercase) then P like principle (uppercase) ?
Old   June 18, 2012, 09:32
Assistant Moderator
Bernhard Gschaider
Linux version:
SUSE LINUX
GNOME 2.32.1
ld -V
gcc -v
COLLECT_GCC=gcc
Thread model: posix
OK. That's not as bleeding edge as I suspected
About ./allMake :
Beginning:
But the libraries are alright? (you should see lines like "'..../libgroovyBC.so' is up to date")
Ending:
Exactly. Except that I mistyped and the "S" should be lowercase ( -lPstream)
Old   June 18, 2012, 10:13
Julien
At the beginning, I can read:
.../libsimpleFunctionObjects.so' is up to date.
.../libsimpleSwakFunctionObjects.so' is up to date.
.../libswakTopoSources.so' is up to date.
.../libswakSourceFields.so' is up to date.
.../libgroovyStandardBCs.so' is up to date.
But the end:
make[1]: *** [/home/meteodyn/OpenFOAM/meteodyn-2.0.1/platforms/linux64GccDPOpt/bin/funkySetFields] Error 1
make[1]: Leaving directory `/opt/openfoam201/Telechargements/swak4Foam/swak4Foam/Utilities/funkySetFields'
make: *** [funkySetFields] Error 2
make[1]: Entering directory `/opt/openfoam201/Telechargements/swak4Foam/swak4Foam/Utilities/replayTransientBC'
     -lfiniteVolume -lmeshTools -ltriSurface -lPstream -lOpenFOAM -ldl   -lm -o /home/meteodyn/OpenFOAM/meteodyn-2.0.1/platforms/linux64GccDPOpt/bin/replayTransientBC
/usr/lib64/gcc/x86_64-suse-linux/4.5/../../../../x86_64-suse-linux/bin/ld: cannot find -lPstream
But it still doesn't work:
Old   June 18, 2012, 14:37
Assistant Moderator
Bernhard Gschaider
But the end:
The library should be in $FOAM_MPI_LIBBIN. Check with
ls $FOAM_MPI_LIBBIN
whether this is set on your system. If yes: add
-L$(FOAM_MPI_LIBBIN)
at the start(!) of the line you've already been editing in Make/options
This is not my fault. The binary distro you're using (I assume from the path that you didn't compile OF yourself) seems to be broken for compilations
I guess you added groovyBC to the libs-list in the controlDict, right? In that case check further up in the solver output: there should be some error about not being able to load it. If not recheck the libs-entry
Old   June 19, 2012, 04:10
Wink
  #11
Julien
Hi Bernhard!
OK. I understood that you think my installation is not as "clean" as possible.
So I will try to reinstall everything.
Right now, I am updating my system (zipper, yast,...), and then, I will fallow the instructions of http://www.openfoam.org/download/suse.php
Does it sounds good for you? Do you think I am in the correct path?
Old   June 19, 2012, 05:53
Default Re-install
  #12
Julien
I just installed OpenFOAM-2.1.0 from http://sourceforge.net/projects/foam/files/foam/suse/11.4/x86_64/
('cause my suse version is only 11.4).
I fallowed the instruction of official OpenFOAM page http://www.openfoam.org/download/suse.php
(rpm-i ... user configuration ... check on icofoam)
Then, I ran svn on swak4Foam .
And then ./Allwmake. Still the same problem. I added
-lmeshTools -ltriSurface -lPstream but it still dosn't work:
make[1]: *** [/home/meteodyn/OpenFOAM/meteodyn-2.1.0/platforms/linux64GccDPOpt/bin/funkySetFields] Error 1
make[1]: Leaving directory `/opt/OpenFOAM-2.1.0/Telechargements/swak4Foam/Utilities/funkySetFields'
make[1]: Entering directory `/opt/OpenFOAM-2.1.0/Telechargements/swak4Foam/Utilities/replayTransientBC'
SOURCE=replayTransientBC.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM-2.1.0/src/cfdTools/lnInclude -I/opt/OpenFOAM-2.1.0/src/cfdTools/general/lnInclude   -I/opt/OpenFOAM-2.1.0/src/finiteVolume/lnInclude   -I/opt/OpenFOAM-2.1.0/src/meshTools/lnInclude -IlnInclude -I. -I/opt/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude -I/opt/OpenFOAM-2.1.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/replayTransientBC.o
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM-2.1.0/src/cfdTools/lnInclude -I/opt/OpenFOAM-2.1.0/src/cfdTools/general/lnInclude   -I/opt/OpenFOAM-2.1.0/src/finiteVolume/lnInclude   -I/opt/OpenFOAM-2.1.0/src/meshTools/lnInclude -IlnInclude -I. -I/opt/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude -I/opt/OpenFOAM-2.1.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/replayTransientBC.o -L/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib \
     -lfiniteVolume -lmeshTools -ltriSurface -lPstream -lOpenFOAM -ldl   -lm -o /home/meteodyn/OpenFOAM/meteodyn-2.1.0/platforms/linux64GccDPOpt/bin/replayTransientBC
make[1]: *** [/home/meteodyn/OpenFOAM/meteodyn-2.1.0/platforms/linux64GccDPOpt/bin/replayTransientBC] Error 1
make[1]: Leaving directory `/opt/OpenFOAM-2.1.0/Telechargements/swak4Foam/Utilities/replayTransientBC'
What should I do to use your nice suiss knife? It seems necessary for my case...
Old   June 19, 2012, 15:01
Assistant Moderator
Bernhard Gschaider
Hi Bernhard!
I THINK the problem is that the binary version of OF you're using is somehow a bit misconfigured for compilation (basically the flags miss a -L-option). Reinstalling won't fix that i'm afraid. Have you ever tried compiling other OF-software and did that work?
Old   June 19, 2012, 17:38
Retired Super Moderator
Bruno Santos
Greetings to all!
@Julien: I've just now finished testing on openSUSE 11.4 x86_64 with the RPM packages of OpenFOAM 2.1.0 and had no problems at all!
My guess is that the problem you're having is due to placing swak4Foam's code in the folder "/opt/OpenFOAM-2.1.0/Telechargements/swak4Foam" .
After the OpenFOAM environment was ready to be used, I did:
mkdir -p $FOAM_RUN
run
cd swak4Foam
export WM_NCOMPPROCS=4
./Allwmake
./Allwmake
The "WM_NCOMPPROCS" is for using 4 cores for faster building. Ran a second time the Allwmake command just to know if all was built successfully and it was all OK! I didn't need to change anything in swak4Foam's code!
Best regards,
Bruno
Old   June 20, 2012, 03:59
Julien
(Thanks everybody! I really appreciate your kind help !)
OK, I apologize. I wanted to make it nice, so I made a special folder for the downloads, in order not to "mix" everything, but know I know I was totally wrong...
Nevertheless, I did not understand from which cwd I should launch svn ?
Old   June 20, 2012, 05:11
Assistant Moderator
Bernhard Gschaider
As long as you don't want to compile your own software that is based on swak or if you don't want to use the swakCoded-functionObject this doesn't matter
Old   June 20, 2012, 05:33
Julien
Know, swak4foam is in /home/me/OpenFOAM/me-2.1.0/run
So, I made
cd swak4Foam/
./Alwmake
There is still the errors.
Old   June 20, 2012, 10:38
Thumbs up It works now !
  #18
Julien
Bernhard, Bruno , thanks a lot . I think I found.
Compiling problems:
I had to change several /Make/option files:
  • for funkyDoCalc , funkySetBoundaryField and funkySetFields, I added the libraries -ltriSurface -lsampling -llagrangian -lPstream -lfileFormats -lsurfMesh -lconversion
  • for replayTransientBC , only -ltriSurface and -lPstream
BUT I had ALSO to move
/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/dummy/libPstrem.so
to
(??? Why was it in a "dummy" folder ???)
Now it's working! 'hope my post could help somebody else...
Bernhard: updateded my controlDict . I works now.
Once again, thanks a lot !
PS: do you think I should post a nethreaded, clean, in order to share my solution without all the rough exchanges with no interest?
Old   June 20, 2012, 12:48
Assistant Moderator
Bernhard Gschaider
Got to catch this quickly before Bruno does. He's only 19 posts behind me and at the rate he's posting my estimate is that he'll overtake me before the weekend
Compiling problems:
to
The dummy-folder holds a non-parallelized version of Pstream that is only needed to bootstrap the compilation process of OpenFOAM. Usually there should be another folder named after you mpi-implementation (openmpi-1.5 or so) with the correct Pstream (the variable $FOAM_MPI_LIBBIN points to it).
Not sure whether your stuff will no work in parallel
Would be nice to have a bug-report on the mantis with the changes required to Make/options so that it will get into the next release. The Pstream-moving .... I still think that this is a problem of the binaries you installed
Old   June 20, 2012, 16:16
Bruno Santos
Hi Bernhard and Julien,
@Bernhard:
What can I say, I'm helping people on the forum instead of playing WoW
(And I got my powers upgraded a week and a half ago nothing like whirling an axe at a spammer )
@Julien: OK, having to hack around in OpenFOAM's installation folder, usually can only mean one thing: you've got a contaminated shell environment. Let me explain: your "$HOME/.bashrc" probably has something like this:
source /opt/OpenFOAM-2.0.1/etc/bashrc
source /opt/OpenFOAM-2.1.0/etc/bashrc
When you should have something this:
alias of201='source /opt/OpenFOAM-2.0.1/etc/bashrc'
alias of210='source /opt/OpenFOAM-2.1.0/etc/bashrc'
The alias commands create command shortcuts, namely the newly created aliases of201 and of210.
Now, whenever you start a new terminal window/tab, you should run only one of the aliases above:
  • In a new terminal where you need OpenFOAM 2.0.1, run:
    of201
  • In a new terminal where you need OpenFOAM 2.1.0, run:
    of210
  • If you need to switch between versions inside the same terminal, here's what you do to switch from 2.1.0 to 2.0.1:
    wmUNSET
    of210
The other possibility is that you might have skipped some important step... for example, might not have installed Open-MPI - what does this command output:
mpirun --version
Best regards,
Bruno
swak4foam
