[swak4Foam] How to start swak4Foam
Old   September 14, 2012, 09:25
Default How to start swak4Foam
M Mallikarjuna Reddy
mmkr825 is on a distinguished road
Hi everyone,
I successfully installed swak4Foam. Now i am working on OF2.1.1 version. Initially i run wobbler case in the swak4Foam library by using solidDisplacementFoam (i didn't made any changes for the solver), I got some error message.
Error:-
malli_reddy@ubuntu:~/OpenFOAM/malli_reddy-2.1.1/swak4Foam/Examples/groovyBC/wobbler$ solidDisplacementFoam
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.1.1-221db2718bbb
Exec : solidDisplacementFoam
Date : Sep 14 2012
Time : 15:41:15
Host : "ubuntu"
PID : 30407
Case : /home/malli_reddy/OpenFOAM/malli_reddy-2.1.1/swak4Foam/Examples/groovyBC/wobbler
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading mechanical properties
--> FOAM FATAL ERROR:
Attempt to return primitive entry ITstream : /home/malli_reddy/OpenFOAM/malli_reddy-2.1.1/swak4Foam/Examples/groovyBC/wobbler/constant/mechanicalProperties::rho, line 17, IOstream: Version 2.0, format ASCII, line 0, OPENED, GOOD
primitiveEntry 'rho' comprises
on line 17 the word 'rho'
on line 17 the punctuation token '['
on line 17 the label 1
on line 17 the label -3
on line 17 the label 0
on line 17 the punctuation token ']' ...
as a sub-dictionary
From function const dictionary& primitiveEntry::dict()
in file db/dictionary/primitiveEntry/primitiveEntry.C at line 170.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Foam:rimitiveEntry::dict() in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#3 Foam::dictionary::subDict(Foam::word const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
in "/opt/openfoam211/platforms/linuxGccDPOpt/bin/solidDisplacementFoam"
#5 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Aborted
At first i run with blockMesh and then i called solidDisplacementFoam. Please suggest me how to rectify this problem.
Thanks
Regards
Mallikarjuna
mmkr825 is offline   Reply With Quote
Old   September 15, 2012, 09:02
Retired Super Moderator
Bruno Santos
Greetings Mallikarjuna,
The file content format has changed since the example was created for swak4Foam. You can easily fix the problem by running the following command:
cp $FOAM_TUTORIALS/stressAnalysis/solidDisplacementFoam/plateHole/constant/mechanicalProperties constant/
When in doubt, check OpenFOAM's own tutorials
Best regards,
Bruno
Old   September 17, 2012, 00:44
Hi Bruno,
Thanks for quick reply. Now it is working.
I have one more doubt. actually in my case i need write zero flux boundary condition. when i applied this boundary condition, i got an expression for gradient. In that equation i need to access gradient of another field. Could you please suggest me any case which is close to my problem.
Thanks
Regards
Mallikarjuna
Old   September 17, 2012, 03:50
Bruno Santos
Hi Mallikarjuna,
Sorry, I unfortunately don't know. I hope someone else can answer you.
Perhaps you might have to create a new thread to ask that question and be more detailed of what you want to know!
Best regards,
Bruno
Old   September 17, 2012, 19:12
Assistant Moderator
Bernhard Gschaider
Originally Posted by mmkr825 View Post
Hi Bruno,
Thanks
Regards
Mallikarjuna
"snGrad(foo)" in a groovyBC-expression should give you the surface-normal gradient of field foo on the patch. Hope that helps
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 18, 2012, 05:07
Hi Gshaider,
Thanks for the quick reply. Now it is working. Thank a lot, you are the man.
Thanks
Regards
Mallikarjuna
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 22:38
Sample not working correctly sihaqqi OpenFOAM Running, Solving & CFD 1 July 12, 2014 01:36
[swak4Foam] errors when trying to use swakCoded-function mayank.dce2k7 OpenFOAM Community Contributions 4 April 15, 2014 10:07
[swak4Foam] Install swak4Foam on OpenFOAM1.7.1 on Ubuntu 13.04 kobayashi OpenFOAM Community Contributions 2 January 5, 2014 17:33
Lets start the public domain CFD-Project! Heinz Wilkening Main CFD Forum 3 March 11, 1999 22:55
