[swak4Foam] a problem in groovyBC: "syntax error, unexpected '('"
Old   December 2, 2012, 14:26
Default a problem in groovyBC: "syntax error, unexpected '('"
immortality's Avatar
Ehsan
immortality is on a distinguished road
hello
here is my groovyBC in a patch but I receive an error that is:
Mean and max Courant Numbers = 97.4802 211.345
deltaT = 9.46319e-10
Time = 9.46319e-10
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0
swak4Foam: Allocating new repository for sampledGlobalVariables
--> FOAM FATAL ERROR:
Parser Error at "1.36" :"syntax error, unexpected '(', expecting value or '-'"
"pr_01*pow((internalField(T)/Tr_01),(gamma/(gamma-1)))"
From function parsingValue
in file lnInclude/CommonValueExpressionDriverI.H at line 802.
FOAM exiting
I need a urgent help.
thank you to helper!
File Type: txt groovy.txt (751 Bytes, 4 views)
immortality is offline   Reply With Quote
Old   December 2, 2012, 16:55
Assistant Moderator
Bernhard Gschaider
Originally Posted by immortality View Post
hello
Time = 9.46319e-10
FOAM exiting
THe formatting on the message board makes it hard to tell where the parser locates the syntax error. Reformatting helps:
It seems like the problem is that you're using an old version of swak4Foam: until recently for "pow(a,b)" only constant scalar values were allowed for b
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   December 3, 2012, 04:03
Ehsan
ok.from where i can download the new version?
Thank you.
Old   December 3, 2012, 04:06
Ehsan
another thing gamma here is a scalar i assigned it in variables list.just a number should be use in this version?
Old   December 3, 2012, 05:22
Assistant Moderator
Bernhard Gschaider
Thank you.
New versions of groovyBC are only available as a part of swak4Foam:
http://openfoamwiki.net/index.php/Co...am#Downloading
I think so. Best way to find out is try
Old   December 3, 2012, 05:58
Ehsan
yes when I use their number values it dosen't show any error.
Old   December 4, 2012, 13:30
Ehsan
I can't download new swak4Foam.how I should do it:
https://openfoam-extend.svn.sourcefo...ies/swak4Foam/
it opens a list that I don't know how download it.
thanks.
Old   December 4, 2012, 13:47
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Please consult this section on the wiki for details on the download procedure:
Kind regards,
Niels
ngj is offline   Reply With Quote
Old   December 4, 2012, 15:40
Ehsan
ISP I use now doesn't support https so Im downloading with http.
it doesn't have any problem?
what should I do then for installing?where this file is saving?
Old   December 4, 2012, 16:03
ngj
First of all, you should use svn (google 'subversion') to download the entire package. It is not intended for you to download the files manually.
Secondly, for compiling (building) swak4Foam look at the description on the page I gave you the link for in the previous post.
Kind regards,
Niels
Old   December 4, 2012, 16:36
Ehsan
Thank you Mr Jacobsen
a directory named swakFoam that is 7.3MB has maked in downloads directory.
is it ok?
how can I find the version of swak4Foam?
thanks.
Old   December 4, 2012, 16:40
Ehsan
I had another swak4foam before.it doesn't make any problem to older one?
it can't be upgrade or must compile from none?
thanks.
Old   December 4, 2012, 18:26
Assistant Moderator
Bernhard Gschaider
thanks.
Just compile the new one. The binaries should replace the old ones
Old   December 5, 2012, 01:31
Ehsan
thanks Mr.Gschaider
How about knowing version?
Thanks.
Old   December 5, 2012, 04:22
Assistant Moderator
Bernhard Gschaider
thanks Mr.Gschaider
Thanks.
You mean: "how do I know which version I have?"?
When you just enter
funkySetFields
you get an error message. Above that is the usual OF-header. Just below the header is a line saying "swakVersion: 0.x.x". If your version is 0.2.1 you have the most recent. If you don't see that line your version is from before 0.2.0
[swak4Foam] log velocity profile with groovyBC - syntax grjmell OpenFOAM Community Contributions 43 December 9, 2020 15:36
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 00:53
[swak4Foam] Problem with fully developed velocity profile groovyBC in 2D axi-sym mesh harshad88 OpenFOAM Community Contributions 7 July 24, 2014 14:28
[swak4Foam] GroovyBC syntax Daniele111 OpenFOAM Community Contributions 19 August 20, 2010 04:40
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
