[swak4Foam] no change in solution by change in groovyBC variables
Like Tree1Likes
  • 1 Post By gschaider
Old   January 27, 2013, 16:30
Default no change in solution by change in groovyBC variables
immortality's Avatar
Ehsan
immortality is on a distinguished road
at my boundary condition when I change w_w3 from 23.6 until 50 degree nothing is changed in solution and the right patch opens to environment at time that is was opened before change.it seems that it is ignored although w_w3 is used in t1 constant and it should have affected on (0<=time()&&time()<=t1) part of condition.why it occurs?
thanks.
this is the BC on U:
right
        type groovyBC;
        variables (
                  //"pi=3.1415926535;"
                  "ymax=max(pos().y);"
                  "ymin=min(pos().y);"
                  "r=0.02325;"
                  "rpm=32151;"
                  "omega=rpm*pi/30;"
                  "v_r=r*omega;"
                  "w_cell=.004;"
                  "n=1;"
                  "w_w0=n*w_cell;"
                  "w_w3=(50-0)*r*pi/180;"
                  "w_w4=(83-61.6)*r*pi/180;"
                  "w_w5=(180-128)*r*pi/180;"
                  "w_p2=(71.1-21.6)*r*pi/180;"
                  "w_p4=(129-84)*r*pi/180;"
                  "c1=w_p2/v_r;"
                  "c2=(w_p2+w_w4)/v_r;"
                  "c3=(w_p2+w_w4+w_p4)/v_r;"
                  "c4=(w_p2+w_w4+w_p4+w_w5+w_w3)/v_r;"
                  "t1=(w_w0+w_w3-pos().y)/v_r;"
                  "t2=t1+c4;"
                  "t3=t1+2*c4;"
                  "t4=t1+3*c4;"
                  "t5=t1+4*c4;"
                  "t6=t1+5*c4;"
                  "t7=t1+6*c4;"
                  "t8=t1+7*c4;"
                  "t9=t1+8*c4;"
                  "t10=t1+9*c4;"
                  "t11=t1+10*c4;"
                  "p0_1=303975;"
                  "T0_1=440;"
                  "p0_3=932190;"
                  "T0_3=1248;"
                  "p0_2=1023382.5;"
                  "T0_4=973;"
                  "gamma=1.4;"
                  "R=287.14;"
        fractionExpression "((0<=time()&&time()<=t1)||(t1+c1<=time()&&time()<=t1+c2)||(t1+c3<=time()&&time()<=t1+c4)||(t2+c1<=time()&&time()<=t2+c2)||(t2+c3<=time()&&time()<=t2+c4)||(t3+c1<=time()&&time()<=t3+c2)||(t3+c3<=time()&&time()<=t3+c4)||(t4+c1<=time()&&time()<=t4+c2)||(t4+c3<=time()&&time()<=t4+c4)||(t5+c1<=time()&&time()<=t5+c2)||(t5+c3<=time()&&time()<=t5+c4)||(t6+c1<=time()&&time()<=t6+c2)||(t6+c3<=time()&&time()<=t6+c4)||(t7+c1<=time()&&time()<=t7+c2)||(t7+c3<=time()&&time()<=t7+c4)||(t8+c1<=time()&&time()<=t8+c2)||(t8+c3<=time()&&time()<=t8+c4)||(t9+c1<=time()&&time()<=t9+c2)||(t9+c3<=time()&&time()<=t9+c4)||(t10+c1<=time()&&time()<=t10+c2)||(t10+c3<=time()&&time()<=t10+c4)||(t11+c1<=time()&&time()<=t11+c2)||(t11+c3<=time()&&time()<=t11+c4))?1:0";
        valueExpression "vector(0,-v_r,0)";
        gradientExpression "vector(0,0,0)";
        value uniform (0 -78.27914269 0);
immortality is offline   Reply With Quote
Old   January 28, 2013, 02:38
Ehsan
does anyone see a trouble in this BC?the long terms should not be frighteninng.they're simple!
Old   January 28, 2013, 07:34
Assistant Moderator
Bernhard Gschaider
Nevertheless: make them simpler (only put one intervall into fractionExpression for instance). Also: try putting the variables used (t1 and c4 I think) into the valueExpression to see if they really have the values they're supposed to have)
immortality likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
CFL Condition Matt Umbel Main CFD Forum 19 June 30, 2020 08:20
[swak4Foam] Defining two different variables at two patch in groovyBC with the same name immortality OpenFOAM Community Contributions 2 January 9, 2013 18:03
[swak4Foam] change "value" in groovyBC r2d2 OpenFOAM Community Contributions 5 September 29, 2011 12:16
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
