[swak4Foam] what this sentence in groovyBC compiling mean? |
February 17, 2013, 05:42 |
Ehsan
Rep Power: 26 |
is this message an error?
No 'swakConfiguration'. Python etc won't work |
February 17, 2013, 05:49 |
Ehsan
Rep Power: 26 |
and also these:
lex.fvexpr.c:60969:22: warning: use of old-style cast [-Wold-style-cast] Code:
lex.parserSubset.c:10227:57: warning: use of old-style cast [-Wold-style-cast] lex.parserSubset.c:10227:57: warning: use of old-style cast [-Wold-style-cast] ][/CODE] and also: Code:
position.hh:136:69: warning: suggest parentheses around ‘&&’ within ‘||’ [-Wparentheses] Code:
Making dependency list for source file swakExplicitSources.C could not open file FixedValuePointPatchField.H for source file swakExplicitSources.C could not open file ZeroGradientPointPatchField.H for source file swakExplicitSources.C could not open file CalculatedPointPatchField.H for source file swakExplicitSources.C |
February 17, 2013, 06:08 |
#3 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
(The message board needs to have at least 10 characters so I'll add an aside: I don't want to imagine the amount of questions you'll ask once you start with Python)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
February 17, 2013, 06:12 |
#4 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
"Could not open file" is an artefact of the utility that determines the dependenies of the source files. It is completely irrelevant
February 17, 2013, 06:58 |
Ehsan
Rep Power: 26 |
allright.then these are not any problems and compilation is ok?
[swak4Foam] is this pattern and message of compiling groovyBC 0.2.1 ok? | immortality | OpenFOAM Community Contributions | 3 | May 13, 2013 10:15 |
[swak4Foam] some errors in compiling groovyBC in OF220 | immortality | OpenFOAM Community Contributions | 10 | April 1, 2013 03:46 |
[swak4Foam] is this expression as bolean sentence wrong in groovyBC? | immortality | OpenFOAM Community Contributions | 6 | March 8, 2013 05:24 |
[swak4Foam] problem in compiling groovyBC in OpenFoam 1.71 | javad814 | OpenFOAM Community Contributions | 4 | July 31, 2011 04:33 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
