[swak4Foam] Turbulent inlet with groovyBC
Old   March 2, 2012, 08:48
Default Turbulent inlet with groovyBC
Joyi Wang
zcjwyl is on a distinguished road
Hi Foam pioneers,
I've implemented a parabolic velocity profile using groovyBC at the inflow B.C. I still want to add a random fluctuation, like the turbulent inlet B.C. in standard OF does.
Is there a way that can couple the two BCs? THX in advance.
Any suggestion on implement a turbulent B.C will be of great appreciation.
zcjwyl is offline   Reply With Quote
Old   March 14, 2012, 07:12
Assistant Moderator
Bernhard Gschaider
Originally Posted by zcjwyl View Post
Hi Foam pioneers,
There are 4 functions in the swak4Foam-version of groovyBC: rand, randNormal, randFixed and randFixedNormal. See the README-file for details (hint: you won't want the Fixed-variety)
Old   December 3, 2012, 08:25
hfs
hfs is on a distinguished road
Any success with combining the groovyBC+turbulentInlet BCs?
hfs is offline   Reply With Quote
Old   April 19, 2013, 12:27
Suro Kim
imsurokim is on a distinguished road
Anybody work on this?
I am having trouble getting groovyBC and turbulentInlet at the same time.
imsurokim is offline   Reply With Quote
Old   April 19, 2013, 13:28
immortality's Avatar
Ehsan
immortality is on a distinguished road
I have a unsteady turbulent compressible internal flow (one inlet and one outlet).I have not faced any trouble related to their combination.
immortality is offline   Reply With Quote
Old   April 20, 2013, 00:37
lixx is on a distinguished road
You can have a look at this report from Charlmers Open source CFD course:
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD/NinaGallJorgensen/ReportReviewed.pdf
This is about a way to generate turbulent inlet conditions based on vortex method (see the reference therein). You can also find the corresponding code on that website. But do note that the code has some problems when ruuning in parallel and it does not fully implement the original vortex method.
lixx is offline   Reply With Quote
[swak4Foam] GroovyBC problem in the defining inlet velocity iampolaris OpenFOAM Community Contributions 7 October 18, 2014 09:25
UDF for fully developed turbulent flow at inlet soroushsaberi FLUENT 0 May 28, 2014 17:00
Spatially Developing Turbulent Boundary Layer Inlet deji OpenFOAM 1 June 8, 2010 14:52
Specify turbulent inlet chris1980 OpenFOAM Running, Solving & CFD 4 August 29, 2006 03:11
inlet turbulent B.C. ROOZBEH FLUENT 3 September 25, 2003 07:07
