[swak4Foam] groovyBC variable parallel reduce?
Old   April 5, 2013, 10:19
Default groovyBC variable parallel reduce?
startingWithCFD is on a distinguished road
Hello there!
I would like to impose a boundary condition based on the amount of mass which is inside my domain, as follows
        type            groovyBC;
        variables
            "Mass{cellSet'allCells}=sum(rho*vol());"
        valueExpression "bananas*Mass";
The problem is that when the problem is decomposed, Mass contains the value corresponding to the current processor domain. Is there a way to force a parallel reduce operation?
startingWithCFD is offline   Reply With Quote
Old   April 5, 2013, 13:52
Assistant Moderator
Bernhard Gschaider
Originally Posted by startingWithCFD View Post
Hello there!
        type            groovyBC;
        variables
The question is "is there a way to force swak to NOT do a parallel reduce?". To which I would have to say "No".
Seriously: functions like sum, max, min AUTOMATICALLY reduce over all processors (if you find instances where this isn't the case: report a bug). In my mind this is the only behaviour that makes sense for this application
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   April 8, 2013, 03:36
Great, thanks for the answer :-)
I guess I reached a conclusion too fast!
Running parallel case after parallel meshing with snappyHexMesh? Adam Persson OpenFOAM Running, Solving & CFD 0 August 31, 2015 22:04
Can not run OpenFOAM in parallel in clusters, help! ripperjack OpenFOAM Running, Solving & CFD 5 May 6, 2014 15:25
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 16:49
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
