[cfMesh] cfMesh - OpenFOAM v1812 not working in parallel
Old   March 8, 2019, 13:21
Default cfMesh - OpenFOAM v1812 not working in parallel
cody
codygo is on a distinguished road
My case is approximately 60M cells, and meshes fairly quickly in cfMesh if I don't attempt "-parallel" (preceded by preparePar, using proper mpi call)
[qtzlctl:32171] *** An error occurred in MPI_Recv
[qtzlctl:32171] *** reported by process [3578789889,16]
[qtzlctl:32171] *** on communicator MPI_COMM_WORLD
[qtzlctl:32171] *** MPI_ERR_TRUNCATE: message truncated
[qtzlctl:32171] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
[qtzlctl:32171] ***    and potentially your MPI job)
I've tried varying MPI_BUFFER_SIZE, and though it does seem to affect where it crashes, I haven't been able to find a stable value.
I can get a little closer if I attempt to run preparePar after creating the mesh, but this is painfully slow.
I'd like to be able to get a successful parallel mesh with cfMesh, and continue adding layers using snappyHexMesh.
codygo is offline   Reply With Quote
Old   May 3, 2019, 06:22
Olivier
olivierG is on a distinguished road
hello,
CfMesh work in parallel without MPI on a multi core single machine. So if your PC have 8 core, set OMP_NUM_THREADS=8 and run CfMesh.
Usually, you just need this.
The only case you would use MPI parallel meshing, is in case you run CfMesh on 2 or more PC (Cluster). In that case, you should infor MPI chich machine and how many core in your cluster. But your error message does not permit to know what 's wrong in your case.
regards,
olivier
olivierG is offline   Reply With Quote
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 16:38
Openfoam parallel calculation performance study - Half performance on mpirun Jurado OpenFOAM Running, Solving & CFD 22 March 24, 2018 20:40
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 03:18
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 13:36
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
