[swak4Foam] whats wrong with this groovyBC expression in parenthesis?
Like Tree1Likes
  • 1 Post By gschaider
Old   May 30, 2013, 15:17
Default whats wrong with this groovyBC expression in parenthesis?
immortality's Avatar
Ehsan
immortality is on a distinguished road
valueExpression "1.5*sqr(I*sum(mag(U.x)*Sf())/sum(Sf()))";
Selecting turbulence model type RASModel
Selecting RAS turbulence model kOmegaSST
kOmegaSSTCoeffs
alphaK1         0.85034;
alphaK2         1;
alphaOmega1     0.5;
alphaOmega2     0.85616;
Prt             1;
gamma1          0.5532;
gamma2          0.4403;
beta1           0.075;
beta2           0.0828;
betaStar        0.09;
a1              0.31;
b1              1;
c1              10;
F3              false;
fluxScheme: Kurganov
Starting time loop
Mean and max Courant Numbers = 3.846733161 23.44685531
deltaT = 2.127659574e-09
Time = 2.12766e-09
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0
[2] swak4Foam: Allocating new repository for sampledGlobalVariables
[3] swak4Foam: Allocating new repository for sampledGlobalVariables
[0] swak4Foam: Allocating new repository for sampledGlobalVariables
[1] swak4Foam: Allocating new repository for sampledGlobalVariables
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 2.261632314e-10, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 1.356428384e-11, No Iterations 2
diagonal:  Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver:  Solving for e, Initial residual = 0.003206774438, Final residual = 2.033790977e-08, No Iterations 50000
time step continuity errors : sum local = 5.358600541e-20, global = -5.358600541e-20, cumulative = -5.358600541e-20
smoothSolver:  Solving for omega, Initial residual = 0.009786991015, Final residual = 7.059726646e-08, No Iterations 4
[0] [1]
[1]
[1] --> FOAM FATAL ERROR:
[1] [2]
[3]
[3]
[3]  Parser Error for driver PatchValueExpressionDriver at "1.39" :"syntax error, unexpected ')'"
Context of the error:
- From dictionary: /home/ehsan/Desktop/Central/nonUniformMesh/Turbulent_WR/main_test/processor1/0/k.boundaryField.left
Evaluating expression "1.5*sqr(I*sum(mag(U.x)*Sf())/sum(Sf()))"
[1]
[1]
[1]     From function parsingValue
[1]     in file lnInclude/CommonValueExpressionDriverI.H at line 1039.
[1]
FOAM parallel run exiting
[1]
- From dictionary: /home/ehsan/Desktop/Central/nonUniformMesh/Turbulent_WR/main_test/processor3/0/k.boundaryField.left
[3]
[3]
[3]     From function parsingValue
[3]     in file lnInclude/CommonValueExpressionDriverI.H at line 1039.
[3]
[3]
[2]
[2] --> FOAM FATAL ERROR:
[2]  Parser Error for driver PatchValueExpressionDriver at "1.39" :"syntax error, unexpected ')'"
- From dictionary: /home/ehsan/Desktop/Central/nonUniformMesh/Turbulent_WR/main_test/processor2/0/k.boundaryField.left
[0]
MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[0] --> FOAM FATAL ERROR:
[0]  Parser Error for driver PatchValueExpressionDriver at "1.39" :"syntax error, unexpected ')'"
- From dictionary: /home/ehsan/Desktop/Central/nonUniformMesh/Turbulent_WR/main_test/processor0/0/k.boundaryField.left
[0]
[0]
[0]     From function parsingValue
[0]     in file lnInclude/CommonValueExpressionDriverI.H at line 1039.
[0]
[0]
mpirun has exited due to process rank 3 with PID 8236 on
node Ehsan-com exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
[Ehsan-com:08227] 2 more processes have sent help message help-mpi-api.txt / mpi-abort
[Ehsan-com:08227] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Killing PID 8223
 PyFoam WARNING on line 232 of file /usr/local/lib/python2.7/dist-packages/PyFoam/Execution/FoamThread.py : Process 8223 was already dead
Getting LinuxMem: [Errno 2] No such file or directory: '/proc/8223/status'
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   May 31, 2013, 13:01
Assistant Moderator
Bernhard Gschaider
Originally Posted by immortality View Post
[0] [1]
[1]
[1] [2]
[3]
[3]
[1]
[1]
[1]
[1]
[3]
[3]
[3]
[3]
[2]
[0]
with errorcode 1.
[0]
[0]
[0]
[0]
Killing PID 8223
Is I a field you're using here or is it really your intention to use it as the unit-tensor? This means that the scalar expression you have here is promoted to a spherical tensor and swak doesn't know how to calculate the square of this, so it expects SOMETHING that reduces the tensor to a scalar (or at least a vector) when it encounters the ")"
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   May 31, 2013, 13:41
Ehsan
Hi
'I' is a constant defined in variables equal to .05 according to turbulent kinetic energy formula k=1.5 \, {(l \, I \,U)}^{2} .why OF assumes it as a tensor?for its capital form?
Old   May 31, 2013, 14:03
Assistant Moderator
Bernhard Gschaider
Hi
In newer versions of swak if no field I is defined then I is assumed to be the unit tensor. Otherwise the field should be used. Maybe this doesn't work with variables. Try for a test to replace it with the actual value. Or another variable name
Old   May 31, 2013, 14:22
Ehsan
thanks dear Bernard.
I wrote it as:
valueExpression "1.5*sqr(I*sum(mag(U.x)*mag(Sf()))/sum(mag(Sf())))";
and doen't show an error on the expression although the run crashes after some(around 12) iterations.
Old   May 31, 2013, 16:14
Assistant Moderator
Bernhard Gschaider
I wrote it as:
OK. Then this is a bug (concerning the handling of I)
That is not a swak-problem
Old   May 31, 2013, 18:06
Ehsan
Bernhard do you mean it should display an error on 'I'?I have defined it as a constant why do you say so?
yes that was for a somewhat bad BC.
and if should report,I have to speak about what aspect of issue?
thanks.
Old   May 31, 2013, 19:20
Assistant Moderator
Bernhard Gschaider
thanks.
Well. It should say "Ah, there's a variable 'I'. He probably means that and not the unit tensor" but it doesn't. It shouldn't display and error
Old   June 1, 2013, 05:00
Ehsan
i think this error was on Sf() .it should have been mag(Sf()) and when i noticed and corrected it,no error displayed.
Anyway i understand what you said about the error but I still think the error should be modified.it says a ) is lost while its about using tensors and/or vectors.
Old   June 4, 2013, 12:34
Assistant Moderator
Bernhard Gschaider
Some function (maxPosition for instance) expect a scalar. So if you say "maxPosition(pos())" at the last ")" it says "hey. That can't be all. At least add a .x or so to make it a scalar. But the ')' is to early". This is what "unexpected ')'" means .. sometimes. At other times you just forgot a '('
immortality likes this.
Old   June 5, 2013, 05:50
Ehsan
thanks so much.
a lateral question from your example!
I use max(pos().y) for example.whats the difference between function max and function maxPosition?
Old   June 5, 2013, 07:54
Assistant Moderator
Bernhard Gschaider
thanks so much.
That is explained in the README file AND the reference documentation (sometimes I seriously wonder why I write those files): the position where the maximum occurs
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
Convergence problem with tetrahedral grids Tarak OpenFOAM Running, Solving & CFD 22 June 25, 2018 19:09
[swak4Foam] groovyBC not working pakanatiakash OpenFOAM Community Contributions 5 January 13, 2016 11:25
meshing of a compound volume in GMSH shawn3531 OpenFOAM 4 March 12, 2015 10:45
[swak4Foam] is this expression as bolean sentence wrong in groovyBC? immortality OpenFOAM Community Contributions 6 March 8, 2013 05:24
