[swak4Foam] Timedependent groovybc
Like Tree1Likes
  • 1 Post By gschaider
Old   November 28, 2013, 08:59
Default Timedependent groovybc
Jakob1 is on a distinguished road
Hey, I am just doing my first baby steps with groovybc and as a start I want to set a T boundary condition to a simple time dependent function. Not sure what I am doing wrong, this is the code:
oben
        type            groovyBC;
	valueExpression "313-(20*exp(a*time())";
	variables	"a=(-2.1/(0.001*2400))";
	timelines	();
paraFoam tells me:
--> FOAM Warning :
    From function groovyBCFvPatchField<Type>::groovyBCFvPatchField(const fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict)
    in file groovyBCFvPatchField.C at line 131
    No value defined for T on oben therefore using 66{0}
When I try to run the simulation I get
--> FOAM FATAL ERROR:
 Parser Error for driver PatchValueExpressionDriver at "1.22-21" :"syntax error, unexpected $end"
Context of the error:
- From dictionary: /home/jakob/OpenFOAM/jakob-2.2.x/run/setCyl20k_10/0/T.boundaryField.oben
  Evaluating expression "313-(20*exp(a*time())"
    From function parsingValue
    in file lnInclude/CommonValueExpressionDriverI.H at line 1081.
FOAM exiting
What am I doing wrong here? I added the libs into the controlDict and set the boundary type to groovyBC. Thanks guys
Jakob1 is offline   Reply With Quote
Old   November 28, 2013, 15:33
Assistant Moderator
Bernhard Gschaider
oben
        type            groovyBC;
	timelines	();
paraFoam tells me:
--> FOAM Warning :
FOAM exiting
There's two things here:
- the syntax error: count the ( and the ) and you will be enlightened
- "no value defined": groovyBC does not evaluate valueExpression during loading (the reason is that the expression might use a field that has not yet been loaded) so it falls back 'value' - if that is there. If it is not there it falls back to '0' - which it tells you in the warning. That is "good enough" for many applications. In your case (temperature) it is not so good (unless your physics make sense at 0 K). Solution is to provide a 'value' for the initialization with a sensible value ("value $internalField" is always a good guess)
Jakob1 likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
[swak4Foam] groovyBC for oscillatory flow liybzd OpenFOAM Community Contributions 5 November 12, 2018 07:53
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 06:46
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 03:30
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 07:16
[swak4Foam] groovyBC and Eqn.setReference() benk OpenFOAM Community Contributions 3 June 2, 2011 08:49
