[swak4Foam] Post-processing on an empty patch using swak4foam
Old   October 9, 2013, 10:42
Default Post-processing on an empty patch using swak4foam
buffi is on a distinguished road
I have a large domain consisting of multiple similar regions for which I want to calculate surface flow field quantities such as U*T*dA through a surface in order to come up with an energy balance.
I used topoSet to create cellSets (for each region) and then created smaller meshes using subsetMesh. However, the new meshes contain an empty patch (which was internal before) called oldInternalFaces. I understand why that empty patch must be there, but how can I now calculate surface field flow?
I tried swak4Foam with this function object:
  QFlow
    type patchFieldFlow;
    functionObjectLibs
      "libsimpleFunctionObjects.so"
    verbose true;
    patches
      inX
      outX
      oldInternalFaces
    fields
      k
    factor 4185;
    outputControl timeStep;
    outputInterval 1;
but unfortunately, swak4foam reports surface field flow through oldInternalFaces as zero.
Also, the field I'm interested in (T) cannot be found by swak4foam (that's why I used k in the above example). Does anybody know why and how I can fix that? The field is where it's supposed to be and I can view it in paraFoam.
When I do the same calculation in paraFoam using the calculator filter with U*T, the resulting surface field flow is non-zero. So to sum it up: How can I calculate quantities such as U*T*dA and integrate them over an empty patch? I don't want to use paraFoam as I'd like to use the results in scripts (many cases).
Regards
Christoph
buffi is offline   Reply With Quote
Old   October 9, 2013, 11:08
Assistant Moderator
Bernhard Gschaider
Originally Posted by buffi View Post
  QFlow
    functionObjectLibs
    verbose true;
    patches
      inX
      outX
      oldInternalFaces
    fields
      k
    factor 4185;
    outputInterval 1;
Check phi. I think (but please check before you take my word) that this should be zero on an empty patch. And 0*k is 0
That is strange. Which solver are you using? If T is in the registry swak should find it. But there are very special cases where a second field named T exists and throws the original out of the registry (its still there. Just not registered anymore). On the other hand: then T shouldn't get written anyhow
That is quite possible. If paraview doesn't understand a boundary condition it uses zeroGradient. So you might get a non-zero U on the empty-boundary (and even a component "through" the empty). Maybe an expression "(U&Sf())*T" will give you your flow (not sure whether U is allowed to be non-zero on the boundary)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 9, 2013, 11:35
I wasn't sure how to check phi, so I just looked at the boundary in phi.gz and it just contains the "empty" patch description. However, the patch normal is aligned with the y coordinate, so I foamCalc'ed components U and the result of Uy*T is zero as well.
I'm using simpleFoam with an added equation for T. Here's the instatiation:
volScalarField T
  IOobject
    "T",
    runTime.timeName(),
    mesh,
    IOobject::MUST_READ,
    IOobject::AUTO_WRITE
  mesh
How would the function object look like then? I tried
  QFlow1
    type surfaces;
    valueType surface;
    surfaceName oldInternalFaces;
    expression "U&Sf())*T";
    accumulations (sum);
    outputInterval 1;
but that also gave me zero.Not sure if the function object is correct, though.
My conclusion for now is that my way of splitting the domain for post-processing is not well suited for my goal of integrating over the new surface created by the split.
Old   October 9, 2013, 12:01
If that matters, here's how I execute the function:
execFlowFunctionObjects -dict funkyDoCalcDict
and the dict is in the system/.
Old   October 9, 2013, 16:23
Assistant Moderator
Bernhard Gschaider
volScalarField T
  IOobject
    "T",
    runTime.timeName(),
    mesh,
  mesh
  QFlow1
    type surfaces;
    valueType surface;
    outputInterval 1;
Looks OK to me.
And it "finds" T (you must have changed something)
Splitting is OK (I guess). The problem is that "empty" is not the appropriate BC for that. That BC is for "erasing" the 3rd dimension for a 2D-calculation. So it is designed to "not let anything through".
Old   October 10, 2013, 03:42
Looks OK to me.
Yes, it's a totally different function object which presumably is implemented differently. I haven't had a look at the code, though...
Yes, empty is not suitable in this case. Any suggestion what I could use instead without too much hassle? I tried to turn it into a plain patch using createPatch and then remap the fields, but mapFields refused to map anything.
Old   October 10, 2013, 10:57
Assistant Moderator
Bernhard Gschaider
Both use "lookupObject" so it should be the same
I'm not sure what your "multiple regions" (original posting) are. Your setup only makes sense for a multiRegion-solver like chtFoam. If you want "control surfaces" in a single-region solver then faceZones or faceSets are more what you need
Old   October 10, 2013, 11:13
Thanks for the hint, the term "region" in my first post was misleading. I'll try faceSets or faceZones. I have never used faceZones, what exactly are they? The documentation is not very verbose in that respect...
Old   October 10, 2013, 13:31
Assistant Moderator
Bernhard Gschaider
These are collections of faces. Some mesh converters generate them. Another possibility is topoSet (look through the tutorials for examples like lagrangian/reactingParcelFoam/filter/system/topoSetDict).
But that is not a swak-problem anymore
Old   October 11, 2013, 04:25
I did a forum search on the difference between faceSets and faceZones, and found this thread: http://www.cfd-online.com/Forums/ope...condition.html (post #8). So what I would need here is a faceZone wherever I want to sample in the field and I could then use swak4Foam or some other post-processing tool to calculate the quantities I'm interested in and integrate them over the zone. Does that sound viable? It would still be a potential swak-problem
To make this more descriptive, here are two screenshots of the whole mesh and of the subdomain:
The whole domain consists of 5 similar subdomains for which I want to calculate an energy balance. This is one of the subdomains I generated with subsetMesh, the new empty patch is on the left side:
Old   October 11, 2013, 08:28
Assistant Moderator
Bernhard Gschaider
Attachment 25994
Attachment 25995
swak can do calculations on faceSets and faceZones. So if can create them you're in business. Examples for using swakExpression or similar can be found in the examples and in the presentations that are found on the Wiki-page. If you use phi you'll need the flip()-function
Old   October 11, 2013, 08:46
Well, I was able to create a faceSet from the new empty patch, but not in the larger domain where these faces would be internal.
Evaluating with swak4foam didn't work as expected. This is the code I used:
functions
  QFlow2
    type swakExpression;
    valueType faceSet;
    setName beforeFilter;
    expression "phi*flip()*T";
    accumulations (
      sum
    verbose true;
but I got this error message:
Unknown function type swakExpression
Table of functionObjects is empty
Old   October 11, 2013, 09:58
Assistant Moderator
Bernhard Gschaider
functions
  QFlow2
    valueType faceSet;
    accumulations (
      sum
    verbose true;
You've got to add the library with the functionObjects to the libs-list in controlDict (check the examples)
Old   October 11, 2013, 11:52
Thanks for the hint, will try that on monday...
Old   October 14, 2013, 04:59
Adding the lib helped a bit, but didn't give me a result. For
functions
  QFlow2
    valueType faceSet;
    setName intFaces;
    accumulations (
      sum
    verbose true;
to work, I need a faceSet named "intFaces" and a cellSet named "intFacesSlaveCells". I created those with a topoSetDict containing
actions
    name intFaces;
    type faceSet;
    action new;
    source patchToFace;
    sourceInfo
      name "oldInternalFaces";
    name intFacesSlaveCells;
    type cellSet;
    action new;
    source faceToCell;
    sourceInfo
      set intFaces;             // Name of faceSet
      option any;
However, executing
execFlowFunctionObjects -time 10011 -dict funkyDoCalcDict
returns an error stating: "field T not existing or of wrong type". The field T does exist and can viewed in paraFoam.
Old   October 14, 2013, 08:31
Assistant Moderator
Bernhard Gschaider
functions
  QFlow2
    valueType faceSet;
    setName intFaces;
    accumulations (
      sum
    verbose true;
actions
    name intFaces;
    type faceSet;
    action new;
    source patchToFace;
    sourceInfo
    type cellSet;
    action new;
    source faceToCell;
    sourceInfo
      option any;
However, executing
The function objects don't search on the disc for data but only in memory. You can switch that behaviour on with the searchOnDisc-option (must be set in each FO-spec. See the incomplete reference guide). But why don't you use funkyDoCalc?
Old   October 14, 2013, 08:49
I didn't use funkyDoCalc because I didn't get it working first, that's all. I didn't know about any substantial differences between the two so this was not real decision.
Removed the "functions" block surrounding the definition to make it work with funkyDoCalc, this is the resulting dict:
QFlow2
  valueType faceSet;
  setName intFaces;
  searchOnDisk true;
  accumulations (
    sum
  verbose true;
But unfortunately the error remains:
Could not find a field name T of type scalar (neither surfaceScalarField nor volScalarField) autoInterpolate: 0 (try setting 'autoInterpolate' to 'true')
    From function SubsetValueExpressionDriver::getFieldInternalAndInterpolate(const word &name,const Subset &sub)
    in file SubsetValueExpressionDriverI.H at line 303.
Old   October 14, 2013, 10:15
Assistant Moderator
Bernhard Gschaider
QFlow2
  valueType faceSet;
  setName intFaces;
  searchOnDisk true;
  accumulations (
    sum
  verbose true;
I think the error message explains quite well what the problem (you're doing calculations on faces and need a field that is only defined in the cells) is and it even suggests a fix (read the reference guide about autoInterpolate).
No matter what I write into the error messages the effect is similar to writing "There is a problem. Ask Bernhard". And when I ask nobody says "Well. I would have understood that error message if it had said ...." so I guess people think "Ups. I should have read the content of the message before asking"
Old   October 14, 2013, 10:37
I read the error message and thought "If there is no field to be found, interpolating that not-a-field will not solve my problem". That's why I didn't even try autoInterpolate.
I totally understand your point here as I'm in a similar position regularly, but in a different context.
adding autoInterpolate true to the function indeed made the error disappear, I'll see if the results make any sense.
Thanks!
Christoph
[Commercial meshers] Fluent msh and cyclic boundary cfdengineering OpenFOAM Meshing & Mesh Conversion 49 November 29, 2024 21:16
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 18:32
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 13:38
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 11:25
