[waves2Foam] how to build a time-dependent wave input under wave2Foam
Old   September 29, 2014, 22:41
Default how to build a time-dependent wave input under wave2Foam
Albert Tong
tfuwa is on a distinguished road
Dear Niels and everyone,
Could you please comment on how to build a time-dependent wave input under wave2Foam, such as a wave group or wave pocket as shown bellow? Thank you very much (sorry if this has been covered in this thread or anywhere else, and in that case a link would be much appreciated).
Kind regards,
Albert
tfuwa is offline   Reply With Quote
Old   September 30, 2014, 02:48
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good morning Albert,
It puzzles me a bit that you consider a wave package more time varying than other waves, but besides that you have two options:
1. Use the focusing functionality for the phases for the generation of irregular waves. (see: waves2Foam/src/waves2Foam/waveTheories/irregular/ and http://openfoamwiki.net/index.php/Co...hasing_Methods).
2. Create a new wave theory that is based on the wanted algebraic formulation. You could e.g. start from the template placed in waves2Foam/doc/templateWaveTheory and use the script as follows:
./makeNewWaveTheory albertsWave
Here, "albertsWave" will be the future name of the wave theory in e.g. waveProperties.input. Note, that this template does not (currently) create a matching setWaveProperties file, but you might want to pre-compute some variables. The setWaveProperties-classes are located in waves2Foam/src/waves2FoamProcessing/preProcessing/setWaveProperties and follows the same code structure as the wave theories.
Good luck,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   September 30, 2014, 05:46
Albert Tong
Good luck,
Niels
Hi Niels,
Many thanks for your prompt reply. I am interested in wake pocket as I am planing to simulate extreme waves and in the same time to save computational effort.
I will try to see if I have any luck. Thank you.
Kind regards,
Albert
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 05:49
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 07:09
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 07:56
