[swak4Foam] GroovyBC. Distance from patch face center to wall terrain.
Old   October 22, 2014, 13:35
Default GroovyBC. Distance from patch face center to wall terrain.
M. Montero
be_inspired is on a distinguished road
Hi all,
The point is that atmBoundaryLayerInletVelocity uses a zGround variable to impose the logaritmic profile. If the surface is not planar, we could have a problem because Zground is clearly variable.
To solve this point I want to use groovyBC. The same mathematical formulation is implemented but I want to use dist() function to calculate the distance the final distance between face center and the terrain.
I have used:
boundaryField
    inlet
      type            groovyBC;
      variables "wd=dist();";
      valueExpression  "vector(wd,0,0)";
      gradientExpression "vector(0,0,0)";
      fractionExpression "(phi > 0) ? 0 : 1";
      value           uniform (10 0 0);
But I obtain wd=0 for the inlet patch. Maybe dist() does not see the terrain?
The appoach that I would like to follow is to impose the wallDistance of the neighbour cell to the face center.
zDistance=dist();wd=internalField(zDistance)
This also fails.
How can I obtain an internalField, zDistance, that I can operate with to obtain wd at the patch?
Thank you very much
be_inspired is offline   Reply With Quote
Old   October 22, 2014, 15:17
Assistant Moderator
Bernhard Gschaider
Originally Posted by be_inspired View Post
Hi all,
I have used:
boundaryField
    inlet
      type            groovyBC;
This also fails.
Thank you very much
Not sure but distToPatch (http://sourceforge.net/p/openfoam-ex...amReference.md) might do what you need. For performance reasons I would not use this directly in the BC (unless your terrain changes) but create it in a functionObject at the beginning of the run
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
