[swak4Foam] swak4Foam and OpenFoam 3.0.x
Like Tree8Likes
Old   November 25, 2015, 05:18
Default swak4Foam and OpenFoam 3.0.x
Dr. Fabian Schlegel
fs82 is on a distinguished road
Dear All,
has anybody tried to compile swak4Foam with OpenFoam 3.0.x? I tried it but it won't work. It seems to be some issue with the configuration files or with the environmental variables. OpenFoam 3.0.x compiles fine without any error, but swak4Foam complaines about missing files. This is the output of ./Allwmake in swak4Foam directory
This is a clean install
/opt/pkg/simulation/OpenFOAM/fwd/3.0.x/OpenFOAM-3.0.x/applications/utilities/miscellaneous/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
Reading variables from 'swakConfiguration'
swakConfiguration: line 13: [: : integer expression expected
Checking swak4Foam-version and generating file
Swak version is 0.3.2
Bison is version 2.7.12-4996
Flex is version 2.5.35 (Minor version: 35)
OpenFOAM-version: Major 3 Minor 0 Patch -1 (-1 == x / 98)
No swak4FoamParsers/foamVersion4swak.H. Generated
wmakeLnInclude: linking include files to simpleFunctionObjects/lnInclude
/opt/pkg/simulation/OpenFOAM/fwd/3.0.x/OpenFOAM-3.0.x/applications/utilities/miscellaneous/swak4Foam/Libraries/swak4FoamParsers
/opt/pkg/simulation/OpenFOAM/fwd/3.0.x/OpenFOAM-3.0.x/platforms/linux64GccDPInt32Opt/applications/utilities/miscellaneous/swak4Foam/Libraries/swak4FoamParsers/options:51: /opt/pkg/simulation/OpenFOAM/fwd/3.0.x/OpenFOAM-3.0.x/platforms/linux64GccDPInt32Opt/applications/utilities/miscellaneous/swak4Foam/Libraries/swak4FoamParsers/../mybison: No such file or directory
/opt/pkg/simulation/OpenFOAM/fwd/3.0.x/OpenFOAM-3.0.x/platforms/linux64GccDPInt32Opt/applications/utilities/miscellaneous/swak4Foam/Libraries/swak4FoamParsers/options:52: /opt/pkg/simulation/OpenFOAM/fwd/3.0.x/OpenFOAM-3.0.x/platforms/linux64GccDPInt32Opt/applications/utilities/miscellaneous/swak4Foam/Libraries/swak4FoamParsers/../myflex: No such file or directory
/opt/pkg/simulation/OpenFOAM/fwd/3.0.x/OpenFOAM-3.0.x/platforms/linux64GccDPInt32Opt/applications/utilities/miscellaneous/swak4Foam/Libraries/swak4FoamParsers/options:55: /opt/pkg/simulation/OpenFOAM/fwd/3.0.x/OpenFOAM-3.0.x/platforms/linux64GccDPInt32Opt/applications/utilities/miscellaneous/swak4Foam/Libraries/swak4FoamParsers/../../../rules/versionOptions: No such file or directory
make: *** No rule to make target `/opt/pkg/simulation/OpenFOAM/fwd/3.0.x/OpenFOAM-3.0.x/platforms/linux64GccDPInt32Opt/applications/utilities/miscellaneous/swak4Foam/Libraries/swak4FoamParsers/../../../rules/versionOptions'.  Stop.
wmake error: file '/opt/pkg/simulation/OpenFOAM/fwd/3.0.x/OpenFOAM-3.0.x/platforms/linux64GccDPInt32Opt/applications/utilities/miscellaneous/swak4Foam/Libraries/swak4FoamParsers/sourceFiles' could not be created in /opt/pkg/simulation/OpenFOAM/fwd/3.0.x/OpenFOAM-3.0.x/applications/utilities/miscellaneous/swak4Foam/Libraries/swak4FoamParsers
Parser library did not compile OK. No sense continuing as everything else depends on it
Requirements for Library not satisfied. I see no sense in going on
Check the README before you go on to ask. And search: Most likely your problem occured to 5 other people before and has been solved on the MessageBoard
fs82 is offline   Reply With Quote
Old   November 25, 2015, 06:57
akidess's Avatar
Anton Kidess
I actually did this yesterday and it worked fine. Note that you need to grab the devel repository.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   November 25, 2015, 11:57
Dr. Fabian Schlegel
No, it is not running. I downloaded the development release but the error remains. I have a feeling that this is somehow related to the content of the $(OBJECTS_DIR) variable. However, I do not have a clue why this points to a wrong place.
Old   November 26, 2015, 03:26
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
I have noticed the same behavior and also linked it to the $(OBJECTS_DIR) variable, however I could not resolve the problem. My colleague however had no problems, nor did our cluster. There may be some small setup differences between the machines, but something like this did not happen before.
Regards,
Tom
tomf is offline   Reply With Quote
Old   November 26, 2015, 11:35
Dr. Fabian Schlegel
Allright, I think I solved this issue. It is not suitable to put the sources of swak4foam into the $WM_PROJECT_DIR/<path>. A better idea is to put the sources into $WM_PROJECT_USER_DIR/<path>, then everything compiles fine and one can use
maintainanceScripts/copySwakFilesToSite.sh
maintainanceScripts/removeSwakFilesFromLocal.sh
to copy the generated executables to a central installation if desired.
Kind regards,
Fabian
tomf, wyldckat, ebache and 3 others like this.
Old   December 16, 2015, 13:49
Default [Solved]
towanda
towanda is on a distinguished road
solved , sorry
https://openfoamwiki.net/index.php/I...oam-extend_3.x
Dear Community of Foamers,
I was trying to install a swak4Foam version which I have download from:
git clone https://github.com/Unofficial-Extend...xtend-Breeder2.0-libraries-swak4Foam.git swak4Foam
for using with OF3.0.0. I put the swak4Foam files into the folder user-3.0.0/swak4Foam
I also run from the base ./maintainanceScripts/compileRequirements.sh
I have added into my PATH variable the following:
export PATH=/users/rechimal/OpenFOAM/rechimal-3.0.0/swak4Foam/privateRequirements/bin:$PATH
Then I run ./Allwmake and I get the following error:
Previously compiled for OpenFOAM 3.0.0
/users/rechimal/OpenFOAM/rechimal-3.0.0/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
No file 'swakConfiguration'. Python etc won't work. See README for details
Try 'ln -s swakConfiguration.automatic swakConfiguration' for automatic configuration. BEWARE: this does not work on some systems
abort: no repository found in '/users/rechimal/OpenFOAM/rechimal-3.0.0/swak4Foam' (.hg not found)!
Flex is version 2.5.39 (Minor version: 39)
OpenFOAM-version: Major 3 Minor 0 Patch 0 (-1 == x / 0)
No change to swak4FoamParsers/foamVersion4swak.H
make: *** No rule to make target 'Make/linux64GccDPInt32Opt/SubsetValueExpressionParser.o', needed by 'Make/linux64GccDPInt32Opt/CellSetValueExpressionDriver.o'.  Stop.
wmake error: file 'Make/linux64GccDPInt32Opt/sourceFiles' could not be created in /users/rechimal/OpenFOAM/rechimal-3.0.0/swak4Foam/Libraries/swak4FoamParsers
After that I run the command:
I run again ./Allwmake and I get the follong error:
I have search for other post but I could not reach to any solution.
Can anybody tell me if I am missing something or doing something wrong?
How can I solve the problem?
Thanks in advance
Last edited by wyldckat; January 9, 2016 at 12:04. Reason: merged posts that were a few of hours apart
towanda is offline   Reply With Quote
Old   January 5, 2016, 16:47
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
OpenSUSE 13.2, OpenFoam 3.0.x
I am trying to install swak4Foam according to this guide: https://openfoamwiki.net/index.php/C...m/Installation
mkdir -p $FOAM_RUN
cd "$HOME/OpenFOAM/$USER-$WM_PROJECT_VERSION"
hg clone http://hg.code.sf.net/p/openfoam-extend/swak4Foam swak4Foam
cd swak4Foam
./Allwmake
The output is
Swak version is 0.4.0
Flex is version 2.5.37 (Minor version: 37)
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file plugins/FaceZoneValuePluginFunction.C
Making dependency list for source file plugins/SampledSetValuePluginFunction.C
Making dependency list for source file plugins/SampledSurfaceValuePluginFunction.C
Making dependency list for source file plugins/FaceSetValuePluginFunction.C
could not open file foamString.H for source file plugins/SampledSetValuePluginFunction.C due to No such file or directory
could not open file foamString.H for source file plugins/FaceZoneValuePluginFunction.C due to No such file or directory
could not open file foamString.H for source file plugins/SampledSurfaceValuePluginFunction.C due to No such file or directory
could not open file foamString.H for source file plugins/FaceSetValuePluginFunction.C due to No such file or directory
could not open file SubsetValueExpressionParser.tab.hh for source file plugins/FaceZoneValuePluginFunction.C due to No such file or directory
Making dependency list for source file plugins/CellZoneValuePluginFunction.C
could not open file coordSet.H for source file plugins/SampledSetValuePluginFunction.C due to No such file or directory
could not open file SubsetValueExpressionParser.tab.hh for source file plugins/SampledSetValuePluginFunction.C due to No such file or directory
could not open file SubsetValueExpressionParser.tab.hh for source file plugins/FaceSetValuePluginFunction.C due to No such file or directory
Making dependency list for source file plugins/CellSetValuePluginFunction.C
Zeppo is offline   Reply With Quote
Old   January 6, 2016, 07:07
Zeppo's Avatar
Sergei
There's no foamString.H in my OpenFOAM-3.0.x sources. The Foam::string class is declared here:
/opt/OpenFOAM/OpenFOAM-3.0.x/src/OpenFOAM/primitives/strings/string/string.H
And foamString.H can be found in my foam-extend-3.2 sources:
/opt/foam/foam-extend-3.2/src/foam/primitives/strings/string/foamString.H
So It implies that I cannot build swak4Foam for OpenFOAM-3.0.x, can I?
Old   January 6, 2016, 09:40
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
If you take a look at Libraries/swak4FoamParsers/include/swakString.H, you find
#ifdef FOAM_MOVED_TIME_AND_STRING_HEADERS
#include "foamString.H"
#else
#include "string.H"
#endif
FOAM_MOVED_TIME_AND_STRING_HEADERS symbol is defined in swak.H:
#if FOAM_VERSION4SWAK >= VERSION_NR(3,2,0) && defined(FOAM_DEV)
#define FOAM_MOVED_TIME_AND_STRING_HEADERS
#endif
To learn why FOAM_VERSION4SWAK >= VERSION_NR(3,2,0) && defined(FOAM_DEV) is try, post your foamVersion4swak.H from Libraries/swak4FoamParsers.
alexeym is offline   Reply With Quote
Old   January 6, 2016, 11:46
Zeppo's Avatar
Sergei
Hi (privet!), Alexey
Originally Posted by alexeym View Post
The content of swak4Foam/Libraries/swak4FoamParsers/foamVersion4swak.H:
// generated by the Allwmake-script of the swak4Foam-distro
#ifndef foamVersion4swak_H
#define foamVersion4swak_H
#define FOAM_VERSION4SWAK_MAJOR 3
#define FOAM_VERSION4SWAK_MINOR 0
#define FOAM_VERSION4SWAK_PATCH -1
#define FOAM_VERSION4SWAK_PATCH_NUM 98
#endif
swak4Foam/Allwmake:
(cd Libraries; wmake all )
swak4Foam/Libraries/Allwmake:
of_version_major=`echo $WM_PROJECT_VERSION | sed -e 's=\([0-9]*\).*=\1='`
of_version_minor=`echo $WM_PROJECT_VERSION | sed -e 's=[0-9]*\.\([0-9]*\).*=\1='`
of_version_patch=`echo $WM_PROJECT_VERSION | sed -e 's=[0-9]*\.[0-9]*\.\([0-9a-z]*\).*=\1=' -e 's=[0-9]*\.[0-9]*=x=' -e 's=x=-1='`
if [[ $of_version_minor == "dev" && $of_version_patch == "dev" ]]; then
    echo "This seems to be an OpenFOAM-development version"
    of_version_major=9
    of_version_minor=9
    of_version_patch=99
    of_development=1
fi
versionFile=swak4FoamParsers/foamVersion4swak.H
cat >$versionFile.tmp <<EOF
#define FOAM_VERSION4SWAK_MAJOR $of_version_major
#define FOAM_VERSION4SWAK_MINOR $of_version_minor
#define FOAM_VERSION4SWAK_PATCH $of_version_patch
#define FOAM_VERSION4SWAK_PATCH_NUM $of_version_patch_num
EOF
if [[ $of_development != "" ]]; then
    echo >>$versionFile.tmp "#define FOAM_VERSION4SWAK_OF_DEV"
fi
cat >>$versionFile.tmp <<EOF
#endif
EOF
It seems like I have a regular (non-development) OpenFOAM-3.0 and the statement FOAM_VERSION4SWAK >= VERSION_NR(3,2,0) && defined(FOAM_DEV) shouldn't be true. Then FOAM_MOVED_TIME_AND_STRING_HEADERS should never be defined and "swak.H" should include #include "string.H".
Old   January 7, 2016, 21:44
Thao Nguyen
khunyeu is on a distinguished road
I also got similar problem when installing swak4Foam, could anyone give me a hint please
this is my make.log file:
/home/thao/OpenFOAM/thao-3.0.0/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
make: *** No rule to make target `Make/linux64GccDPInt64Opt/SubsetValueExpressionParser.o', needed by `Make/linux64GccDPInt64Opt/CellSetValueExpressionDriver.o'. Stop.
wmake error: file 'Make/linux64GccDPInt64Opt/sourceFiles' could not be created in /home/thao/OpenFOAM/thao-3.0.0/swak4Foam/Libraries/swak4FoamParsers
Thanks,
Thao.
khunyeu is offline   Reply With Quote
Old   January 8, 2016, 08:45
Alexey Matveichev
@Zeppo,
In fact I missed that you are unhappy about foamString.H during wmkdep invocation. The utility does not expand pre-processor definitions, it just scan file for #include directives and symlinks files. So the error could be ignored.
About your log file, I can not reproduce the error on Fedora 21/OpenFOAM 3.0.x (commit 9cf0156). The software builds OK till Bison invocation (and it is expected since I do not want to install older Bison).
Last edited by alexeym; January 8, 2016 at 14:38. Reason: too many facts in one place
Old   January 8, 2016, 12:55
Zeppo's Avatar
Sergei
In fact I missed the fact that you are unhappy about foamString.H during wmkdep invocation. The utility does not expand pre-processor definitions, it just scan file for #include directives and symlinks files. So the error could be ignored.
That is why I see no errors of this type when I run ./Allwmake for the second time.
c++ compiler can't convert "int &" to "long int &" implicitly on the ground of possible numeric overflow:
Previously compiled for OpenFOAM 3.0.x
/home/sergei/OpenFOAM/sergei-3.0.x/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
../SubsetValueExpressionParser.yy: In instantiation of ‘Foam::autoPtr<Foam::Field<Type> > Foam::SubsetValueExpressionDriver::evaluatePluginFunction(const Foam::word&, const parserSubset::location&, int&, bool) [with T = Foam::Vector<double>]’:
../SubsetValueExpressionParser.yy:740:7:   required from here
../SubsetValueExpressionParser.yy:132:9: error: no matching function for call to ‘Foam::CommonPluginFunction::evaluate(std::basic_string<char>, int&, bool&)
../SubsetValueExpressionParser.yy:132:9: note: candidates are:
In file included from ../SubsetValueExpressionParser.yy:99:0:
lnInclude/CommonPluginFunction.H:224:12: note: template<class T> Foam::tmp<T> Foam::CommonPluginFunction::evaluate(const Foam::string&, Foam::label&)
     tmp<T> evaluate(
lnInclude/CommonPluginFunction.H:224:12: note:   template argument deduction/substitution failed:
../SubsetValueExpressionParser.yy:132:9: note:   cannot convert ‘scanned’ (type ‘int’) to type ‘Foam::label& {aka long int&}’
lnInclude/CommonPluginFunction.H:230:20: note: template<class T> Foam::tmp<Foam::Field<Type> > Foam::CommonPluginFunction::evaluate(const Foam::string&, Foam::label&, bool)
     tmp<Field<T> > evaluate(
lnInclude/CommonPluginFunction.H:230:20: note:   template argument deduction/substitution failed:
../SubsetValueExpressionParser.yy: In instantiation of ‘Foam::autoPtr<Foam::Field<Type> > Foam::SubsetValueExpressionDriver::evaluatePluginFunction(const Foam::word&, const parserSubset::location&, int&, bool) [with T = double]’:
../SubsetValueExpressionParser.yy:1301:7:   required from here
../SubsetValueExpressionParser.yy:132:9: error: no matching function for call to ‘Foam::CommonPluginFunction::evaluate(std::basic_string<char>, int&, bool&)’
     tmp<T> evaluate(
I got it! When I built my OpenFoam from sources I specified the option WM_LABEL_SIZE=64 (just out of curiosity) which affected the definition of the "label" type:
// "label.h"
// A label is an int32_t or int64_t as specified by the pre-processor macro WM_LABEL_SIZE.
#define INT_ADD_SIZE(x,s,y) x ## s ## y
#define INT_ADD_DEF_SIZE(x,s,y) INT_ADD_SIZE(x,s,y)
#define INT_SIZE(x,y) INT_ADD_DEF_SIZE(x,WM_LABEL_SIZE,y)
namespace Foam    {
    typedef INT_SIZE(int, _t) label;
It is now:
typedef int64_t label;
And somewhere in <cstdint>:
typedef long int  int64_t;
Unfortunatly swak4Foam doesn't always obey the rules - sometimes it uses "int", sometimes "Foam::label", which makes a little mess in the code and I can't got it compiled. I can recompile OpenFOAM with WM_LABEL_SIZE=32 to overcome the issue and I'll be fine, though. Anyway, if what I said is true should I report it as a bug to anywhere?
Old   January 8, 2016, 14:36
Alexey Matveichev
There is https://sourceforge.net/p/openfoam-e...ketsswak4foam/.
Old   January 16, 2016, 07:52
hcl734 is on a distinguished road
So is there any solution to this issue ready to use?
hcl734 is offline   Reply With Quote
Old   January 16, 2016, 16:06
Zeppo's Avatar
Sergei
I have recompiled OpenFOAM with WM_LABEL_SIZE=32 and then swak4Foam has been built with no issues. Are you sure you really need more than (2^32)/2=2147483648 cells, patches, regions etc in your simulations? Just wondering.
Btw, shouldn't "label" be typedefed as "unsigned int" or "unsigned long int"? As far as I can see, objects of this type is only used to index data containers.
I opened a ticket with a bug report: https://sourceforge.net/p/openfoam-e...swak4foam/233/
Old   April 7, 2016, 14:50
Alejandro
ancolli is on a distinguished road
Kind regards,
Fabian
Hi Fabian, I have the same problem as you, but I don't quite understand how did u solve it. Could u please explain to me step by step?
ancolli is offline   Reply With Quote
Old   April 8, 2016, 02:17
Dr. Fabian Schlegel
  1. Create a directory in $WM_PROJECT_USER_DIR
    mkdir -p $WM_PROJECT_USER_DIR/applications/utilities/miscellaneous
    cd $WM_PROJECT_USER_DIR/applications/utilities/miscellaneous
  2. Download the sources of swak4foam
    git clone https://github.com/Unofficial-Extend...-swak4Foam-dev swak4Foam
    cd swak4Foam
    git checkout port_2.0.x
  3. Copy/Edit the preferences file to use Python (depends on operating system)
    cp swakConfiguration.automatic swakConfiguration
  4. Build custom Bison 2.x
  5. Build swak4foam
    ./Allwmake
Old   April 8, 2016, 03:50
Alejandro
    cd swak4Foam
  5. Build swak4foam
    ./Allwmake
the same problem
I could not use step 2. instead i used:
cd swak4Foam
OpenFOAM-version: Major  Minor v0 Patch v-1+ (-1 == x / v-1+)
No swak4FoamParsers/foamVersion4swak.H. Generated....
Old   April 8, 2016, 04:07
Alejandro
    cd swak4Foam
  5. Build swak4foam
    ./Allwmake
if i do the installation as you say i obtain an error in:
error: pathspec 'port_2.0.x' did not match any file(s) known to git.
and then i obtain the following:
/home/ancolli/OpenFOAM/ancolli-v3.0+/applications/utilities/miscellaneous/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
abort: no repository found in '/home/ancolli/OpenFOAM/ancolli-v3.0+/applications/utilities/miscellaneous/swak4Foam' (.hg not found)!
No swak4FoamParsers/foamVersion4swak.H. Generated.....
[swak4Foam] Problem with swak4Foam and OpenFOAM 2.3.1 behzad-cfd OpenFOAM Community Contributions 4 March 25, 2017 16:19
[swak4Foam] Installing swak4Foam with openFoam v3.0+ RebelLion OpenFOAM Community Contributions 0 March 11, 2016 19:10
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
[swak4Foam] fails in parallel with -otherTime? Phicau OpenFOAM Community Contributions 3 June 26, 2013 13:00
[swak4Foam] Installing swak4Foam to OpenFOAM in mac Kaquesang OpenFOAM Community Contributions 22 January 21, 2013 11:51
