[swak4Foam] calculating velocity transformations
Like Tree2Likes
  • 1 Post By santoshgoku
  • 1 Post By gschaider
Old   June 19, 2012, 12:15
Default calculating velocity transformations
Santosh
santoshgoku is on a distinguished road
I am trying to calculate a new transformed velocity field
as a post processing step according to the following expression: dU/dt = c*dUz/dx, where c is a constant. I am trying it using swak4Foam, in which I had a couple of questions,
- how to add the dUz/dx term? I can add the div(U) term, but how to ensure that I get dUz/dx alone?
- for the dU/dt term, is it possible to use an explicit formulation like, U=U-delta(T)*c*<term for dUz/dx>?
I went through the slides on swak4Foam (No C++, please. We’re users!, Bernhard F.W. Gschaider, June 2011), and found multiple ways to obtain such expressions.
- using libswakFunctionObject and expressionField kind formulations (slide number 61/176)
Ustar
functionObjectLibs ("libswakFunctionObjects.so");
type expressionField;
outputControl timeStep;
fieldName Ustar;
expression "U = U - c*div(U)*deltaT()";
autowrite true;
- using storedValues and patchExpression (slide 131/176)
Which of the above will be apt for this formulation?
Lastly, I was trying to compile swak4Foam for OpenFoam v. 2.0.1, and I get the following errors (related to swakcodedFunctionObject) while compiling:
swakCodedFunctionObject.C:299: error: no matching function for call to ‘Foam::swakCodedFunctionObject::updateLibrary(Foam ::word&)’
/home/OpenFOAM/OpenFOAM-2.0.1/src//postProcessing/functionObjects/utilities/lnInclude/codedFunctionObject.H:111: note: candidates are: void Foam::codedFunctionObject::updateLibrary() const
make: *** [Make/linux64GccDPOpt/swakCodedFunctionObject.o] Error 1
I removed the last parameter to the =codedFunctionObject=-constructor in =swakCodedFunctionObject.C= as mentioned in the README, but still continue to get this error. Due to this, I am unable to use the expressionField kind of formulation as well. Rest of the functions are compiled fine, the problem is only with the codedFunctionObject.
Looking forward to some directions.
Thanks,
Santosh
manuc likes this.
santoshgoku is offline   Reply With Quote
Old   June 19, 2012, 14:58
Assistant Moderator
Bernhard Gschaider
Originally Posted by santoshgoku View Post
What speaks against "grad(U.z).x" ?
No. But some months ago field expressions can also do "ddt(U)" (provided the solver stores the old value of U). You can also access the old time value of U (again: if stored) with "oldTime(U)"
Ustar
fieldName Ustar;
autowrite true;
That would involve equation solving and swak doesn't do that. So: no "=" in expression
If the solver doesn't store the old U a sequence like this (yeah. This is weird) in the variables
"oldU=storedU;"
"oldU=U;"
and stordeU being declared as a stored variable will give you the U of the previous timestep as oldU to use in your expressions
There was a change in that interface some time after 2.0.1 but before 2.1 and I never bothered to support both versions as users with a fairly up-to-date 2.0.x would have the new interface. Sorry
manuc likes this.
Old   June 19, 2012, 16:26
Santosh
thanks for the reply Bernhard, really appreciated.
So, if I understand correct,
1. If U is stored in the previous time step, then I can use the expressionField, with the following expression,
expression "oldTime(U) - c*grad(U.z).x*deltaT()";
2. In case U is not stored in the previous timestep, I can use stored variables function as follows,
variables (
"oldU=storedU;"
"oldU=U;"
"storedU =oldU - deltaT()*c*grad(U.z).x;"
storedVariables (
name storedU;
initialValue "0";
expression "storedU"
But then, in the example in the slides, the above expression is used only as a patchExpression, with some "accumulation" term. Can it be used as a modified form of expressionField or swakExpression?
I will try upgrading my version of OpenFoam, and hope it works.
Thanks again.
Santosh
Old   June 20, 2012, 05:18
Assistant Moderator
Bernhard Gschaider
variables (
"oldU=storedU;"
"oldU=U;"
storedVariables (
name storedU;
initialValue "0";
accumulations is only needed if you need "a single number" to print to the screen. For instance if you use a swakExpression-FO to print the maximum and minimum of your field to the screen.
Concerning your variables: I think you'll want to exchange the last two assignments (overwrite oldU AFTER it was used. But I still don't quite understand what exactly you're trying to calculate here
Old   June 20, 2012, 05:39
Santosh
I am trying to calculate a transformation which will lead to a new steady velocity field. The constant "c" in my expression is the velocity of structures I observe in the flow. After this transformation, I will be able to obtain a velocity field which does not change with time.
Old   April 19, 2016, 12:57
Sami
Mehrez is on a distinguished road
I think there is a bug when using swak4Foam "storedVariables" in parallel.
The stored variables are not defined in all the sub-meshes and cause a crash.
Mhrz
Mehrez is offline   Reply With Quote
Expression for calculating friction velocity Divyaprakash Main CFD Forum 0 October 1, 2015 02:03
Calculating average velocity for multiphase flows using CFD-Post amin.z FLUENT 1 July 15, 2015 07:34
Derivative of velocity and mean velocity hiuluom OpenFOAM Post-Processing 1 May 29, 2015 23:42
[General] Calculating average velocity in paraview haghgoo_reza ParaView 0 October 22, 2013 20:03
Calculating the Friction Velocity cbarry OpenFOAM 7 November 17, 2009 11:24
