[swak4Foam] Variable pressure with crank angle groovyBC |
February 21, 2017, 04:45 |
Giuseppe
Rep Power: 9 |
Hi guys,
I am new in OpenFoam and I need to change an instruction in a already written boundary condition with groovyBC. I am using the solver coldEngineFoam in order to simulate a gas spring (a piston compressor without valves). I want that a value of pressure is variable with time (sinusoidal) in this sub model, now is constant. In order to do this I need to take the crank angle at the current time step. Anyone knows how to do? I attached a screenshot of the instruction tried by me but it doesn't work. Thank you in advance. |
Crank angle for peak pressure value is not matching.. | Pawan30 | FLUENT | 1 | November 23, 2016 01:56 |
Pressure problems with inlet variable velocity | jaimesdiegop | CFX | 2 | September 1, 2016 02:31 |
Pressure Vs Crank Angle | amita | FLUENT | 1 | May 28, 2009 07:20 |
Variable Operating Pressure (field) | Arturo | FLUENT | 0 | April 30, 2008 15:22 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
