[waves2Foam] error in overtopping.C
Old   May 19, 2016, 04:15
Default error in overtopping.C
Xiantao Zhang
zhxter is on a distinguished road
Hi Niels,
In order to learn how to calculate overtopping rate, I read the relevant file overtopping.C. And in the member function " void Foam:vertopping::computeAndWrite ()", the momentum flux is calculated as follows,
f[facei]=rho1_*q[facei]*Foam::mag( q[facei]/magSf[facei] );
And I wonder if the term magSf[facei] should be replaced by magSf[faceI]??
Regards
Xiantao
Center for offshore Foundation Systems, the University of Western Australia
zhxter is offline   Reply With Quote
Old   May 19, 2016, 04:30
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hallo Xiantao,
Thank you for the bug report. The bug has been fixed and submitted to the svn.
Have a nice day,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   May 19, 2016, 08:45
Default overtopping used as a functionObject
Xiantao Zhang
Hi Niels,
After reading the source file overtopping.C. My idea of how to use overtopping as a functionObject is as follows,
Adding the following sentences in the controlDict
overtoppingAnyName
type overtopping;
functionObjectLibs ("libwaves2Foam.so");
outputControl timeStep;
outputInterval 1;
And one thing to mention is that the name of the faceZone (used for extracting the overtopping rate) should be "overtopping".
Is it right for calculating overtopping rate??
Regards
Xiantao
Old   May 19, 2016, 10:52
ngj
Hi Xiantao,
Yes it looks correct, though you might need another library (the sampling one in waves2Foam).
Note that you can have multiple overtopping zones, and long as the faceZone starts with 'overtopping', e.g. overtopping01, overtopping02, etc.
Kind regards
Niels
