[swak4Foam] multiple patch Nusselt number calculation
Old   July 23, 2016, 05:56
Default multiple patch Nusselt number calculation
Manu Chakkingal
manuc is on a distinguished road
Dear Foamers
I have two patches (w_l,w_lb --> both of them of different area and mesh distribution) and I want to find combined nusselt No. for them.
When I do the below it crashes:
Test234
type patchExpression;
patches (
w_l
w_lb
verbose true;
variables (
"Tsat=300;"
"lc2D=0.0786;"
"sumHere{w_l}=sum(snGrad(T)*area()/(T-Tsat);"
/*"dtwl{w_l}=T-Tsat;"
"dtwlb{w_lb}=T-Tsat;"*/
"sumThere{w_lb}=sum(snGrad(T)*area()/(T-Tsat));"
"areaHere{w_l}=sum(area());"
"areaThere{w_lb}=sum(area());"
"totalAverage=(sumHere+sumThere)/(areaHere+areaThere);"*/
expression "totalAverage";
accumulations (
max
min
average
sum
But when I try to debug and remove the division by (T-Tsat) it runs ,but not what I need..
Test234
patches (
w_l
w_lb
verbose true;
variables (
"Tsat=300;"
"lc2D=0.0786;"
"sumHere{w_l}=sum(snGrad(T)*area());"
"sumThere{w_lb}=sum(snGrad(T)*area());"
accumulations (
max
min
average
sum
Also it creates 2 output files w_l and w_lb .Is this expected
Please note : The same was tested for a "single patch" by doing the nusslet number calculation in "expression() " as in
http://www.cfd-online.com/Forums/ope...swak4foam.html
which works finr
Could you please comment on it..
My scenario: A wall cut into two patches so that I could use one of the as inlet for flow if needed.At present both considered as wall. So I want Nusselt number at the whole wall and I need averaging over both patches.
Regards
Manu
manuc is offline   Reply With Quote
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 18:32
decomposePar -allRegions stru OpenFOAM Pre-Processing 2 August 25, 2015 03:58
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 02:01
AMI interDyMFoam for mixer danny123 OpenFOAM Running, Solving & CFD 4 June 19, 2013 04:49
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
