[waves2Foam] compiler errors with OpenFOAM 3.0.1
Old   June 18, 2018, 05:49
Default compiler errors with OpenFOAM 3.0.1
Simon J S
oceanFoam is on a distinguished road
Hi Niels,
waves2Foam seems to be a great tool for ocean hydrodynamics, which is why I decided to work with it for my masters thesis at Heriot-Watt University, Edinburgh. Previous simulations I have run in OpenFoam 5.0, but since waves2Foam does not seem to run on it, I now installed OpenFoam 3.01. When I try to compile the library however, a few errors seem to appear that prevent the installation to run successfully.
These start to appear in the section COMPILE SPARSKIT2
'thirdpartylibs/LIB_VTK_IO/static/lib_vtk_io.mod' -> '/home/simon/OpenFOAM/simon-3.0.1/applications/utilities/waves2Foam/ThirdParty/OceanWave3D-Fortran90/../build/lib_vtk_io.mod'
gfortran -O3 -fPIC -ffpe-trap=invalid,zero,overflow -ffree-line-length-none -fstack-protector-all -c src/multigrid/GaussSeidelSpecialPoints.f90 -o /home/simon/OpenFOAM/simon-3.0.1/applications/utilities/waves2Foam/ThirdParty/OceanWave3D-Fortran90/../build/GaussSeidelSpecialPoints.o -I/home/simon/OpenFOAM/simon-3.0.1/applications/utilities/waves2Foam/ThirdParty/OceanWave3D-Fortran90/../build
ls: cannot access '*.mod': No such file or directory
mv: cannot stat '*.mod': No such file or directory
and continue in a similar style in other parts like COMPILE OCEANWAVE.
In POST PROCESSING I eventually get the following error
make[1]: Entering directory '/home/simon/OpenFOAM/simon-3.0.1/applications/utilities/waves2Foam/applications/utilities/postProcessing/postProcessWaves2Foam'
Making dependency list for source file postProcessWaves2Foam.C
could not open file foamTime.H for source file postProcessWaves2Foam.C due to No such file or directory
I am running on an Ubuntu 16.04 machine and would say that I am overall rather a beginner in OpenFoam with only a few month of experience with several tutorial cases etc. Any help in this matter is greatly appreciatet. Thanks a lot.
Cheers,
Simon
Edit: After running the compiler for a second time I think the main problem arising from the errors, is that the solvers are not installed/compiled. I attached the second log file as well. This is the content of the folder $HOME/OpenFOAM/simon-3.0.1/applications/utilities/waves2Foam/applications/solvers
.                 solvers170        solvers220  solvers240       solvers310_EXT
..                solvers1712_PLUS  solvers221  solvers300       solvers320_EXT
solvers160        solvers210        solvers222  solvers300_EXT   solvers400
solvers1606_PLUS  solvers211        solvers230  solvers300_PLUS  solvers400_EXT
oceanFoam is offline   Reply With Quote
Old   June 19, 2018, 03:07
Maoyanjun
Maoyanjun is on a distinguished road
Originally Posted by oceanFoam View Post
Hi Niels,
Cheers,
Simon
you can copy the sovler300 and rename it as sovler301, and be sure to source the waves2foam env
You can see the details from my Blog in Chinese: wish you could understand Chinese
http://maoyanjun.top/2018/01/10/wave...D%BF%E7%94%A8/
Maoyanjun is offline   Reply With Quote
Old   June 19, 2018, 07:19
Simon J S
Hi Maoyanjun,
thanks a lot for your reply. unfortunately I don't read Chinese. However am I right that in your blog you are doing the same thing with the solver1706 file?
I tried to compile again with the new folder and am still getting an error when trying to run the waveFlume tutorial case saying that /bin/preProssecing is not executable. Since I cant find that file neither in /bin nor in the /OpenFoam/OpenFoam-3-0-1/bin directory I am afraid that the issues with my installation go a bit further.
But thank you so far already!
Cheers,
Simon
Old   December 12, 2018, 05:30
Kazakis Ioannis
Giannis_Kaz is on a distinguished road
Dear Simon
Did you have a solution for your problem? I have the same issue with OF4.1.
Greetings
John
Giannis_Kaz is offline   Reply With Quote
Old   December 12, 2018, 05:33
Kazakis Ioannis
Hi Niels,
Cheers,
Simon
Dear Simon
Greetings
John
Old   January 31, 2020, 06:33
Conor Owen
Cjyowen1 is on a distinguished road
Hi Niels,
Cheers,
Simon
What solution was found for this problem, very new to waves2Foam and running into the exact same problem.
Cjyowen1 is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 02:34
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
