[cfMesh] CFMesh doing long non-parallel calculation
Old   February 14, 2018, 11:10
Default CFMesh doing long non-parallel calculation
benoit paillard
bennn is on a distinguished road
Hi all,
I've noticed that, for some complicated geometries, CFMesh does long calculation (~10 to 20h) on a single core, mostly at the beginning of the process : mainly during template generation or before starting the boundary layer generation, when restarting from meshOptimisation.
I've tried looking at the source code to see what happened there, but no luck so far...
Has anyone else experienced that ?
This is only for very complicated, and potentially bad quality geometry though. It works perfectly fine 99% of the time.
Thanks !
bennn is offline   Reply With Quote
Old   January 28, 2020, 08:16
Joćo Duarte Miranda
JoaoDMiranda is on a distinguished road
Dear bennn,
I know is a old post, but did you manage to solve the problem. I have the same for a rather complex case. What is strange is that for another even more complex case it worked well.
Do you have some information/tips you can share?
Thanks a lot!
JoaoDMiranda is offline   Reply With Quote
Openfoam parallel calculation performance study - Half performance on mpirun Jurado OpenFOAM Running, Solving & CFD 22 March 24, 2018 20:40
MPI error in parallel application usv001 OpenFOAM Programming & Development 2 September 14, 2017 11:30
Iterations Calculation stopped for long time - Simulation CFD 2015 archNUOVO Autodesk Simulation CFD 0 February 21, 2017 09:57
Dynamic mesh adaption in parallel calculation xh110120 FLUENT 1 March 12, 2016 08:05
parallel calculation on multiple computers foam_noob OpenFOAM 4 February 3, 2010 03:14
