[waves2Foam] BC changes from relaxationAlpha to waveAlpha after using setWaveField in OFv2306
Like Tree1Likes
  • 1 Post By Jesper_Roland
Old   August 17, 2023, 05:52
Post BC changes from relaxationAlpha to waveAlpha after using setWaveField in OFv2306
Jesper R. K. Qwist
Jesper_Roland is on a distinguished road
I have compiled the newest version of waves2Foam with OpenFoam-v2306.
My problem
I specify boundary condition type to be relaxationAlpha in 0/alpha.water as follows:
boundaryField
    inlet
        type            relaxationAlpha;
        refValue        uniform 0;
        refGrad         uniform 0;
        valueFraction   uniform 1;
        value           uniform 0;
    bottom
        type            zeroGradient;
    outlet
        refValue        uniform 0;
        refGrad         uniform 0;
        value           uniform 0;
    atmosphere
        type            zeroGradient;
    frontBack
        type            empty;
When I call setWaveField 0/alpha.water is modified. The internal field is perfectly fine but something odd happens in the boundary field.
The boundary type changes from relaxationAlpha to waveAlpha.
The following piece of code, is the boundary field section from the alpha.water field that was written during a call to the setWaveField application.
boundaryField
    inlet
        type            waveAlpha;
        waveDictName    waveProperties;
        value           uniform 0;
    bottom
        type            zeroGradient;
    outlet
        type            waveAlpha;
        value           uniform 0;
    atmosphere
        type            zeroGradient;
    frontBack
        type            empty;
This results in an error when I try to execute that case as the code does not know about any boundary condition called waveAlpha since the new name is relaxationAlpha.
My temporary solution:
If I manually change waveAlpha to relaxationAlpha then my case executes perfectly fine.
Notes:
I have observed the same change in 0/U where the boundary type is changed from relaxationVelocity to waveVelocity.
I have been looking at the source files related to the setWaveField application and class as well as the waveAlphaFvPatchScalarField and waveVelocityFvPatchScalarField classes. But I have not been able to identify exactly where the code writes waveAlpha or waveVelocity to the dictionary files.
Are there anyone who have experienced the same problem?
And how to solve this / suggestions to where to look for the problem?
Best Regards,
Jesper Qwist
gcampana likes this.
Jesper_Roland is offline   Reply With Quote
Old   December 13, 2023, 09:05
Guillén Campaña Alonso
gcampana is on a distinguished road
Hi! I have also experienced this issue, moreover I cannot fix it like you do. An error arises saying:
Dictionary entry for patch inlet not found
file: constant/waveProperties at line 17 to 75.
    From static Foam::autoPtr<Foam::waveModel> Foam::waveModel::New(const Foam::word&, const Foam::fvMesh&, const Foam::polyPatch&)
    in file waveModel/waveModelNew.C at line 61.
These are the boundary conditions after setWaveFields
alpha.water (I omit the internalField list)
boundaryField
    inlet
        value           uniform 0;
    outlet
        type            zeroGradient;
    ground
        type            zeroGradient;
    top
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    side1
        type            empty;
    side2
        type            empty;
U
internalField   uniform (0 0 -0);
boundaryField
    inlet
        type            relaxationVelocity;
        value           uniform (0 0 0);
    outlet
        type            fixedValue;
    ground
        type            slip;
    top
        type            pressureInletOutletVelocity;
    side1
        type            empty;
    side2
        type            empty;
And finally, this is my waveProperties.input file
seaLevel        0;
relaxationNames
    inlet
    outlet
initializationName inlet;
inletCoeffs
    waveType        stokesSecond;
    depth           103.68;
    period          11.3;
    direction       ( 1 0 0 );
    phi             0;
    height          5.49;
    Tsoft           11.3;
    debug           false;
    relaxationZone
        relaxationScheme    Spatial;
        relaxationWeight    Exponential;
        exponent            3.5;
        courantCorrection   false;
        beachType           Empty;
        relaxationShape     Rectangular;
        relaxType           INLET;
        startX              ( -400 -204 0 );
        endX                ( -200  204 0 );
        orientation         ( 1 0 0 );
outletCoeffs
    waveType        potentialCurrent;
    depth           103.68;
    U               ( 0 0 0 );
    Tsoft           11.3;
    relaxationZone
        exponent            3.5;
        relaxType           OUTLET;
        startX              ( 200 -203.4 0 );
        endX                ( 700  203.4 0 );
initCoeffs
    U               ( 0 0 0 );
    Tsoft           11.3;
I can use the zeroGradient BC and it works. Do you know where my error is?
Best regards
gcampana is offline   Reply With Quote
boundary, relaxationalpha, setwavefield, wavealpha, waves2foam
[waves2Foam] setWaveField and/or waveFoam not working in parallel saeed.barzegar.v OpenFOAM Community Contributions 2 January 25, 2023 14:57
setWaveField never finish Rasmusiwersen OpenFOAM Pre-Processing 3 June 30, 2022 11:51
