[cfMesh] Problem CfMesh 2D Mesh
Like Tree1Likes
  • 1 Post By Clmkite
Old   September 23, 2015, 16:35
Default Problem CfMesh 2D Mesh
Clement Mtrl
Clmkite is on a distinguished road
I'm trying to mesh a car with cfMesh in 2D but I experience some problems.
Here is the geometry :
https://drive.google.com/file/d/0B0-...ew?usp=sharing
Here is my meshDict :
| \\      /  F ield         | OpenFOAM GUI Project: creativeFields           |
|  \\    /   O peration     | Version:  0.8.9.0                                  |
|   \\  /    A nd           | Web: www.c-fields.com                                       |
|    \\/     M anipulation  |                                                |
FoamFile
version    2;
format    ascii;
class    dictionary;
location    "system";
object    meshDict;
surfaceFile    "caronly3.ftr";
maxCellSize    100;
minCellSize     80;
//boundaryCellSize 200;
localRefinement
car
cellSize 50;
objectRefinements
box
type box;
cellsize 100;
centre (15000 3000 5);
lengthX 20000;
lengthY 5500;
lengthZ 10;
boundaryLayers
 patchboundaryLayers
  car
    nLayers         10;
    thicknessRatio  1.2;
    maxFirstlayrThickness 0.01;
In fact I have 2 problems,
When the ratio between maxCellSize and minCellSize is too large I have the following error :
--> FOAM FATAL ERROR:
This cannot be a 2D mesh
    From function void polyMeshGen2DEngine::findZMinOffsetPoints()
    in file utilities/meshes/polyMeshGen2DEngine/polyMeshGen2DEngine.C at line 174.
FOAM exiting
When the ration between maxCellSize and boundaryCellSize is too big I have this one :
Octree nodes 37794
Resizing points!
Segmentation fault (core dumped)
And it seems quite important to have a big ratio to reduce the number of cells far from the car.
My second problem is that my localRefinement / objectRefinements / boundaryLayers are completely ignored by the program (cartesian2DMesh).
At this point I didn,t find my answers anywhere...
Thanks a lot
Clmkite is offline   Reply With Quote
Old   September 27, 2015, 10:29
Franjo Juretic
franjo_j is on a distinguished road
Send a message via Skype™ to franjo_j
The case did not produce the expected results because of some incorrect settings (mainly typos), and the crash was due to some bugs in the 1.1 version. Please upgrade to the 1.1.1 version available at SourceForge. We have resolved some problems reported by the people using the 2D mesher.
Please check the attached case and please let me know if it generates the required result.
There are a few suggestions that I would like to point out:
1. When you generate the features via surfaceFeatureEdges and export the results into an stl or an ftr file, it changes the names of the patches in the surface mesh. You need to use the new names for meshing or simply use the regular expressions. A non-existent patch name in meshDict results in the region being ignored.
2. Please pay attention to use the correct keywords. The settings are case-sensitive so you cannot use cellsize, it has to be cellSize. The same problem is with patchboundaryLayers, it shall be patchBoundaryLayers. This has caused the problem that box refinement region was ignored, and there was only one boundary layer.
I hope that this helps you.
Regards,
Franjo
Principal Developer of cfMesh and CF-MESH+
www.cfmesh.com
Social media: LinkedIn, Twitter, YouTube, Facebook, Pinterest, Instagram
franjo_j is offline   Reply With Quote
Old   September 28, 2015, 11:17
Clement Mtrl
Hi Franjo,
Thanks for your answer.
I did upgrade myversion and since I didn't encounter my first error.
And you were right about my typo because now it works much better
It's not so long that I work in linux environnement and not used to take care so much of the typo !!!
Howevers I get a mesh loonking like I want (cf pictures).
My checkMesh is not really good and I don't really know how to play with parameters in order to get good quality mesh (I tried optimiseLayer but I didn't find may informations about it).
My MeshDict
FoamFile
version	2;
format	ascii;
class	dictionary;
location	"system";
object	meshDict;
surfaceFile	"caronly1.stl";
maxCellSize	600;
minCellSize     6;
boundaryCellSize 350;
boundaryCellSizeRefinementThickness 400;
localRefinement
car {cellSize 30;refinementThickness 200;}
objectRefinements
becquet {type sphere;cellSize 0.5;centre (10013 1732 5);radius 6;}
box1 {type box;cellSize 80;centre (11000 1300 5);lengthX 12500;lengthY 2600;lengthZ 20;}
box2 {type box;cellSize 200;centre (15000 2200 5);lengthX 25000;lengthY 4400;lengthZ 20;}
box3 {type box;cellSize 400;centre (25000 2500 5);lengthX 45000;lengthY 5000;lengthZ 20;}
boundaryLayers
 patchBoundaryLayers
  car {nLayers 30;thicknessRatio 1.2;maxFirstLayerThickness 0.01;}
optimiseLayer 1; // activates layer optimisation
// optional parameters
optimisationParameters
// number of iterations in the procedure for reducing normal-variation
nSmoothNormals 30;
// max number of total iterations
maxNumIterations 50;
// feature size factor. Reasonable range <0.2, 0.5>
// lower values force thinner layers
featureSizeFactor 0.3;
// shall the normal vectors be recalculated
reCalculateNormals 1;
// relative thickess variation between two hair nSmoothNormals
// lower value produce thinner and more uniform layers
relThicknessTol 0.01;
chekcMesh results
|  \\    /   O peration     | Version:  2.4.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.4.0-f0842aea0e77
Exec   : checkMesh
Date   : Sep 28 2015
Time   : 11:04:32
Host   : "clement-desktop"
PID    : 2742
Case   : /home/clement/OpenFOAM/clement-2.4.0/run/etude/caronly
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    internal points:  0
    faces:            479164
    internal faces:   237537
    cells:            118920
    faces per cell:   6.02675
    boundary patches: 7
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     116196
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     2724
    Breakdown of polyhedra by number of faces:
        faces   number of cells
            7   2269
            8   453
            9   2
Checking topology...
    Boundary definition OK.
 ***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
                   Patch    Faces   Points                  Surface topology
                     car     2983     5966  ok (non-closed singly connected)
                   inlet       40       82  ok (non-closed singly connected)
                  ground      556     1114  ok (non-closed singly connected)
                     top      168      338  ok (non-closed singly connected)
                  outlet       40       82  ok (non-closed singly connected)
        bottomEmptyFaces   118920   122404  ok (non-closed singly connected)
           topEmptyFaces   118920   122404  ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (0 0 0) (50000 12000 10)
    Mesh (non-empty, non-wedge) directions (0 0 0)
    Mesh (non-empty) directions (0 0 0)
 ***Number of edges not aligned with or perpendicular to non-empty directions: 291712
  <<Writing 212922 points on non-aligned edges to set nonAlignedEdges
    Boundary openness (3.33116e-20 4.09695e-20 4.28121e-14) OK.
 ***Open cells found, max cell openness: 1, number of open cells 1761
  <<Writing 1761 non closed cells to set nonClosedCells
 ***Zero or negative face area detected.  Minimum area: 0
  <<Writing 14895 zero area faces to set zeroAreaFaces
 ***Zero or negative cell volume detected.  Minimum negative volume: -0.0445, Number of negative volume cells: 4766
  <<Writing 4766 zero volume cells to set zeroVolumeCells
    Mesh non-orthogonality Max: 179.145 average: 34.9415
   *Number of severely non-orthogonal (> 70 degrees) faces: 26886.
 ***Number of non-orthogonality errors: 10474.
  <<Writing 37360 non-orthogonal faces to set nonOrthoFaces
 ***Error in face pyramids: 5229 faces are incorrectly oriented.
  <<Writing 4902 faces with incorrect orientation to set wrongOrientedFaces
 ***Max skewness = 8.75e+150, 6824 highly skew faces detected which may impair the quality of the results
  <<Writing 6824 skew faces to set skewFaces
    Coupled point location match (average 0) OK.
Failed 7 mesh checks.
End
Thanks again because I try cfMesh and sHM and I was about giving up on cfMesh whereas now I found it powerful and very efficient (if I can fix quality).
Old   September 28, 2015, 14:30
Clement Mtrl
I found the utility improveMeshQuality
in the userguide but is it possible to constrain it with qulity criteria instead of numbers of iterations ?
Is it normal to get the kind of results I attached after using improveMeshQuality ?
Thx a lot
Old   September 28, 2015, 17:14
Franjo Juretic
Can you please post the content of your controlDict? Do you save the mesh in the binary format? Can you please post the log of cartesian2DMesh?
It seems to me that the thickness of the first layer is smaller than the floating-point tolerance. Please increase the number of digits saved in a file or set the writeFormat to binary.
Not yet, we are working on that. It will be available in the next couple of days.
Thx a lot
Your boundary layers are extremely thin and the algorithm is not designed to handle that.
www.cfmesh.com
Old   September 29, 2015, 09:48
Clement Mtrl
Hi Franjo,
Thanks for everything,
In fact I changed my wall function so I increase my first layer thickness and everything went well !
For next time I sill remember what you've said but how can I choose the writeFormat (just change ascii to binary in the header ?)
It's really great to have the support of the developer while discovering this great tool
franjo_j likes this.
Old   September 29, 2015, 12:44
Smile
Franjo Juretic
Hi Franjo,
Yes, all you need is:
writeFormat binary;
My suggestion is to use the binary format because it does not lose information, that is extremely important for very thin layers. In addition, it also saves disk space.
Thank you! Happy meshing !
www.cfmesh.com
Old   February 1, 2018, 01:37
ashkan is on a distinguished road
Hi Franjo,
I am trying to create a 2D case for flow around a pipe using cfmesh and openfoam v1712. However, it seems that I cannot get it working with "cartesian2DMesh" at all. It seems that the issue is on the stl/fra file as it consider it 3D.
Basically, I created a cylinder and mesh it in salome then created boundying box for it using "surfaceGenerateBoundingBox" and use that in the meshDict. Attached please find my case file with the "Allrun" file showing the steps I have taken.
I would highly appreciate your input on how to get it to work.
many thanks
Ashkan
ashkan is offline   Reply With Quote
Old   February 2, 2018, 00:37
I managed to resolve my issues and generate the 2D mesh following the very helpful instructions given here
Old   February 14, 2018, 07:26
Question cfMesh different behaviour
Hosein
einstein_zee is on a distinguished road
Hi there foamers,
I didn't want to create a new thread cause the current name is good and applicable to my question as well. I just noticed that for the same geometry when I try to run cfMesh (I use cartesianMesh) for the first time it gave me 103 badCells. Then I just deleted the polymesh folder ($caseFile/constant/polymesh) and tried to run cfMesh for the second time and this time it gave me 64 badCells! this was weird for me and I tried for the third time and I got 115 badCells! I would appreciate if somebody can tell me why this happens?
I also tried to change the format of my original geometry (.stl file) to .fms (using surfaceToFMS). Guess what... after running cfMesh I got a different number of badCells. But at least for this one I can assume that there might be some slight changes during the conversion from one file format to another. However, for the first case all of the trials were completely identical (in .stl format). I'm using OF1712 and latest version of cfMesh, only if that matters!
einstein_zee is offline   Reply With Quote
Old   July 12, 2018, 04:02
Default No cells in mesh / segmentation fault
  #11
Jenna Vergeynst
jenna is on a distinguished road
Hi dear all,
I'm also having problems with the cartesian2D mesher.
The stl file (from Salome): https://drive.google.com/open?id=1X7...lLNXpFyP5PaS2p
The refined one: https://drive.google.com/open?id=1Yh...TCcGJ9QGa7UfAr
My meshDict only contains:
surfaceFile "Ham2D.stl";
maxCellSize 1;
I get the error:
There are no cells in the mesh!
The reasons for this can be fwofold:
1. Inadequate mesh resolution.
2. You maxCellSize is a multiplier of the domain length. This can be reolved by reducing the maxCellSize by a fraction.i.e. 2.49999 instead of 2.5.
I made sure that the geometry was completely closed, as hinted here: Inadequate mesh resolution (CfMesh). But this didn't help.
Then I tried refining the mesh, but still the same error. When I change the maxCellSize parameter to 0.5, it runs but crashes and then gives
 segmentation fault
I also tried first converting to ftr with surfaceConvert, but this did not help either.
Any idea?
jenna is offline   Reply With Quote
Old   July 12, 2018, 05:00
Franjo Juretic
Have a look at the hat case in the tutorial folder and prepare your geometry accordingly. In addition, you can find information about 2D geometries in the user guide.
You need to create a ribbon in order to use cartesian2DMesh.
It may help you to try keepCellsIntersectingBoundary 1 option.
However, it better to desing your geometry as a set of edges in the x-y plane and extrude it into a ribbon with the extrudeEdgesInto2DSurface utility.
www.cfmesh.com
Old   July 12, 2018, 09:35
Jenna Vergeynst
Hi franjo,
Thank you for the quick reply!
I exported only the edges from salome now, but extrudeEdgesInto2DSurface doesn't take it. Problem is that it is a vtk file, which contains VERTICES, causing the fatal error
Unsupported tag VERTICES
I tried to convert the vtk file to something foam-readable with vtkUnstructuredToFoam, but this gives the same error... Any ideas for this, or is it rather a salome thing?
Old   July 12, 2018, 10:22
Franjo Juretic
Can you visualize the vtk file in ParaView? Do you see edges, only?
Any edge mesh format readable by OpenFOAM shall suffice.
Which version of OF do you use?
www.cfmesh.com
Old   July 13, 2018, 03:39
Jenna Vergeynst
The openfoam version is 2.3.0, cfmesh v1.1.1.
When I visualise the vtk file (https://drive.google.com/open?id=1IK...czL6ccbY2IZuus), I see the edges, but also the vertices.
I tried with deleting the vertices part => this visualises in paraview as only edges. But then extrudeEdgesInto2DSurface gives:
bad size -2147483647
Old   August 13, 2018, 11:07
Jenna Vergeynst
Hi Franjo,
Still same trouble here... Maybe there is a problem with the edges file... Some details on what I'm trying to do: I have a closed PolyLine in Salome (which are the edges of my geometry), which I export in the Geometry module as a vtk file. However, this file cannot be read by extrudeEdgesInto2DSurface, as mentioned earlier. Can it be due to the type of element in Salome (PolyLine)? Is there a way to make Edges from a PolyLine? ...
Thanks,
Jenna
Old   August 23, 2018, 03:27
Jenna Vergeynst
Hi all,
To by-pass my problem with cartesian2DMesh, I changed the approach as follows:
instead of trying to read out edges from salome and later do extrudeEdgesInto2DSurface, I directly extruded the ribbon (in x-y plane) in the z-direction, within salome (for instance a polyline can be extruded with geompy.MakePrism).
Then I named the needed patches (geompy.CreateGroup) and also added them to the mesh after meshing (with GroupOnGeom).
Finally I exported the mesh as .fms by use of salomeTriSurf.py (notes on this also here).
And on this fms file, cartesian2DMesh works smoothly!
boundarylayers, cfmesh, refinement
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 04:27
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[ICEM] ICEM Structured Mesh Problem OMJT ANSYS Meshing & Geometry 3 March 22, 2013 10:06
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
