[waves2Foam] can't do the SVN step, is there any other way to download? |
November 21, 2017, 04:18 |
Rep Power: 8 |
Hello, I'm sorry if this is more of a Linux/Docker issue than strictly a waves2foam issue, but I was hoping someone might be able to help me out as I haven't been able to find the solution online. Basically I am running openFoam v1606 from a Docker container, as recommended on the openFoam website. This works fine, but when trying to install waves2foam I can't do the SVN step (svn co http://svn.code.sf.net/p/openfoam-ex...her/waves2Foam) from inside the Docker container, because for some reason Docker doesn't recognise that the file /usr/bin/svn exists.
I can do this step from outside the Docker container, but as far as I can understand, that is not what is required for the waves2foam installation. Sorry if this is not really within the remit of this thread. As I say, I suspect that it is my lack of knowledge of Linux that is letting me down, rather than anything specifically to do with waves2foam. However if anyone could point out where I'm going wrong I'd be extremely grateful, as I am really looking forward to using waves2foam - it seems that it will be extremely useful for my research. Thanks in advance, Richard |
November 21, 2017, 05:18 |
Ahmed Elhanfi
Rep Power: 11 |
Hi Richard,
Try this one, and let me know if it works for you. https://github.com/ogoe/waves2Foam Kind Regards, Ahmed |
November 21, 2017, 05:43 |
Rep Power: 8 |
Thanks so much for the recommendation Ahmed. I am away from my machine at the moment but I will try it this evening and will let you know.
Thanks again, Richard |
November 21, 2017, 17:57 |
Rep Power: 8 |
Hello again Ahmed. I got the installation to work - I just needed to do the SVN step outside of Docker, and then copy the downloaded waves2foam directory into the applications/utilities directory before running the Allwmake script from there, inside Docker. I'm going to have a go with the tutorials now.
Thanks again for your suggestion. Richard |
November 25, 2017, 02:02 |
#5 | |
Ahmed Elhanfi
Rep Power: 11 |
Thanks for the update, and I hope everything is going well with you now. Kind Regards, Ahmed |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
