[waves2Foam] Problem of deep water simulation(wavelength become larger as propagation) |
February 13, 2019, 02:23 |
i-chen,tsai
Rep Power: 8 |
Dear all,
I have a problem with deep water simulation. Wavelength would become larger as wave propagation. Could someone tell me how to solve the problem? The following are my file: waveProperties: Code:
seaLevel 0.00; // A list of the relaxation zones in the simulation. The parameters are given // in <name>Coeffs below. relaxationNames (inlet outlet); initializationName outlet; inletCoeffs { // Wave type to be used at boundary "inlet" and in relaxation zone "inlet" waveType stokesSecond; // Ramp time of 2 s Tsoft 1.2; // Water depth at the boundary and in the relaxation zone depth 0.900000; // Wave period period 1.20; // Phase shift in the wave phi 0.000000; // Wave number vector, k. direction (1.0 0.0 0.0); // Wave height height 0.06; debug false; // Specifications on the relaxation zone shape and relaxation scheme relaxationZone { relaxationScheme Spatial; relaxationShape Rectangular; beachType Empty; relaxType INLET; startX (0.0 0.0 -0.9); endX (6.0 0.9 0.3); orientation (1.0 0.0 0.0); } }; outletCoeffs { waveType potentialCurrent; U (0 0 0); Tsoft 1.2; relaxationZone { relaxationScheme Spatial; relaxationShape Rectangular; beachType Empty; relaxType OUTLET; startX (29.0 0.0 -0.9); endX (35.0 0.9 0.3); orientation (1.0 0.0 0.0); } }; Code:
application interFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 60; deltaT 0.001; writeControl adjustableRunTime; writeInterval 0.1; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; maxCo 0.25; maxAlphaCo 0.25; maxDeltaT 0.001; Code:
solvers { "alpha.water.*" { nAlphaCorr 1; nAlphaSubCycles 1; alphaOuterCorrectors yes; cAlpha 1; MULESCorr yes; nLimiterIter 3; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0; } pcorr GAMG { tolerance 1e-7; relTol 0.0; smoother DIC;//GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; }; pcorrFinal GAMG { tolerance 1e-7; relTol 0.0; smoother DIC;//GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; }; p_rgh GAMG { tolerance 1e-7; relTol 0.0; smoother DIC;//GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; }; p_rghFinal GAMG { tolerance 1e-8; relTol 0.0; smoother DIC;//GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; }; U PBiCG { preconditioner DILU; tolerance 1e-09; relTol 0; }; UFinal PBiCG { preconditioner DILU; tolerance 1e-09; relTol 0; }; gamma PBiCG { preconditioner DILU; tolerance 1e-07; relTol 0; }; } PIMPLE { momentumPredictor yes; nOuterCorrectors 1; nCorrectors 3; nNonOrthogonalCorrectors 1; } relaxationFactors { fields { } equations { ".*" 1; } } Code:
ddtSchemes { default Euler; } gradSchemes { // default cellLimited fourth 1; default Gauss linear; grad(U) Gauss linear; grad(alpha1) Gauss linear; } divSchemes { // default Gauss linear; div(rhoPhi,U) Gauss limitedLinearV 1; // div(phi,gamma) Gauss vanLeer; // div(rho*phi,U) Gauss MUSCL; // div((muEff*dev(T(grad(U))))) Gauss linear; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; div(phi,alpha) Gauss MUSCL; div(phirb,alpha) Gauss interfaceCompression; // div(rhoPhi,U) Gauss limitedLinearV 1; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p_rgh; pcorr; alpha.water; } x:35m z:1.2m dx:0.005m dz:0.0025 wave condition period:1.2 sec wave height:0.06m water depth:0.9m This is deep water condition! There are 24 cells per wave height and about 439 cells per wavelength. I tried two versions of OpenFOAM (1712plus and extend 4.0), different types of mesh and different timesteps. The result of different timesteps, version and mesh type shown below: |
February 26, 2019, 18:05 |
Hillary Kiptoo
Rep Power: 7 |
Quick answer: You need to check your numerical schemes for example, from my experience, CrankNicolson works best than euler
February 27, 2019, 13:55 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Also, if you compare the conditions with stream function wave theory, then you will see that stream function wave theory is roughly 1% longer, so after 13 wave lengths it amounts to a noticeable effect.
Kind regards Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
March 6, 2019, 02:21 |
i-chen,tsai
Rep Power: 8 |
@ngj
Dear Niels, Thanks for your quick reply. I found that the result is much more approach to Stokes 5th wave, not Stokes 2nd waves. Would you please tell me why the wave condition is appropriate to choose Stokes 2nd Wave, but the result is more approach to Stokes 5th wave? Thank you very much! |
discrete model problem (water droplet evaporation) | rabaeto1984 | FLUENT | 4 | October 1, 2018 04:16 |
Problem after mergeMesh, water flows through the wall, which should not happen | Andy_Wang | OpenFOAM | 13 | June 15, 2016 08:11 |
shallow water VS deep water | Paul | Main CFD Forum | 10 | August 30, 2004 11:56 |
Problem Patching Water Depth (2-D) | SEMC | FLUENT | 3 | March 15, 2004 19:58 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
