[waves2Foam] Problems changing waveType from stokesFirst to others |
June 13, 2016, 02:50 |
Kenric
Rep Power: 10 |
Hello, I am running the waveFlume tutorial and I have an error while using the function setWaveParameters when I edit the wavetype from stokesFirst to other type of wave in waveProperties.input file. Not sure whether I'm doing it at a right way or not either because I'm very new in openfoam. The waveProperties.input file and the error are as below. Appreciate alot if I can get any help from anyone here. Thank you very much!
PHP Code:
PHP Code:
September 28, 2018, 05:18 |
on the use of waves2Foam other wave theories
zhongzhong
Rep Power: 7 |
Hello,Excuse me,i want to ask have you solved this problem? i also met it now
if you solved it,can you tell me? Thank you very much |
November 5, 2018, 10:24 |
Jorge Gadelho
The error is very explicit:
keyword debug is undefined in dictionary "/home/oecu/OpenFOAM/oecu-3.0.1/waves2Foam/tutorials/waveFoam/waveFlume/constant/waveProperties.input.inletCoeffs" Use your prefered editor to edit waveProperties.input Under inletCoeffs add a variable called debug and give a boolean value (true or false). In other words, add the green line as follows: // Wave height height 0.1; debug true; |
loading issue libraries:libsimpleFunctionObjects.so libsimpleSwakFunctionObjects.so | immortality | OpenFOAM Pre-Processing | 15 | April 7, 2024 12:35 |
[ANSYS Meshing] Periodicity problems in icem | zeeshu | ANSYS Meshing & Geometry | 0 | April 17, 2016 20:59 |
Problems when compile SU2 v4.X with openmpi | BopngMa | SU2 | 1 | September 6, 2015 06:30 |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 12:13 |
[OpenFOAM] ParaView Postprocessing problems with cyclic boundaries | christian | ParaView | 10 | June 26, 2009 05:49 |
