[waves2Foam] How to use stream function wave theory
Old   November 29, 2016, 10:35
Default How to use stream function wave theory
Wang Xi
Melo1993 is on a distinguished road
Hi all, I met some problems when I was trying to use stream function wave theory into my case.
First I run generateStreamFile.m and put the result into waveProperties.input. But when I run setWaveParameters, it shows that
keyword height is undefined in dictionary "/home/wxi/OpenFOAM/wxi-2.4.0/applications/utilities/waves2Foam/tutorials/mycase/real/3.validate/validatestream/constant/waveProperties.input.inletCoeffs"
Then I add the wave height into waveProperties.input and run it, it shows
keyword specifyPeriod is undefined in dictionary "/home/wxi/OpenFOAM/wxi-2.4.0/applications/utilities/waves2Foam/tutorials/mycase/real/3.validate/validatestream/constant/waveProperties.input.inletCoeffs"
In generateStreamFile.m, I set 'H=0.12,h=0.6,T=0.8,uEors=0,EorS=0,N=15'
In waveProperties.input :
seaLevel 0.0;
relaxationNames ( inlet outlet );
initializationName outlet;
inletCoeffs
waveType streamFunction;
N 15;
depth 0.600000;
omega 7.853982;
phi 0.000000;
waveNumber (5.622357 0.0 0.0);
uBar 1.39692;
A nonuniform List<scalar> 15
0.056124
0.0108254
0.00326968
0.0011939
0.000483655
0.000209166
9.46084e-05
4.42151e-05
2.11873e-05
1.03602e-05
5.16046e-06
2.63074e-06
1.40627e-06
8.53606e-07
3.47706e-07
B nonuniform List<scalar> 15
0.408132
0.0186686
0.00260019
0.000466129
8.11037e-05
1.51577e-05
2.88303e-06
5.59405e-07
1.10116e-07
2.19105e-08
4.39949e-09
8.90332e-10
1.82825e-10
3.86484e-11
7.43894e-12
relaxationZone
relaxationScheme Spatial;
relaxationShape Rectangular;
beachType Empty;
relaxType INLET;
startX ( -8 0 0 );
endX ( 0 0 0.1 );
orientation ( 1 0 0 );
outletCoeffs
waveType potentialCurrent;
U ( 0 0 0 );
Tsoft 2;
relaxationZone
beachType Empty;
relaxType OUTLET;
startX ( 10 0 0 );
endX ( 18 0 0.1 );
I don't know how to solve it. Anyone can help? Thanks a lot!
Melo1993 is offline   Reply With Quote
Old   November 29, 2016, 15:36
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Wang,
You do not need to use the matlab script any longer. Stream function waves are now supported directly with setWaveParameters as of the 19th of May 2016. See https://openfoamwiki.net/index.php/C..._.28History.29
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   November 29, 2016, 16:42
Wang Xi
Hi Niels,
Many thanks for reply. For using setWaveParameters, I am wondering which parameters should be set under inletcoeffs or do I still need to fill the parameters shown below, and how to setl uBar, A, B?
+++ Example - setWaveParameters +++
// Currently not working
+++ Example - Running +++
omega <scalar>;
depth <scalar>;
phi <scalar>;
waveNumber <vector>;
uBar <scalar>;
N <scalar>;
A <scalarField>;
B <scalarField>;
Tsoft <scalar>; // Not required
Tstart <scalar>; // Not required (Default 0.0);
Tend <scalar>; // Not required (Default GREAT);
Thanks again!
Old   November 30, 2016, 12:50
ngj
Good evening,
@Wang: Merely step through a couple of time iterations and provide iteratively the information that setWaveParameters request. The WIKI is not up to date in terms of the streamFunction wave. If you want, I would be happy if you could improve the WIKI for the streamFunction description.
Kind regards,
Niels
Last edited by wyldckat; August 25, 2018 at 07:30. Reason: removed answers to other posts that were on the main thread
Old   May 27, 2020, 10:03
Michiel Bots
mbots is on a distinguished road
Hi Niels,
I am trying to generate a wave using the streamFunction at the inlet and potentialCurrent with zero velocity at the outlet. However, I can't manage to generate any waves while using both streamFunction and potentialCurrent. When I use streamFunction at both inlet and outlet, everything seems to work fine. Do you have any idea what could be causing this?
Thank you your help!
Michiel
seaLevel            0;
seaLevelAsReference true;
// A list of the relaxation zones in the simulation. The parameters are given
// in <name>Coeffs below.
relaxationNames (inlet outlet);
inletCoeffs
    specifyPeriod true;
    specifyEuler false;
    stokesVelocity 0;
    N 		32;
    Niter	8;
    Tsoft       1.2;
    depth       0.4;
    period      1.2;
    phi         4.20156075;
    direction  (1.0 0.0 0.0);
    height      0.06;
    relaxationZone
           beachType           Empty;
           relaxType           INLET;
           startX              ( -6 1.125 -1.3 );
           endX                ( -3.7 -0.375 1.3 );
outletCoeffs
    U                   ( 0 0 0 );
    Tsoft               1.2;
//    waveType    streamFunction;
//    specifyPeriod true;
//    specifyEuler false;
//    stokesVelocity 0;
//    N 		32;
//    Niter	8;
//    Tsoft       0;
//    depth       0.4;
//    period      1.2;
//    phi         4.20156075;
//    direction  (1.0 0.0 0.0);
//    height      0.06;
    relaxationZone
        beachType           Empty;
        relaxType           OUTLET;
        startX              ( 9.7 1.125 -1.3 );
        endX                ( 12 -0.375 1.3 );
mbots is offline   Reply With Quote
Old   May 27, 2020, 11:00
ngj
Hi Michiel,
I have done similar things many times, so it should work. I cannot spot any flaws in your waveProperties.input file.
One thing is that you should watch out for the definition of the relaxation zone, which should be defined in the horizontal plane only. Try to run relaxationZoneLayout tool on your setup to verify that you are content with the relaxationZone definition.
Kind regards
Niels
Old   May 28, 2020, 06:13
Michiel Bots
Hi Niels,
Thank you very much for your response. The layout of the relaxation zone seems fine to me, I visualized it in Paraview (see attached figure).
The waves move along the x-axis and the gravity works along the y-axis.
I've also tried running a case that worked with both streamFunction and potentialCurrent before. However, when I run it, it doesn't work. Could there be something wrong with the installation?
Michiel
Old   May 28, 2020, 08:32
Michiel Bots
Hi Niels,
Just to be sure, I just studied the manual again and I found the section about 'combined waves':
I guess you only have to use 'combined waves' if you want to apply two wave theories to the same relaxation zone, right?
Michiel
PS:An update, I've adjusted the waveFlume tutorial to use the streamFunction (inlet) and potentialCurrent (outlet, zero velocity). I used both the waveFoam and the waveDyMFoam solver to run this case. When using the waveFoam solver everything goes fine; the waves are generated properly and they also dampen out in the outlet. However, when using the waveDyMFoam solver the waves are generted properly, but they do not dampen out in the outlet. Do you think this might be an indication for the waveDyMFoam solver being not properly compiled?
Old   May 28, 2020, 12:10
ngj
Hi Michiel,
I would guess that you have not generated your waveDyMFoam solver correctly. Make sure that the statement 'relaxation.correct();' (or similar, please check waveFoam) is not missing.
Kind regards
Niels
Old   May 29, 2020, 07:11
Michiel Bots
Hi Niels,
Thank you very much! With your suggestion, I managed to solve the issue
For other users that might run into a similar issue, I will describe what I did exactly below, using OpenFOAM version 1606+.
Best regards,
Michiel
1. Go to the .../solvers/solvers1606_PLUS/waveFoam folder run the command 'wclean'. Do the same in the folder .../solvers/solvers1606_PLUS/waveFoam/waveDyMFoam.
2. Make sure that you've sourced waves2Foam. In order to do so go to the folder .../applications/utilities/waves2Foam and in this folder run the command: source ./bin/bashrc
3. Return to the folder .../solvers/solvers1606_PLUS/waveFoam/waveDyMFoam in the file waveDyMFoam.C add the line 'relaxing.correct();', like below:
            #include "alphaControls.H"
            #include "alphaEqnSubCycle.H"
            // include here relaxing.correct() like in waveFoam.C
            relaxing.correct();
            mixture.correct();
            #include "UEqn.H"
4. Go to the waveFoam folder and execute the command 'wmake'. Hereafer, go to the waveDyMFoam folder and also exectue the command 'wmake'.
Now the relaxation zones should work fine. You can check this by running the waveFlume tutorial using the waveDyMFoam solver instead of the waveFoam solver (adjust the Allrun file accordingly).
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 10:05
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 10:20
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
