[waves2Foam] Long waiting time for large number of gauges |
Rep Power: 17 ![]() |
Ni Niels,
I have trouble getting wave2Foam to run with large amount of gauges ("surfaceElevation" function object) in the domain. Previously, I usually use small amount of gauges in my domain. This run almost instantly without any problem. However, it I increase the amount of gauges (say to 5000 gauges), and run waveFoam, the simulation spent alot of time before entering the time loop as follows : Code:
Reading g Reading waveProperties Reading waveProperties Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Calculating field g.h No finite volume options present time step continuity errors : sum local = 0, global = 0, cumulative = 0 DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 Courant Number mean: 0 max: 0 Starting time loop <<<< Really long time here >>>> Courant Number mean: 0 max: 0 Interface Courant Number mean: 0 max: 0 deltaT = 0.0011999956 Time = 0.0012 MULES: Solving for alpha1 Kind regards, katakgoreng |
Niels Gjoel Jacobsen
Rep Power: 38 ![]() ![]() |
Good evening,
It has been some time since my last reply, so I will try to wrap everything up: @Katakgoreng: I have never tried to use that many wave gauges. Could you please try to track it down in order to figure out, where the time is spend? E.g. put some Info statements in the code. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. Last edited by wyldckat; October 8, 2018 at 09:32. Reason: removed answer to another post that was on the main thread |
Display Modes | |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
