[waves2Foam] about this "timeShift" in the "waveProperties" dictionary
Old   August 20, 2014, 12:48
Default about this "timeShift" in the "waveProperties" dictionary
katakgoreng is on a distinguished road
Hi Niels,
Could you explain a bit about this "timeShift" in the "waveProperties" dictionary. Will "timeShift" introduce a lag if it is set to non-zero value?
Kind regards,
katakgoreng
katakgoreng is offline   Reply With Quote
Old   August 20, 2014, 13:01
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Katakgoreng,
If you are thinking of the parameter in the main part of the waveProperties file it is an artefact, which does no longer have any meaning.
Any other occurrence of timeShift would be unknown to me.
Thank you for pointing it out. I will try to remember to clean it up, when I update the repository next time.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
[waves2Foam] Error "request for dictionary waveProperties from objectRegistry region0 failed" gautami OpenFOAM Community Contributions 6 April 29, 2021 12:23
ill defined primitiveEntry starting at keyword 'value' on line 197 ChangeDictionary Struggle_Achieve OpenFOAM Pre-Processing 2 December 20, 2017 03:58
[waves2Foam] keyword debug is undefined in dictionary waveProperties Tings_ OpenFOAM Community Contributions 2 September 21, 2015 07:30
[waves2Foam] wave2foam dictionary waveProperties objectRegistry request failed sophie_l OpenFOAM Community Contributions 11 March 19, 2013 11:08
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
