[ImmersedBoundary] Immersed Boundary foam-ext 3.2 Parallelization for higher amount of MPI tasks
Old   October 11, 2016, 03:50
Default Immersed Boundary foam-ext 3.2 Parallelization for higher amount of MPI tasks
hxaxtma is on a distinguished road
Hi guys,
I observed a little bug regarding the IB Method of Jasak and its parallelization.
Meanwhile the immersed boundary region is not decomposed over different cores, the IB implementation runs in parallel. Nevertheless, if the Immersed Boundary regionis decomposed over different cores, an error occurs.
Create time
Create mesh for time = 0
Create immersed boundary cell mask
Create immersed boundary face mask
Found immersed boundary patch 0 named ibCylinder
[3] Number of IB cells: 0
[6] Number of IB cells: 0
[7] Number of IB cells: 0
External flow
[2] Number of IB cells: 0
[5] Number of IB cells: 0
[4] Number of IB cells: 0
[0] Number of IB cells: 63666
[1] Number of IB cells: 81786
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Time = 5e-05
Courant Number mean: 0.00304818143 max: 1.81649312 velocity magnitude: 2.35556273
*** Error in `icoIbFoam': free(): invalid next size (normal): 0x000000002468a800 ***
======= Backtrace: =========
/lib64/libc.so.6(+0x7410f)[0x2b80e90ea10f]
/lib64/libc.so.6(+0x7996e)[0x2b80e90ef96e]
/lib64/libc.so.6(+0x7a647)[0x2b80e90f0647]
/home/iagaxtma/opt/foam/foam-extend-3.2/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam4ListINS_4PairIiEEE7setSizeEi+0x42)[0x2b80e59ded72]
/home/iagaxtma/opt/foam/foam-extend-3.2/lib/linux64GccDPOpt/libimmersedBoundary.so(_ZNK4Foam23immersedBoundaryFvPatch15makeIbCellCellsEv+0x1c38)[0x2b80e72526b8]
/home/iagaxtma/opt/foam/foam-extend-3.2/lib/linux64GccDPOpt/libimmersedBoundary.so(_ZNK4Foam23immersedBoundaryFvPatch11ibCellCellsEv+0x1d)[0x2b80e7252a0d]
At the moment I do overcome this by creating a zone and preserving this faceZone on one processor, with this workaround, the IB method also runs for higher rates of mpi tasks in parallel,
Nevertheless I would like to fix this bug, the problem is, I do not really know where to start. I had a deeper look in the Immersed Boundary Implementation files, but somehow I am missing the important part.
Any hint would be appreciated and maybe Prof Jasak has an advice.
Thanks
hxaxtma is offline   Reply With Quote
Old   October 12, 2019, 09:34
courant_numero_uno is on a distinguished road
Hello hxaxtma, I know this post is old now, but I am running into the same issue you suggested (crashing when the immersed boundary crosses between processors).
Could you please let me know how you were able to create a faceZone to get around this problem? Thanks!
courant_numero_uno is offline   Reply With Quote
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 10:20
segmentatio fault using cyclic boundary conditions in FOAM extend 3.2 GFarello OpenFOAM Running, Solving & CFD 2 January 18, 2017 05:27
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 02:21
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
