[waves2Foam] Questions about the case 'bejiBattjes' |
April 6, 2014, 10:16 |
Rep Power: 12 |
Hi, Ngs,
I am learning about the case in waves2foam, named 'bejiBattjes'. But I am puzzled with the mesh. In the file 'stlDefinitions', there are four points to definite the shape. But I do not know about the meaning of the file 'geometria.stl_backup'. Please give me more details. Thank you very much. ps, If I have change the points in 'stlDefinitions', the shape also changes. Last edited by zhyren; April 6, 2014 at 10:38. Reason: more information |
April 7, 2014, 13:43 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Good evening,
@Zhyren: Please read the Allrun script, as this will tell you the details on the various steps/files. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. Last edited by wyldckat; November 4, 2018 at 13:47. Reason: removed answer to another post that was on the main thread |
April 8, 2014, 09:07 |
Rep Power: 12 |
Hi, Niels,
In the simulation results of tutorials case 'bejiBattjes', I can not find the data files in the folder 'surfaceElevation'. Should I change something in Allrun or make other changes? Thanks. zhiyuan |
April 8, 2014, 14:49 |
Rep Power: 37 |
Hi Zhiyuan,
Yes, I can confirm that it is a bug. I am thinking of how to make a general correction, but for know, merely change to field name in the controlDict (the sample part) from alpha1 to alpha.water. Hopefully, this is the only place, where I have missed a static name of the VOF field. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
April 10, 2014, 07:14 |
Two questions about 'bejiBattjes'
Rep Power: 12 |
Dear Niels,
I have two questions about this case 'bejiBattjes', 1. I do not use the matlab code and directly compare them with other software. I have found that in the matlab code, a time shift 1.49s need to be applied to the simulation results. Could you explain why? Do I have to do this time shift to all the other cases? 2. The simulation results do not match well with the experiment data. However, I have found that in the master paper 'Development of a numerical wave tank using OpenFOAM', the grid size 0.02 by 0.01 is enough. And his results are better than this case. So, do you have some suggestions? Best regards, Zhiyuan |
Pressure instabilities with interDyMFoam for the floatingObject case | nbadano | OpenFOAM Running, Solving & CFD | 15 | October 15, 2021 06:35 |
dynamicMesh case setup simpleton questions | tellico | OpenFOAM Pre-Processing | 2 | January 17, 2014 12:41 |
some questions about the setting of a compressible case | xck1986 | OpenFOAM | 9 | October 7, 2011 17:56 |
[snappyHexMesh] Editing the motorBike case, loading diffirent .stl | btgyd | OpenFOAM Meshing & Mesh Conversion | 1 | September 26, 2011 17:24 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
