[waves2Foam] Error message when installing: "Correct the path in bin/bashrc" |
March 24, 2014, 10:50 |
Rep Power: 12 |
Hi Jacobsen,
I have a problem when I want to install the waves2Foam. It read like this: ===================================== ENVIRONMENTAL VARIABLES ===================================== EXTBRANCH=0 FOAMEXTENDPROJECT=0 WAVES_APPBIN=/home/zhiyuan/OpenFOAM/zhiyuan-2.3.0/platforms/linuxGccDPOpt/bin WAVES_DIR=/home/zhiyuan/OpenFOAM/zhiyuan-2.3.0/applications/utilities/waves2Foam WAVES_GSL_INCLUDE=/usr/include WAVES_GSL_LIB=/usr/lib64 WAVES_LIBBIN=/home/zhiyuan/OpenFOAM/zhiyuan-2.3.0/platforms/linuxGccDPOpt/lib WAVES_POST=/home/zhiyuan/OpenFOAM/zhiyuan-2.3.0/applications/utilities/waves2Foam/applications/utilities/postProcessing WAVES_PRE=/home/zhiyuan/OpenFOAM/zhiyuan-2.3.0/applications/utilities/waves2Foam/applications/utilities/preProcessing WAVES_SOL=/home/zhiyuan/OpenFOAM/zhiyuan-2.3.0/applications/utilities/waves2Foam/applications/solvers/solvers230 WAVES_SRC=/home/zhiyuan/OpenFOAM/zhiyuan-2.3.0/applications/utilities/waves2Foam/src WAVES_TUT=/home/zhiyuan/OpenFOAM/zhiyuan-2.3.0/applications/utilities/waves2Foam/tutorials WAVES_UTIL=/home/zhiyuan/OpenFOAM/zhiyuan-2.3.0/applications/utilities/waves2Foam/applications/utilities WAVES_XVERSION=0 WM_PROJECT_VERSION_NUMBER=230 FATAL ERROR. The directory path /home/zhiyuan/OpenFOAM/zhiyuan-2.3.0/applications/utilities/waves2Foam does not exist. Correct the path in bin/bashrc This means that you should correct the environmental variable $WAVES_DIR such that it is pointed (in absolute sense) to the path, where waves2Foam is located. Please note that once bin/bashrc is created, bin/bashrc.org is only an inactive file. The latter is also the only of the two files, which is updated through the SVN-repository. EXITING |
March 24, 2014, 12:13 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Zhyren,
Please read the error message carefully. Otherwise, the solution is given a multiple number of times in this thread. Good luck, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
Extruding surface/domain mesh in helical path | rahulksoni | Pointwise & Gridgen | 6 | March 4, 2018 10:57 |
[waves2Foam] Error: "The directory path WAVES_DIR=:/home/waves2Foam does not exist." | Dmitrjs | OpenFOAM Community Contributions | 3 | June 27, 2014 08:53 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Problem installing on 64bit with ver13 | jonititan | OpenFOAM Installation | 5 | May 12, 2006 18:42 |
Problem installing on 64bit with ver13 | jonititan | OpenFOAM Installation | 0 | April 28, 2006 05:45 |
