[cfMesh] Does cfMesh supports LABEL 64 (integer 64bit) for larger mesh size?
Like Tree1Likes
  • 1 Post By lonelywing
Old   March 29, 2019, 03:22
Default Does cfMesh supports LABEL 64 (integer 64bit) for larger mesh size?
Junshin Park
lonelywing is on a distinguished road
Dear Foamer,
I have been working on generating large numbers of mesh (over 150 miliion) using cfMesh cartesianMesh utility.
I did have few success in generating for some cases.
Whenever mesh generates large number of polyhedral mesh in the transition region, however, number of edges and vertices exceed 2.1biliion (max. 32bit integer).
I'm aware of the fact that cfMesh v.1.1.2 have announced that it supports OpenFOAM 4.0, which made it possible to install OF with LABEL 64(64bit integer). However, when I install OF4 with LABEL 64, installation of cfMesh fails.
I'd like to generate more meshes (that involves more edges and vertices that can be dealt with 32bit integer) using cfMesh utility.
Does anyone have tried this before and had success with this?
If it is not fully supported yet, is there any way I can get help or contribute to the present version?
Many thanks,
Junshin
nope likes this.
lonelywing is offline   Reply With Quote
Old   August 16, 2019, 03:00
nope is on a distinguished road
Hi
I know it's a little bit late...
I'm running cfMesh with OF v1812 and OF v1906 with 64bit Labels successfully. 64bit Labels solved an error i got during meshing with cfMesh. Eventhough the final mesh wasn't that big, an intermediate stage seems to lead to an overflow.
FOAM FATAL ERROR: Negative size requested
Cheers, nope
nope is offline   Reply With Quote
cfmesh, integer 64bit, openfoam
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[ICEM] Effect of globle mesh size and mesh independency sujay ANSYS Meshing & Geometry 20 September 29, 2019 07:36
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 07:30
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 11:27
