[cfMesh] cfMesh - How to reconstruct after running using mpi |
February 15, 2019, 15:05 |
W. Schuyler Hinman
Rep Power: 13 |
Hello!
I have been using cfMesh for a very long time with tons of success. Recently I have been trying to experiment with deploying it onto my cluster. I am running cfMesh with OpenFOAM-1806. From the manual, and a few forum entries, I gathered that I should run it like (this test was on two 4-core remote computers): Code:
preparePar mpirun -np 8 -hostfile machines -x FOAM_SETTINGS ~/OpenFOAM/OpenFOAM-v1806/bin/foamExec cartesianMesh -parallel Code:
Reading points from "8Core_0.25MeshSize/processor0" for time = constant Reading points from "8Core_0.25MeshSize/processor1" for time = constant Reading points from "8Core_0.25MeshSize/processor2" for time = constant Reading points from "8Core_0.25MeshSize/processor3" for time = constant Reading points from "8Core_0.25MeshSize/processor4" for time = constant Reading points from "8Core_0.25MeshSize/processor5" for time = constant Reading points from "8Core_0.25MeshSize/processor6" for time = constant Reading points from "8Core_0.25MeshSize/processor7" for time = constant Overall mesh bounding box : (-0.00257379658 -0.00374847875 -12.8007856) (24.9997 3.00000102 27.2012334) Relative tolerance : 1e-07 Absolute matching distance : 4.72683587e-06 Merging mesh 0 with 1 --> FOAM FATAL ERROR: Perfect match specified but number of master and slave faces differ. master:215 slave:0 From function Foam::faceCoupleInfo::faceCoupleInfo(const Foam::polyMesh&, const labelList&, const Foam::polyMesh&, const labelList&, Foam::scalar, bool, bool, bool) in file polyMeshAdder/faceCoupleInfo.C at line 2037. FOAM aborting Thanks in advance! Schuyler |
May 15, 2019, 11:27 |
Akash Patel
Rep Power: 7 |
Generally, you will have to use a utility called "reconstructParMesh". It combines mesh from all processors for you.
November 13, 2019, 04:16 |
Tim Jeremy Patrick Karpowski
Rep Power: 8 |
I ran into the same problem, for me "reconstructParMesh -constant -fullMatch " worked.
mpirun, best parameters | pablodecastillo | Hardware | 18 | November 10, 2016 12:36 |
Error running Converge Failed MPI File Open | Kurik | CONVERGE | 1 | August 2, 2016 11:44 |
Error using LaunderGibsonRSTM on SGI ALTIX 4700 | jaswi | OpenFOAM | 2 | April 29, 2008 10:54 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
MPI profiling OpenFOAM damBreak3D application | mellanoxuser | OpenFOAM Running, Solving & CFD | 0 | April 13, 2008 23:04 |
