[cfMesh] install cfMesh 1.1.2 with OpenFOAM 7 |
December 23, 2019, 15:06 |
Rep Power: 8 |
Hey,
i like to use OpenFOAM 7 with cfMesh 1.1.2 and Ubuntu 18.04.03. I downloaded and install openFoam in the /opt directory. Make the run directroy with Code:
mkdir -p $FOAM_RUN Code:
cp -r tutorials $FOAM_RUN I want do to the first exercise like in the readme: Code:
Copy the 'tutorials' examples directory in the cfMesh distribution to the 'run' directory. If the OpenFOAM environment variables are set correctly, then the following command will work correctly: + cp -r tutorials $FOAM_RUN Run the first example case of a simplified car body: + cd $FOAM_RUN/tutorials/asmoOctree + cartesianMesh All cases have Allrun and Allclean scripts guiding you through the meshing process. Code:
kai@Kai-Desktop:~/OpenFOAM/kai-7/run/tutorials/cartesianMesh/asmoOctree$ cartesianMesh cartesianMesh: Befehl nicht gefunden. kai@Kai-Desktop:~/OpenFOAM/kai-7/run/tutorials/cartesianMesh/asmoOctree$ Why is the command not found. what do i wrong ? Best regards Kai |
December 27, 2019, 15:43 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: You have to compile/build cfMesh, it's not just a matter of downloading it. Instructions are available here: https://openfoamwiki.net/index.php/E...ilities/cfMesh
December 29, 2019, 07:47 |
Rep Power: 8 |
Thank you very much. It runs now
Best regards Kai |
April 28, 2020, 17:13 |
#4 | |
Franco
Rep Power: 6 |
hello kai, could you help me to install it? completly new to linux is a little bit complicate it, tried to follow the instuction but when i use:
mkdir - p $FOAM_RUN i get Quote:
April 29, 2020, 00:37 |
Rep Power: 8 |
HEy otaolafr, do you follow these steps ? https://openfoam.org/download/7-ubuntu/ Best regards Kai
April 29, 2020, 06:01 |
#6 | ||||
Franco
Rep Power: 6 |
yes i have followed all the steps, for if i do Quote:
April 30, 2020, 08:11 |
Rep Power: 8 |
mh, its been a while since i installed it.
Under "Getting Startet" there is a code line Code:
mkdir -p $FOAM_RUN if you print this in ypur consol, will the same massage appear? Best regards Kai |
May 1, 2020, 04:44 |
#8 | |
Franco
Rep Power: 6 |
thanks |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 25 | August 14, 2022 13:55 |
[OpenFOAM.com] Docker OpenFOAM install error on Mac OS X | dersh | OpenFOAM Installation | 10 | May 6, 2016 12:49 |
Install openFOAM from with proxy server | Dhruval | OpenFOAM Installation | 3 | October 18, 2014 15:38 |
Unable to install OpenFOAM 1.6-ext | Maimouna | OpenFOAM Installation | 23 | May 8, 2014 05:47 |
OpenFOAM Install problem | masb | OpenFOAM | 3 | May 25, 2009 11:32 |
