[swak4Foam] Setting field with a zone() condition using OpenFOAM V1912 setExprField
Old   January 5, 2020, 20:38
Default Setting field with a zone() condition using OpenFOAM V1912 setExprField
Jeff
stewaj5 is on a distinguished road
Does the new OpenFOAM V1912 utility setExprFields allow for the condition of zone() to be used as is available for funkySetFields?
I did not see it as an option in https://www.openfoam.com/documentati...xprFields.html but I wouldn't be surprised if it is there and I've missed it.
I have a multi-region model defined by several cellZones. I'd like to set initial field values for each zone.
I have unresolved installation issues with installing swak4Foam with all versions of OpenFOAM (separate threads). I have successfully installed OpenFOAM V1912 and it would be terrific if I could accomplish the same field initialization with the setExprFields utility and forget about attempting to install swak4Foam.
Thanks,
Jeff
stewaj5 is offline   Reply With Quote
cellzones, funkysetfields, openfoam v1912, setexprfields, swak4foam
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 07:30
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 05:40
Journal file error magicalmarshmallow FLUENT 3 April 4, 2014 12:25
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
