[cfMesh] surface patches feature edges not preserved
Old   April 8, 2019, 11:55
Default surface patches feature edges not preserved
robboflea is on a distinguished road
Hi all,
I am using cfmesh since a few days and I am having an issue with the shape of feature edges on surface patches.
My domain is very simple. It's basically a parallelepiped with a rectangular inlet on a part of a face and a rectangular outlet on a part of another face.
I am having an issue with the conservation of the shape of the inlet and outlet patches after meshing. I did run:
surfaceFeatureEdges -angle 45 domain.stl domain.fms
this runs correctly. The feature edges are correctly recognized and I can see them in paraFOAM. The issue is that, while right angles are conserved in the mesh for all the edges of the parallelepiped, they are not preserved at the inlet and outlet boundaries. Below you can see an image of the inlet patch after meshing.
Anyone has any idea why this is happening? While trying to debug the meshing process using workflowControls I can see that the first problems start to arise after the surface projection step.
Thanks a lot for the help!
robboflea is offline   Reply With Quote
Old   May 16, 2019, 03:24
Kmeti Rao
Krao is on a distinguished road
Hi Robboflea,
Can you please post your meshDict, it looks like the refinements at the edges are not defined. If you want to have sharp edges without defining any refinement, you can use surfaceAutoPatch. If you have already solved your problem please let me know your solution, so that it can be impleamented in the future work. Thank you.
Krao is offline   Reply With Quote
Old   March 3, 2020, 05:23
Joćo Duarte Miranda
JoaoDMiranda is on a distinguished road
Hello.
I am facing a similar problem.
Did you find a solution?
Thanks a lot
JoaoDMiranda is offline   Reply With Quote
Old   June 14, 2020, 11:52
Charlie Marshall
charlliemarshalll is on a distinguished road
got the same problem, the inlet / outlet shapes are not preserved. I transferred the .obj files created by FreeCAD
charlliemarshalll is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[OpenFOAM] Offset when displaying Feature Edges with Paraview cutter ParaView 0 December 12, 2014 09:06
[mesh manipulation] Sharp edge problem on concave patches using polyDualMesh without error keepfit OpenFOAM Meshing & Mesh Conversion 1 November 25, 2014 14:28
[snappyHexMesh] Problem with Sanpper, surface still Rough Zephiro88 OpenFOAM Meshing & Mesh Conversion 7 November 5, 2014 12:05
[snappyHexMesh] problems using snappyHexMesh 2.1.0 on a supercomputer Sunxing OpenFOAM Meshing & Mesh Conversion 9 September 20, 2014 09:30
