[swak4Foam] Installing swak4foam on OpenFOAM 19.10 (Windows) |
July 27, 2020, 15:11 |
Mohammad Khojastehmehr
Rep Power: 5 |
Hey everybody! I hope you're doing fine!
Can anyone help me with installing swak4foam on OpenFOAM 19.10 (Windows)? I have downloaded this version from cfdsupport.com and I'm not quite sure whether or not it is possible to install swak4foam on this version. I've seen the relevant threads but It seems that most of the users have their OpenFOAMs installed on Ubuntu. Should I try installing OpenFOAM with Windows subsystem for Linux to have swak4foam? if this is the case, which version should I download to be able to use this library? Thank you so much! Mohammad |
August 6, 2020, 03:01 |
Petros Ampatzidis
Rep Power: 7 |
Hi Mohammad,
If you want to work in Windows then you either set up a Linux virtual machine or you use the Windows Subsystem for Linux (WSL). I am using the latter with Ubuntu 18.04 LTS and OpenFOAM v2006. The develop branch of swak4Foam compiles perfectly. Best, Petros |
August 7, 2020, 07:15 |
#3 | |
Rep Power: 5 |
Thank you so much. I was trying to run from using WSL as I'm not comfortable with Linux commands! Seems I have no other choice! |
June 21, 2022, 01:05 |
Hi petros,
Can you share the link to download the swak4foam utility here? Thanks and regards |
June 21, 2022, 05:23 |
#5 | |
Petros Ampatzidis
Rep Power: 7 |
swak4Foam on OpenFoam-v2006? Note, though, that it's been a while since the last time I tried to install swak4Foam. Hope this helps. P. |
swak4foam |
[Other] How to install OpenFOAM under Windows? | lzgwhy | OpenFOAM Installation | 19 | October 7, 2023 04:27 |
[OpenFOAM.com] Installing OpenFOAM on secondary drive | CronusX | OpenFOAM Installation | 4 | June 25, 2020 05:04 |
[Other] Installing OpenFoam on Windows 7, 32 bit Operating System | Khan82 | OpenFOAM Installation | 5 | April 22, 2017 07:43 |
installing openfoam windows 7 | Rasouli.majid | OpenFOAM | 1 | March 31, 2012 02:10 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
