[ImmersedBoundary] Problems when running potentialFoam in foam-extend 4.1 by using IBM |
Yateng Qiao
Rep Power: 3 ![]() |
Hi everyone,
I'm going to simulation a 3D helix rotating in the fluid domain by using IBM in foam-extend 4.1. I used movingCylinderInChannelIcoFine case for reference, but in the Z direction the mesh cell is set to be 1 in blockMeshDict. When I set 100 cells in Z direction. The error appears in the log.potentialFoam as follows: Create mesh for time = 0 153 154 155 156 --> FOAM FATAL ERROR: 157 Error in point ordering: mixed used and unused points at the end of point list.158 Last used point: 0 (-0.02 -0.02 0.005) 159 First unused point: 1 (-0.0198667 -0.02 0.005) 160 and point 1 (-0.0198667 -0.02 0.005) is used by a live face. 161 Face 0 4(1 302 60803 60502) with points 4((-0.0198667 -0.02 0.005) (-0.0198667 162 Done. 163 164 From function void polyMesh::initMesh() 165 in file meshes/polyMesh/polyMeshInitMesh.C at line 166. 166 167 FOAM aborting I'm not sure if the IBM in foam-extend can simulate the 3D case. I am struggled with this error for several days. ![]() |
Hrvoje Jasak
Rep Power: 33 ![]() |
Looks like a broken mesh; can you try to run something without IBM?
Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
Yateng Qiao
Hi hjasak,
Thanks for your reply. I run blockMesh, when I set the Z direction mesh to 1, the potentialFoam run correctly, when I set the Z direction mesh >1, the same error appears. Thanks! |
Periodic B.C. in Foam extend IBM | Jiashun | OpenFOAM | 0 | March 12, 2022 06:58 |
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 04:20 |
[swak4Foam] undefined symbols in .so libraries when compiling swak4foam 0.4.2 on foam extend 4.1 | mAlletto | OpenFOAM Community Contributions | 3 | August 29, 2018 06:02 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
