[waves2Foam] Having difficulty setting up wave gauges |
#1 | |||||
Wangh
Rep Power: 3 ![]() |
Hi everyone,
I am having some issues with setting up wave gauges using waves2Foam. I am new to waves2Foam and I want to set up wave gauges in my case. I have done the following: 1. Copied the constant/probesDefinitions from the wave flume tutorial to my constant folder; 2. Added the following to my controlDict file: Quote:
My probesDefinitions, controlDict, and Allrun are shown below: Quote:
Narayan Kumar
Would you like to do it step-by-step manually without Allrun?
May be you will be able to find the issue |
Wangh
Marion Sant
Rep Power: 2 ![]() |
#5 | |
Wangh
I managed to resolve this issue by linking the wavesFoam library. You can do this by adding the following code to your controlDict: Code:
functions { libs ("libwaves2FoamSampling.so"); #includeIfPresent "../waveGaugesNProbes/surfaceElevationAnyName_controlDict"; } |
#6 | |
Marion Sant
Narayan Kumar
#8 | |
Marion Sant
Have you ever used the cnoidalFirst wave theory in waves2foam? I'm trying to run a simulation with that and the setWaveFields fails. I'll attach a folder with the log file and my setWaveField file if you have any clue! |
#9 |
Wangh
Hi edo2822:
I'm sorry to tell you that I have never used elliptical cosine waves, but I see that you are using version 2206. Have you tried lower versions, such as 1912, I really don't know about gabc. Good luck! |
wave guage. waves2foam |
Does the default wall in Fluent reflects 100% acoustic wave energy? | czx0415 | FLUENT | 4 | April 8, 2023 16:36 |
How to Install Numerical Wave and Pressure Gauges in the Numerical Wave Tank? | mushtak | Main CFD Forum | 0 | November 2, 2020 02:34 |
[OLAFLOW] The height of wave generated by OF1806 is too small compared to theorectical wave | Robin86 | OpenFOAM Community Contributions | 5 | December 9, 2018 20:20 |
[IHFOAM] The height of wave generated by OF1806 is too small compared to theorectical wave | Robin86 | OpenFOAM Community Contributions | 0 | December 6, 2018 21:20 |
[waves2Foam] Stokesfirst wave profile asymetrical against the still water level?? | zhxter | OpenFOAM Community Contributions | 2 | March 23, 2015 12:08 |
