[waves2Foam] waveFoam: command not found
Old   February 19, 2024, 09:49
Default waveFoam: command not found
Marion Sant
edo2822 is on a distinguished road
Hi all.
I finally succesfully compiled waves 2 foam with Ubuntu 20.04 and Openfoam2206.
The compilation show this error which makes me unable to run waveFoam:
g++ -std=c++14 -m64 -pthread -DOPENFOAM=2206 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I/usr/lib/openfoam/openfoam2206/applications/solvers/multiphase/VoF -I/usr/lib/openfoam/openfoam2206/src/phaseSystemModels/twoPhaseInter/incompressibleInterPhaseTransportModel/lnInclude -I/usr/lib/openfoam/openfoam2206/src/phaseSystemModels/twoPhaseInter/VoFphaseIncompressibleTurbulenceModels/lnInclude -I/usr/lib/openfoam/openfoam2206/src/finiteVolume/lnInclude -I/usr/lib/openfoam/openfoam2206/src/meshTools/lnInclude -I/usr/lib/openfoam/openfoam2206/src/sampling/lnInclude -I/usr/lib/openfoam/openfoam2206/src/dynamicFvMesh/lnInclude -I/usr/lib/openfoam/openfoam2206/src/transportModels -I/usr/lib/openfoam/openfoam2206/src/transportModels/incompressible/lnInclude -I/usr/lib/openfoam/openfoam2206/src/transportModels/interfaceProperties/lnInclude -I/usr/lib/openfoam/openfoam2206/src/transportModels/twoPhaseMixture/lnInclude -I/usr/lib/openfoam/openfoam2206/src/TurbulenceModels/turbulenceModels/lnInclude -I/usr/lib/openfoam/openfoam2206/src/TurbulenceModels/incompressible/lnInclude -I/usr/lib/openfoam/openfoam2206/src/TurbulenceModels/phaseIncompressible/lnInclude -I/usr/lib/openfoam/openfoam2206/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/home/edoardoforte/OpenFOAM/edoardoforte-v2206/applications/utilities/waves2Foam/src/waves2Foam/lnInclude -I/home/edoardoforte/OpenFOAM/edoardoforte-v2206/applications/utilities/waves2Foam/src/waves2FoamGABC/lnInclude -I/home/edoardoforte/OpenFOAM/edoardoforte-v2206/applications/utilities/waves2Foam/src/waves2FoamSampling2206/lnInclude -I/usr/include -DOFVERSION=2206 -DEXTBRANCH=0 -DOFPLUSBRANCH=1 -DXVERSION=0 -iquote. -IlnInclude -I/usr/lib/openfoam/openfoam2206/src/OpenFOAM/lnInclude -I/usr/lib/openfoam/openfoam2206/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/waveFoam.o -L/usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/lib \
-lfiniteVolume -lfvOptions -lmeshTools -lsampling -ldynamicFvMesh -lincompressibleTransportModels -linterfaceProperties -limmiscibleIncompressibleTwoPhaseMixture -ltwoPhaseProperties -lturbulenceModels -lincompressibleTurbulenceModels -lwaveModels -lVoFphaseTurbulentTransportModels -lincompressibleInterPhaseTransportModels -L/home/edoardoforte/OpenFOAM/edoardoforte-v2206/platforms/linux64GccDPInt32Opt/lib -lwaves2Foam -lwaves2FoamGABC -lwaves2FoamSampling -L/usr/lib64 -lgsl -lgslcblas -lOpenFOAM -ldl \
-lm -o /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/waveFoam
/usr/bin/ld: cannot open output file /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/waveFoam: Permission denied
collect2: error: ld returned 1 exit status
make: *** [/usr/lib/openfoam/openfoam2206/wmake/makefiles/general:150: /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/waveFoam] Error 1
The other solvers like porousWaveFoam seem to work properly.
What could be the cause of the problem?
I will attach folders with waves2foam Allwmake.log file and the standing wave log files.
Thanks to anyone who is willing to help!
edo2822 is offline   Reply With Quote
Old   February 19, 2024, 12:35
Default Solution
Marion Sant
EDIT: For anyone who should face this problem.
Coding sudo chown -R "$USER:" /path/to/the/directory in the terminal before doing ./Allwmake should solve the problem
[RapidCFD] Discussion thread on how to install and use RapidCFD newoscar OpenFOAM Community Contributions 88 May 17, 2024 09:39
Gmsh installation on terminal help spitfire Main CFD Forum 4 July 27, 2017 15:11
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 01:36
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
