[waves2Foam] Porous rubble mound PorousWaveFoam |
Marion Sant
Rep Power: 2 ![]() |
Hi all!
I'm trying to simulate a wave hitting a composite breakwater with waves2foam. The breakwater caisson can easily be removed with snappyHexMesh from the mesh. The rubble mound on the other hand, is porous and formed by multiple layers with different porosity. I have a few questions on how to set this case: -porous zones can be defined in the blockMesh dictionary and then a porosityZones dictionary in the constant folder. However, when we define the boundary faces of the porous zone in the blockmeshdict, which boundary type should they be? They are internal faces and should simply act as internal faces delimiting a porous zone. If nothing is specified, they are assigned as empty boundary type. Whych boundary should they be? - I tried the case with a rubble mound formed by a single hexahedral block and it works fine (although I don't know which boundary type to set for the boundary face of the porous zone), but when I want to try a realistic trapezoidal shape of the rubble mound, how can I do that? I tried to shape the rubble mound as an hexahedral and two prisms to have the trapezoidal shape. The geometry is created successfully, however the mesh inside the two prisms is really nonsense and cause problems to the simulation. Does anyone have experience with similar cases? Thanks |
sebastiaan bors
Rep Power: 8 ![]() |
Hey,
Although I am sure there is a way to create your mesh such that the interface between porous region and non porous region aligns with internal cell faces, I am not sure it is required. I have used the method whereby you create your mesh solely based on the solid regions with optional refinement near the porous interface and subsequently set the cell region containing the rubble to a porous zone by first using topoSet and then setsToZones. For example: the content in your topoSetDict for creating a cellSet for the armour layer from defined by an stl geometry might look like this: Code:
actions ( // Load initial cellSet { name armourLayer; type cellSet; action new; source surfaceToCell; file "./constant/triSurface/armour_layer.stl"; fileType stl; outsidePoints ($pointInMesh); // definition of outside includeCut true; // cells cut by surface includeInside true; // cells not on outside of surf includeOutside false; // cells on outside of surf nearDistance -1; // cells with centre near surf // (set to -1 if not used) curvature -100; // cells within nearDistance // and near surf curvature // (set to -100 if not used) } ); Again, this does not result in a transition between porous and non-porous regions that aligns perfectly with the design geometry. You could combine this with your blockmesh approach where you combine everything into one region, after which the transition should be as you want it. If anyone knows of a way to achieve the same effect without explicitly creating the blockmesh such that it aligns with the design interface, I would be interested as well. Hope this helps, |
#3 | |
Marion Sant
Dear Sebastiaan, Thank you for your reply! This seems to work for one single porous zone! I will try with more porous zones ![]() Last edited by edo2822; March 31, 2024 at 09:59. |
Thermal non-equilibrium porous media model with conjugate heat transfer | Hexahedron | FLUENT | 9 | February 22, 2023 02:55 |
conventional rubble mound breakwater 3D model design | ewissmach | Main CFD Forum | 0 | August 16, 2022 15:26 |
Properties as a function of space/cellzone – porous region | absorbedsponge | OpenFOAM Pre-Processing | 0 | September 29, 2021 14:59 |
Porous Media Zone Thickness | TheKitchenCleaner | FLUENT | 0 | October 5, 2020 00:42 |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 04:09 |
