[swak4Foam] for faceZones
Old   August 30, 2011, 09:07
Default for faceZones
Andrea Pasquali
andrea.pasquali is on a distinguished road
I'd like to calculate the mass flow throgh a faceZone.
I tried first the function in OpenFOAM 2.0 sum(phi) but it calculates the mass flow adding the flux phi without taking in account the normal of the face. I think it is not correct.
After I tried swak4Foam, which does sum(phi*flip()). This is correct but my problem is:
- I got the faceZones whit the snappy
- the faceZones are written into faceZones file directly after snapppy. For some I can find the flip field written, for other no...
- if I use also the swak4Foam I got the correct mass flow for some faceZones and incorrect for others
My question are:
- is it possible to have the correct normals by OpenFOAM?
- I tried also to rewrite the faceZones set, and then to rewirte the file faceZones with the command setsToZones (without the -noFlipMap flag), but I got error and suggestion to use -noFlipMap
Now I solved the problem calculating the faces normals myself, but I'id be very glad if someone can suggest me the correct way to use the OpenFOAM / swak4Foam functions.
Thanks
Andrea Pasquali
andrea.pasquali is offline   Reply With Quote
Old   August 30, 2011, 09:27
Assistant Moderator
Bernhard Gschaider
Originally Posted by andrea.pasquali View Post
My question are:
Thanks
Calculating the flip-map is not completely trivial (although doable - I did something similar in calcMassFlow back in the day) and not even necessarily an operation that gives a unique result.
If you have a cellZone/cellSet that is on either side of the faceSet/faceZone then you might be in business. The convention of setsToZones is that if it finds a cellSet fooSlaveCells then it uses those to calculate the flip-map of the faceZone foo. You'll just have to provide that cellSet (by renaming, converting from faceZone etc).
Old   August 30, 2011, 09:34
Andrea Pasquali
Hi Bernhard,
Thank you for your reply.
I don't know if I understood well... but during my snappy I use some opened stl as internalFaces (or faceZones) to have then the flux phi on those.
The snappy routine create also a cellZone with the same name of the faceZone but it's empty!
How could I do? If I use a closed stl the mass flow would be 0
Andrea
Andrea Pasquali
Old   August 30, 2011, 11:24
Assistant Moderator
Bernhard Gschaider
Hi Bernhard,
Andrea
I'm not a snappy-expert, but my guess is that it creates an empty cellZone either because the shape ist not closed or because it has not been defined which side of the shape is "inside".
Maybe you "splitMeshRegions -makeCellZones -blockedFaces" helps you
