[swak4Foam] Scale discrete inlet velocity profile with groovyBC
Old   May 28, 2010, 11:13
Default Scale discrete inlet velocity profile with groovyBC
cboss is on a distinguished road
for an inlet patch with approximately 3000 faces I have a discrete profile for inlet velocity. Putting these values in the U file sets a velocity vector to every single face.
Generally setting an inlet velocity profile for a compressible flow will not exactly give a desired mass-flow. So I tried to scale the velocity field with groovyBC, to get an defined mass-flow.
3000 faces lead to 3 vectors (u, v, w) of length 3000. Trying to read such a vector with groovyBC gives the error:
string "u=(-62.420493,-52.599637,-51.460724,-60.386578,-58.347571,-61.218533,-57.528353,..."
is too long (max. 1024 characters)
Is there a way to scale such long vectors with groovyBC?
Thanks and a nice weekend,
Christoph
cboss is offline   Reply With Quote
Old   June 20, 2010, 13:02
Default GroovyBC in cirdulation geometry
Joseph
tamsilian is an unknown quantity at this point
Hi sir/Madam
I simulated circular geometry as polymer fluid in around of rotating screw in extruder. I possess some problem to describe boundary condition for movingWalls. I want to use groovyBC to specify velocity vectors (Ux,Uy,Uz) in movingWalls BC where is depend on places in face. I cannot define velocity function with C++ rules. Could you help me about coding this BC as C++ rules? Content of U file, 0file are presented as follow:
Tnx in avanced your help
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (0 0 10);
movingWalls
Velocity vectors calculated by (-0.0346*sin(teta) ,0.0346*cos(teta),0.4764) where angle range is between 0 to 2pi.
fixedWalls
type fixedValue;
value uniform (0 0 0);
outlet
type zeroGradient;
tamsilian is offline   Reply With Quote
[swak4Foam] Inlet velocity profile for turbulent pipe flow using swak4Foam zordiack OpenFOAM Community Contributions 5 February 23, 2016 01:52
simpleFoam: Non-uniform mesh near inlet & outlet causes incorrect velocity profile? Zaphod'sSecondHead OpenFOAM Running, Solving & CFD 0 January 28, 2015 05:17
Strange velocity profile at the inlet for a flow inside a cylindrical pipe michmich OpenFOAM Running, Solving & CFD 0 July 2, 2012 03:37
Export & Import Velocity profile as Inlet eRzBeNgEl STAR-CCM+ 6 March 26, 2012 05:16
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
