[swak4Foam] FunkySetfields +InterFOAM
Old   February 22, 2011, 16:55
Default FunkySetfields +InterFOAM
Ramesh Yapalparvi
yapalparvi is on a distinguished road
Hi all,
I have been using funky setfeilds+interfoam to simulate droplet impingement on to a free surface. I create a circular gamma field using funkySetfields. As I run my simulation, the droplet impacts the free surface vertically. How do I modify so that the droplet impinges the free surface obliquely?I tried changing the acceleration due to gravity by multiplying it with pi/4, rotated the mesh by pi/4 etc but nothing worked. Any help would be appreciated
Cheers,
Ramesh
yapalparvi is offline   Reply With Quote
Old   February 23, 2011, 02:45
Bernhard
Bernhard is on a distinguished road
I think the correct physics is to give bubble an initial horizontal velocity. Changing the direction of gravity will obviously also change the orientation of your free surface, which is probably not what you want.
Bernhard is offline   Reply With Quote
Old   February 23, 2011, 05:52
Ramesh Yapalparvi
Thanks Bernhard. How do I do this?.
Old   February 23, 2011, 09:21
Bernhard
Did you try funkySetFields?
Old   February 23, 2011, 21:15
Ramesh Yapalparvi
Yes, I use the following commands
funkySetFields -time 0 -field U -expression 'vector(0,0,0)' -keepPatches
funkySetFields -time 0 -field gamma -expression 0 -keepPatches
funkySetFields -time 0 -field gamma -expression 1 -keepPatches -condition "pow(pos().x-0.292,2)+pow(pos().y-0.534,2)<pow(0.05,2)"
funkySetFields -time 0 -field gamma -expression 1 -keepPatches -condition "pos().x <=0.584 && pos().y <=0.05"
attached are two picture. Initial shows the intial gamma field created using funkySetfields using the above commands.
If my velocity vector is (0,0,0) the droplet falls vertically.
I changed the velocity vector (0.71, 0,0). Although it starts to impact obliquely(02sec_field.jpg) , the problem I have is even the liquid layer at the bottom also changes. Please let me know how to fix this
Old   February 24, 2011, 02:50
Bernhard
Of course only set the initial velocity inside the bubble, with the same expression you used to set the gamma-field.
Old   February 24, 2011, 05:05
Ramesh Yapalparvi
Thanks. How do I set the velocity only inside the bubble?
Old   February 24, 2011, 07:16
Bernhard
By using what you already know from funkySetFields? If you can set gamma inside your bubble, you can probably do it for U as well, right?
Old   February 25, 2011, 04:25
Ramesh Yapalparvi
Thanks for your help. It worked..
Old   February 27, 2011, 14:45
Ramesh Yapalparvi
suppose I replace this liquid droplet with a solid object How do I go about solving this type of problem. Ofcourse, this solid object is in air and there is a layer of liquid at the bottom
Old   February 28, 2011, 04:50
Bernhard
Then your situation is completely different. You cannot use interFoam, and I don't know whether it is possible in OpenFOAM to solve this kind of problem. At least you have to deal with dynamic meshes and stuff like that.
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
interFoam (HELYX-OS) pressure boundary conditions SFr OpenFOAM Running, Solving & CFD 8 June 23, 2016 16:36
k-e & GAMG interFoam Schemitisation Stability Issue JFM OpenFOAM Running, Solving & CFD 3 December 1, 2015 05:58
[swak4Foam] InterFoam + FunkySetFields - Initial phase function of the given volume pedrojrebelo OpenFOAM Community Contributions 0 February 12, 2015 18:03
interFoam in parallel gooya_kabir OpenFOAM Running, Solving & CFD 0 December 9, 2013 05:09
