July 3, 2011, 12:09 |
pyFoamPotentialRunner issue!
Hi experts,
I have a problem with pyFoamPotentialRunner.py. I use it in pitzDaily tutorials but after it sets case for potential solver it crashes! here is the error: Code:
Setting system-directory for potentialFoam Traceback (most recent call last): File "/usr/local/bin/pyFoamPotentialRunner.py", line 5, in <module> PotentialRunner() File "/usr/local/lib/python2.6/dist-packages/PyFoam/Applications/PotentialRunner.py", line 42, in __init__ nr=1) File "/usr/local/lib/python2.6/dist-packages/PyFoam/Applications/PyFoamApplication.py", line 155, in __init__ result=self.run() File "/usr/local/lib/python2.6/dist-packages/PyFoam/Applications/PotentialRunner.py", line 128, in run pRefValue=self.opts.pRefValue) File "/usr/local/lib/python2.6/dist-packages/PyFoam/Applications/PotentialRunner.py", line 148, in __init__ pot=SolutionDirectory(path.join(pre,"potentialFoam","cylinder"),archive=None,paraviewLink=False) File "/usr/local/lib/python2.6/dist-packages/PyFoam/RunDictionary/SolutionDirectory.py", line 53, in __init__ self.reread() File "/usr/local/lib/python2.6/dist-packages/PyFoam/RunDictionary/SolutionDirectory.py", line 321, in reread if not force and stat(self.name)[ST_CTIME]<=self.lastReread: OSError: [Errno 2] No such file or directory: '/usr/lib/OpenFOAM-1.6-ext/tutorials/basic/potentialFoam/cylinder' |
July 4, 2011, 14:52 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Bernhard |
July 4, 2011, 16:06 |
#3 | |
You are right about different tutorials location; I fixed that and I got some results but after that I faced 2 warnings, maybe these are not very important but could you please have a look: Code:
Setting system-directory for potentialFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-ext Exec : potentialFoam -case . -writep Date : Jul 05 2011 Time : 00:26:48 Host : amir PID : 5198 Case : /home/amir/OpenFOAM/amir-1.6-ext/run/myRun/simpleFoam/pitzDaily nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 // using new solver syntax: p { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0.01; } // using new solver syntax: U { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } // using new solver syntax: k { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } // using new solver syntax: epsilon { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } // using new solver syntax: R { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } // using new solver syntax: nuTilda { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } Reading field p Reading field U Calculating potential flow DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00951731, No Iterations 172 continuity error = 0.166533 Interpolated U error = 0.000116283 mag(U): max: 27.0928 min: 0.125791 ExecutionTime = 0.23 s ClockTime = 0 s End PyFoam WARNING on line 196 of file /usr/local/lib/python2.6/dist-packages/PyFoam/Applications/PotentialRunner.py : Trigger called: Resetting fvSchemes and fvSolution Killing PID 5197 PyFoam WARNING on line 232 of file /usr/local/lib/python2.6/dist-packages/PyFoam/Execution/FoamThread.py : Process 5197 was already dead Getting LinuxMem: [Errno 2] No such file or directory: '/proc/5197/status' |
July 4, 2011, 18:26 |
#4 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The second warning means "your computer is too fast". Once the process that should supervise the solver had started up the solver itself was already finished. No problem here. Solution: get a slower machine |
July 4, 2011, 20:00 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Solution #2: Increase mesh resolution by 10x or 100x
July 5, 2011, 02:29 |
#6 | |
Thank you very much for your helps |
rhoCentralFoam inviscid airfoil issue (Foam::error::printStack(Foam::Ostream&) at ??) | kmkb21 | OpenFOAM Running, Solving & CFD | 1 | March 1, 2018 01:07 |
Convergence issue in natural convection problem | chrisf90 | FLUENT | 5 | March 5, 2016 08:30 |
Strange issue while launching ANSYS workbench in CentOS 6.4 | Philip_C | ANSYS | 11 | August 29, 2013 06:44 |
CyclicAMI Issue In OpenFOAM 2.2.0 | prasant | OpenFOAM Running, Solving & CFD | 17 | March 16, 2013 02:00 |
Meshing related issue in Flow EFD | appu | FloEFD, FloWorks & FloTHERM | 1 | May 22, 2011 08:27 |
