[PyFoam] Problems with installing PyFoam
Like Tree1Likes
Old   March 19, 2012, 10:37
Default Problems with installing PyFoam
Christoph_84 is on a distinguished road
Hallo,
I'm trying to install PyFoam, I use OpenFoam 1.7.1 on OpenSuse 11.4. I tried it several times , with the description of the Wiki, as user and as root. Some applications work others not. One imported Application is pyFoamDisplayBlockMesh.py but I got that Error:
Trying VTK implementation from Paraview
 Traceback (most recent call last):
   File "/home/nonroot/my_python/bin/pyFoamDisplayBlockMesh.py", line 5, in <module>
     from PyFoam.Applications.DisplayBlockMeshQt import DisplayBlockMesh
   File "/usr/local/lib/python2.7/site-packages/PyFoam/Applications/DisplayBlockMeshQt.py", line 30, in <module>
     doImports()
   File "/usr/local/lib/python2.7/site-packages/PyFoam/Applications/DisplayBlockMeshQt.py", line 28, in doImports
     error("Error while importing modules:",e)
   File "/usr/local/lib/python2.7/site-packages/PyFoam/Error.py", line 49, in error
     raise FatalErrorPyFoamException(*text)
 PyFoam.Error.FatalErrorPyFoamException: FatalError in PyFoam: 'PyFoam FATAL ERROR on line 28 of file /usr/local/lib/python2.7/site-packages/PyFoam/Applications/DisplayBlockMeshQt.py: Error while importing modules: No module named paraview'
Can anybody help me?
Christoph_84 is offline   Reply With Quote
Old   March 19, 2012, 11:14
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by Christoph_84 View Post
Hallo,
     doImports()
When you look at the output of pyFoamVersion.py you will see that VTK (a requirement for that utility) is missing. You'll have to install that (make sure that the python and the QT-bindings are installed if your system has them in separate packages). While you're add it: check the output of pyFoamVersion.py for PyQT4. If that is missing: it is required too
gschaider is offline   Reply With Quote
Old   March 20, 2012, 03:16
Thank you Bernhard,
I installed the missing libraries an now it works and I can starting to discover PyFoam!
Christoph
Old   March 20, 2012, 05:26
Assistant Moderator
Bernhard Gschaider
Thank you Bernhard,
Christoph
I never stressed those libraries as requirements as they're not necessary for the majority of the tools
Old   November 28, 2012, 11:09
Default needs help to find my mistake
RomW is on a distinguished road
Hello everyone,
I am struggling to get the following command to behave.
pyFoamDisplayBlockMesh.py constant/polyMesh/blockMeshDict
I get:
Using system-VTK
PyFoam WARNING on line 282 of file /usr/local/lib/python2.7/dist-packages/PyFoam/Applications/DisplayBlockMeshQt.py : While reading constant/polyMesh/blockMeshDict this happened: 'patches'
File "/usr/local/bin/pyFoamDisplayBlockMesh.py", line 11, in <module>
DisplayBlockMesh()
File "/usr/local/lib/python2.7/dist-packages/PyFoam/Applications/DisplayBlockMeshQt.py", line 744, in __init__
nr=1)
File "/usr/local/lib/python2.7/dist-packages/PyFoam/Applications/PyFoamApplicationQt4.py", line 37, in __init__
exactNr=exactNr)
File "/usr/local/lib/python2.7/dist-packages/PyFoam/Applications/PyFoamApplication.py", line 155, in __init__
result=self.run()
File "/usr/local/lib/python2.7/dist-packages/PyFoam/Applications/PyFoamApplicationQt4.py", line 59, in run
self.setupGUI()
File "/usr/local/lib/python2.7/dist-packages/PyFoam/Applications/DisplayBlockMeshQt.py", line 751, in setupGUI
self.dialog=DisplayBlockMeshDialog(bmFile)
File "/usr/local/lib/python2.7/dist-packages/PyFoam/Applications/DisplayBlockMeshQt.py", line 283, in __init__
raise e
I think that I installed all the required libraries because when I run:
pyFoamVersion.py
I get the following output:
PYTHONPATH: not set
OpenFOAM (2, 0, 1) of the installed versions []
pyFoam-Version: 0.5.5
Configuration search path: [('file', '/etc/pyFoam/pyfoamrc'), ('directory', '/etc/pyFoam/pyfoamrc.d'), ('file', '/home/romain/.pyFoam/pyfoamrc'), ('directory', '/home/romain/.pyFoam/pyfoamrc.d')]
Configuration files (used): []
Installed libraries:
Gnuplot : Yes
ply : No Not a problem. Version from ThirdParty is used
Numeric : No Not a problem if numpy is present
numpy : Yes
matplotlib : Yes
psyco : No Not a problem. Acceleration not possible
hotshot : Yes
profile : Yes
cProfile : Yes
PyQt4 : Yes
PyQt4.Qwt5 : No Only an alternate plotting back-end
vtk : Yes
Tkinter : Yes
mercurial : Yes
PyQt4 -> checked
vtk -> checked
The only issue seems to be the PYTHONPATH. Does anyone now what I have to set in my ~/.bashrc?
RomW is offline   Reply With Quote
Old   November 28, 2012, 13:59
Assistant Moderator
Bernhard Gschaider
Originally Posted by RomW View Post
Hello everyone,
I get:
pyFoamVersion.py
PyQt4 -> checked
vtk -> checked
Well. The error message means that the problem occurred during the reading of the blockMeshDict.
vtk and PyQT4 are there (according to pyFoamVersion) and have already been loaded during that state of the problem. You don't have to set the PYTHONPATH (this output is mainly there to find out whether other libraries than the system versions are used).
You followed the first rule of pyFoam-Error-Reporting: pyFoamVersion. And this leads to the probable problem: your version is rather old (0.5.5) and was definitely released before 2.0. In that version (at least as far as I remember) the format of the blockMeshDict changed (especially with the patches). Current versions are tolerant about this but 0.5.5 can't possibly know about this.
Solution: install the current pyFoam-version (0.5.7). If the version you're using is system-wide installed and you can't easily replace it, then install it locally in your account and THEN you have to set PYTHONPATH
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   November 29, 2012, 06:20
Thank you very much Bernhard. I did not check there was a newer version of PyFoam before installing PyFoam 0.5.5, big mistake, thank you for pointing this out.
When I install PyFoam 0.5.7 the same way I installed the previous version, when I run:
pyFoamVersion.py
I still get as output that I am using PyFoam 0.5.5 version
Do you know how I could overwrite it?
Thank you very much
Rom
Old   November 29, 2012, 09:45
Assistant Moderator
Bernhard Gschaider
pyFoamVersion.py
Thank you very much
Rom
Did you do it like this:
http://openfoamwiki.net/index.php/Co...a_regular_user
Probably you've got to set PYTHONPATH (and also PATH) to you installation so that it "shadows" the system-installation
Old   November 29, 2012, 11:46
After setting the PYTHONPATH (and also PATH), it worked just fine.
Amazing piece of software, really thanks Bernhard for simplifying OpenFOAM with PyFoam.
Old   November 30, 2012, 09:59
Sorry Bernhard to ask so many basic questions, but when i run pyFoamPlotRunner.py, i actually do not get any plots, is that behaviour normal?
Old   November 30, 2012, 12:20
Assistant Moderator
Bernhard Gschaider
No it is not. Usually the first plot windows should pop up once pyFoam found the second timestep in the output. It does so by looking for the usual time string "Time = x.xxx" in the output. If that is different for a solver (happens) another pattern can be specified
Old   January 1, 2013, 08:42
DDB
DDB
DDB is on a distinguished road
Hi, I am very new to all this (inc forums) and very frustrated!!
I can't get pyFoamDisplayBlockMesh.py constant/polyMesh/blockMeshDict to work, so any help would be gratefully appreciated!
gives
File "/usr/bin/pyFoamDisplayBlockMesh.py", line 5, in <module>
File "/usr/lib/python2.7/site-packages/PyFoam/Applications/DisplayBlockMeshQt.py", line 33, in <module>
doImports()
File "/usr/lib/python2.7/site-packages/PyFoam/Applications/DisplayBlockMeshQt.py", line 31, in doImports
File "/usr/lib/python2.7/site-packages/PyFoam/Error.py", line 49, in error
PyFoam.Error.FatalErrorPyFoamException: FatalError in PyFoam: 'PyFoam FATAL ERROR on line 31 of file /usr/lib/python2.7/site-packages/PyFoam/Applications/DisplayBlockMeshQt.py: Error while importing modules: No module named paraview'
and
pyFoamVersion.py
gives
Python version: 2.7.3 (default, Jul 24 2012, 10:05:38)
[GCC 4.7.0 20120507 (Red Hat 4.7.0-5)]
PYTHONPATH: /usr/lib64/python2.7/site-packages/openmpi
OpenFOAM (2, 1, 1) of the installed versions ['2.1.1']
pyFoam-Version: 0.5.7
Configuration search path: [('file', '/etc/pyFoam/pyfoamrc'), ('directory', '/etc/pyFoam/pyfoamrc.d'), ('file', '/home/natalie/.pyFoam/pyfoamrc'), ('directory', '/home/natalie/.pyFoam/pyfoamrc.d')]
Gnuplot : Yes version: 1.8
Numeric : No Not supported anymore. No need to install it
numpy : Yes version: 1.6.2
matplotlib : No Only Gnuplot-plotting possible
hotshot : Yes
profile : Yes
cProfile : Yes
PyQt4 : Yes
vtk : No Not a problem. Only used for some utilities
Tkinter : Yes version: $Revision: 81008 $
mercurial : No Not a problem. Used for experimental case handling
but
Package vtk-5.8.0-6.fc17.x86_64 already installed and latest version
Package paraview-3.14.1-3.fc17.x86_64 already installed and latest version
I have installed as root and there is nothing in my .bashrc for pyFoam...
Please help!
DDB is offline   Reply With Quote
Old   January 1, 2013, 09:25
Retired Super Moderator
Bruno Santos
Greetings DDB and welcome to the forum!
The answer was given on the second post:
[...] (make sure that the python and the QT-bindings are installed if your system has them in separate packages). While you're add it: check the output of pyFoamVersion.py for PyQT4. If that is missing: it is required too
It looks like you've got Fedora 17 installed. I think you need to install the following packages:
vtk-python vtk-qt pyqt4
Which you can install by running as root:
yum install vtk-python vtk-qt pyqt4
Best regards,
Bruno
PS: If OpenFOAM's plugins for ParaView are properly installed and you have at least OpenFOAM 2.0.0, then you can use the following command as well:
paraFoam -block
Old   January 1, 2013, 09:37
DDB
DDB
Hi wyldckat, Thank you very much for your help! It works now!
Your instructions look very different to the 2nd post though, so I am not surprised a newbie like me didn't understand!!
Old   April 27, 2013, 14:35
Default PyFoam mac displayblockmesh error
  #15
Simone Martini
simone.rowing is on a distinguished road
I have a mac lion 1.7, and recently installed OpenFOAM 2.1 with paraview 3.14.1. I am interested in using PyFoam. Already installed 0.6 using the guides on the openfoam wiki site. Unfortunately find an error which I cannot fix:
MacBook-di-Simone:cavity simomartini$ pyFoamDisplayBlockMesh.py constant/polyMesh/blockMeshDict
PyFoam WARNING on line 11 of file /usr/local/bin/pyFoamDisplayBlockMesh.py : Falling back to the old Tkinter-implementation because no PyQT4 was found
Error in /usr/local/bin/pyFoamDisplayBlockMesh.py : FatalError in PyFoam: 'PyFoam FATAL ERROR on line 29 of file /Library/Python/2.7/site-packages/PyFoam/Applications/DisplayBlockMesh.py: Error while importing modules: No module named paraview'
this props up when using the pyFoamDisplayBlockMesh.py command. I suspect the paraview path has not been set correctly. here is my bashrc commands:
alias of21='hdiutil attach "/Users/simomartini/OpenFOAM-v2.1.sparseimage" -mountpoint "$HOME/OpenFOAM" > /dev/null ; . $HOME/OpenFOAM/OpenFOAM-2.1.0/etc/bashrc'
alias paraview="/Applications/'Paraview_3.14.1.app'/Contents/MacOS/paraview"
alias emacs="/Applications/'Aquamacs.app'/Contents/MacOS/Aquamacs"
alias parax="touch case.foam && paraview --data=case.foam &"
alias paraFoam="paraFoam -builtin"
please assist on fixing this issues. also any ideas on where i could find a solution would be great. we have been looking on the forums for a day now but nothing seems to be applicable.
simone.rowing is offline   Reply With Quote
Old   April 28, 2013, 06:22
Bruno Santos
Greetings Simone and welcome to the forum!
This is roughly on section 10.4: http://openfoamwiki.net/index.php/Co...paraview-stuff
But since this installation on Mac OS X uses a pre-built ParaView version... a quick hack would be to add the following code to before or after that the code in "bashrc" that you've provided:
ParaView_DIR="/Applications/Paraview_3.14.1.app/Contents/MacOS/"
if [ "$PYTHONPATH" ]; then
    export PYTHONPATH=$PYTHONPATH:$ParaView_DIR/Utilities/VTKPythonWrapping
else
    export PYTHONPATH=$ParaView_DIR/Utilities/VTKPythonWrapping
fi
Although you need to check if these are indeed the paths you've got in your installation. I say this because I don't have a Mac to test this on
Best regards,
Bruno
Old   April 28, 2013, 17:15
Assistant Moderator
Bernhard Gschaider
else
fi
Best regards,
Bruno
I'm afraid there is no such directory in the Mac-binary (so this won't work)
In my experience the easiest way to get a VTK that works with pyFoamDisplayBlockMesh.py on a Mac is to use MacPorts. Something like
port install vtk5 +python27 +qt4_mac
should install it with python and QT-support (if you use a different python adapt it). Also use
port install py27-pyqt4
if PyQT is not yet installed
Old   May 2, 2013, 04:50
Default PyFoam
  #18
Simone Martini
this reply is in response to the last 2 posts. initially we tried wyldckat's suggestion and that got us past the paraview error provided we supplied the correct addresses for the paraview installation folder (different from the post). However we had a different PyQt4 error immediately after.
after that we tried the macports installation of PyQt4 etc... as described by gschaider, however we still get the original paraview error in this case. So far I have set pyqt4 module folder "/opt/local/share/py27-sip/PyQt4" to be added to PYTHONPATH and tried to confirm this by doing "import PyQt4" i get an error that module doesnt exist. On the internet it does say there is a support problem for PyQt4 and Mac lion OSX, so we are sort of stuck. the suggestion on the web is to fiddle with the installation package, but we're not sure how to do this. if there is any suggestion on how to do this plz help!
Old   May 4, 2013, 06:49
Assistant Moderator
Bernhard Gschaider
It shouldn't be necessary to set the PYTHONPATH ... if the pyqt4 you installed is for your currently used Python. Try the following
- Start python and on the Python-Shell try importing it: "import PyQt4"
- run pyFoamVersion.py and post the result here
Old   May 8, 2013, 15:30
Simone Martini
dear geschaider, after a bit of fiddling with the folders, we have the PyQt4 installed and able to import it in python. the vtk package must also be installed, however it shows the following erro after runnung the code "pyFoamVersion.py"
Gnuplot              :  No      Not a problem. Version from ThirdParty is used
/Applications/Paraview_3.98.1.app/Contents/Python/numpy/random/__init__.py:87: RuntimeWarning: compiletime version 2.6 of module 'mtrand' does not match runtime version 2.7
  from mtrand import *
matplotlib           :  Yes      version: 1.1.1
hotshot              :  Yes
profile              :  Yes
cProfile             :  Yes
PyQt4                :  Yes
vtk                  :  Error: Could not import vtkCommonComputationalGeometryPython
nose                 :  No      Only needed for running the unit-tests (developers only)
twisted              :  Yes      version: 11.0.0
pandas               :  No      Not yet used. Maybe handling of timelines will be reimplemented with it
scipy                :  No      Not yet used. Possibly use signal-fitting etc
not entirely sure what to do next, many thanks for the help so far.
[swak4Foam] Problems installing swak4Foam in foam-extend-4.0 on Ubuntu 16.04 jock OpenFOAM Community Contributions 12 September 6, 2019 03:27
[OpenFOAM.com] v3.0+ Problems installing on Ubuntu 16.04 Evander OpenFOAM Installation 3 March 26, 2017 14:47
[OpenFOAM.org] Problems installing OF4.1 in Kubuntu 14.04 Outbound OpenFOAM Installation 5 February 2, 2017 07:54
[foam-extend.org] Problems installing foam-extend 3.0 aylalisa OpenFOAM Installation 9 April 23, 2015 16:17
Problems installing CFX on Sun Unix Platform Haley CFX 2 November 9, 2001 09:52
