[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X
Like Tree20Likes
Old   May 19, 2013, 17:04
Simone Martini
simone.rowing is on a distinguished road
Have a look at /Users/simomartini/OpenFOAM/OpenFOAM-2.1.0/wmake/rules/darwinIntel64Gcc46 : it should be a symbolic link to the directory darwinIntel64Gcc in the same directory. The patch-program doesn't create this correctly. So if it is a plain file delete it (darwinIntel64Gcc46) and replace it with a symbolic link to the neighbour directory. Or copy the directory
I had the same problem but I solve mine with the help of Bernhard with this solution. Try this solution problably this is your problem.
rdbisme likes this.
simone.rowing is offline   Reply With Quote
Old   May 19, 2013, 20:24
rdbisme's Avatar
Ruben Di Battista
rdbisme is on a distinguished road
Ok, thanks for your answer. I was doing symlinking wrong. I removed all the files and did:
cd wmake/rules
ln -s darwinIntel64Gcc/ darwinIntel64Gcc46
this seems to have worked.
Another question: Do i have to set
 export WM_MPLIB=SYSTEMOPENMPI
rdbisme is offline   Reply With Quote
Old   May 20, 2013, 03:17
rdbisme's Avatar
Ruben Di Battista
Done compiling, in the log i still have some errors:
gccmp-4.6 -m64 -fsignaling-nans  -ftrapping-math  -Wall -O2   -fPIC -Ddarwin dirToString.c -o /Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/wmake/platforms/darwinIntel64Gcc46/dirToString
make: gccmp-4.6: No such file or directory
make: *** [/Users/#########/OpenFOAM/OpenFOAM-2.2.x/wmake/platforms/darwinIntel64Gcc46/dirToString] Error 1
gccmp-4.6 -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -DSCOTCH_RENAME_PARSER -Drestrict=__restrict -DCOMMON_TIMING_OLD -DSCOTCH_VERSION=6 -DSCOTCH_RELEASE=0 -DSCOTCH_PATCHLEVEL=0 dummysizes.c -o dummysizes -lz -lm
make[2]: gccmp-4.6: No such file or directory
make[2]: *** [dummysizes] Error 1
make[1]: *** [scotch] Error 2
make: *** [scotch] Error 2
gccmp-4.6 -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -DSCOTCH_RENAME_PARSER -Drestrict=__restrict -DCOMMON_TIMING_OLD -DSCOTCH_VERSION=6 -DSCOTCH_RELEASE=0 -DSCOTCH_PATCHLEVEL=0 ddummysizes.c -o dummysizes -lz -lm
make: *** [ptscotch] Error 2
scotchDecomp.C:132:20: fatal error: scotch.h: No such file or directory
compilation terminated.
make: *** [Make/darwinIntel64Gcc46DPOpt/scotchDecomp.o] Error 1
ptscotchDecomp.C:126:22: fatal error: ptscotch.h: No such file or directory
make: *** [Make/darwinIntel64Gcc46DPOptMACPORTOPENMPI/ptscotchDecomp.o] Error 1
$SOURCE -o Make/darwinIntel64Gcc46DPOpt/SloanRenumber.o
ld: library not found for -lboost_thread
SurfaceFeatureExtract.C:85:47: error: wrong number of template arguments (1, should be 3)
/opt/local/include/CGAL/Monge_via_jet_fitting.h:57:9: error: provided for 'template<class DataKernel, class LocalKernel, class SvdTraits> class CGAL::Monge_via_jet_fitting'
surfaceFeatureExtract.C:85:70: error: invalid type in declaration before ';' token
surfaceFeatureExtract.C:86:47: error: expected initializer before 'Monge_form'
surfaceFeatureExtract.C:148:9: error: 'Monge_form' was not declared in this scope
surfaceFeatureExtract.C:148:20: error: expected ';' before 'monge_form'
surfaceFeatureExtract.C:164:21: error: 'monge_form' was not declared in this scope
surfaceFeatureExtract.C:146:31: warning: unused variable 'monge_fit' [-Wunused-variable]
surfaceFeatureExtract.C:92:18: warning: unused variable 'd_monge' [-Wunused-variable]
It seems to have problem with scotch/ptscotch compiling. Someone can give me some directions to solve this?
Old   May 20, 2013, 10:25
Assistant Moderator
Bernhard Gschaider
That is strange. It should be gcc-mp-4.6. I don't see how the minus go missing (WM_CC is set in etc/settings/profile.sh). Maybe you changed WM_CC somewhere else in an attempt to fix things
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   May 21, 2013, 08:29
rdbisme's Avatar
Ruben Di Battista
Ok right. I had mispelled gcc-mp-4.6 in the bashrc file. Now it's correct. Recompiled, still some errors:
cp: ../bin/d[agm]*: No such file or directory
make: [install] Error 1 (ignored)
collect2: ld returned 1 exit status
make: *** [/Users/#####/OpenFOAM/OpenFOAM-2.2.x/platforms/darwinIntel64Gcc46DPOpt/lib/libSloanRenumber.dylib] Error 1
surfaceFeatureExtract.C:85:47: error: wrong number of template arguments (1, should be 3)
surfaceFeatureExtract.C:85:78: error: invalid type in declaration before ';' token
surfaceFeatureExtract.C:86:57: error: expected initializer before 'Monge_form'
make[2]: *** [Make/darwinIntel64Gcc46DPOpt/surfaceFeatureExtract.o] Error 1
make[2]: Target `/Users/######/OpenFOAM/OpenFOAM-2.2.x/platforms/darwinIntel64Gcc46DPOpt/bin/surfaceFeatureExtract' not remade because of errors.
make[1]: *** [surfaceFeatureExtract] Error 2
OpenFOAM/OpenFOAM-2.2.x/platforms/darwinIntel64Gcc46DPOpt/bin/surfaceTransformPoints
make[1]: Target `application' not remade because of errors.
make: *** [surface] Error 2
Sorry for my incapacity.
Old   May 21, 2013, 15:47
Assistant Moderator
Bernhard Gschaider
Where would that happen?
With my patches if the variable WM_USE_MACPORT is set and the MacPort-verison of boost is installed then it should use the -lboost_thread-mt library.
Anyway: this library is not essential (99% of OF will work without it)
Compiler-call would be super-helpful in this case. Anyway: for first experiments in OF this utilitiy is not required.
The last error is just a followup to the others. But I'm not sure.
Anyway: you tried to run a basic tutorial (blockMesh, setFields, interFoam) and does that work?
Old   May 21, 2013, 17:42
rdbisme's Avatar
Ruben Di Battista
Thanks for your very precious help. Anyway,
i run an incompressible tutorial and it seems to work.
This is for the not found directory. It seems to happen in the scotch directory in Thirdparty folder
cd libscotchmetis ; make        scotch && make install)
make CC="gcc-mp-4.6" SCOTCHLIB=ptscotch                        \
                    libscotchmetis.dylib
gcc-mp-4.6 -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -DSCOTCH_RENAME_PARSER -Drestrict=__restrict -DCOMMON_TIMING_OLD -fPIC -I../../include -I../libscotch -c metis_graph_order.c -o metis_graph_order.o
gcc-mp-4.6 -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -DSCOTCH_RENAME_PARSER -Drestrict=__restrict -DCOMMON_TIMING_OLD -fPIC -I../../include -I../libscotch -c metis_graph_order_f.c -o metis_graph_order_f.o
gcc-mp-4.6 -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -DSCOTCH_RENAME_PARSER -Drestrict=__restrict -DCOMMON_TIMING_OLD -fPIC -I../../include -I../libscotch -c metis_graph_part.c -o metis_graph_part.o
gcc-mp-4.6 -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -DSCOTCH_RENAME_PARSER -Drestrict=__restrict -DCOMMON_TIMING_OLD -fPIC -I../../include -I../libscotch -c metis_graph_part_f.c -o metis_graph_part_f.o
gcc-mp-4.6 -dynamiclib -undefined dynamic_lookup -o libscotchmetis.dylib metis_graph_order.o metis_graph_order_f.o metis_graph_part.o metis_graph_part_f.o
echo libscotchmetis.dylib
make[2]: `libscotchmetis.dylib' is up to date.
cp metis.h ../../include
cp libscotchmetis.dylib ../../lib
+ make prefix=/Users/rubendibattista/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0 libdir=/Users/rubendibattista/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46DPOpt/lib install
mkdir /Users/rubendibattista/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0/bin
mkdir /Users/rubendibattista/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0/include
mkdir /Users/rubendibattista/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0/share
mkdir /Users/rubendibattista/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0/share/man
mkdir /Users/rubendibattista/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0/share/man/man1
cp -f ../bin/[agm]* /Users/rubendibattista/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0/bin
cp -f ../bin/d[agm]* /Users/rubendibattista/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0/bin
This for the surfaceFeatureConvert.C
Making dependency list for source file surfaceFeatureConvert.C
SOURCE=surfaceFeatureConvert.C ;  g++-mp-4.6 -m64 -fsignaling-nans  -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100 -I/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/src/meshTools/lnInclude -I/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/src/edgeMesh/lnInclude -IlnInclude -I. -I/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude -I/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64Gcc46DPOpt/surfaceFeatureConvert.o
g++-mp-4.6 -m64 -fsignaling-nans  -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100 -I/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/src/meshTools/lnInclude -I/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/src/edgeMesh/lnInclude -IlnInclude -I. -I/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude -I/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -lpthread -L/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/platforms/darwinIntel64Gcc46DPOpt/lib/openmpi-macport -lPstream Make/darwinIntel64Gcc46DPOpt/surfaceFeatureConvert.o -L/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/platforms/darwinIntel64Gcc46DPOpt/lib \
         -lmeshTools -ledgeMesh -lOpenFOAM -ldl   -lpthread -lm -o /Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/platforms/darwinIntel64Gcc46DPOpt/bin/surfaceFeatureConvert
+ '[' -n /opt/local ']'
+ echo
+ echo 'Compiling surfaceFeatureExtract with CGAL curvature support'
+ echo
+ '[' -n 1 ']'
+ THREAD_EXTENSION=-mt
+ wmake 'ENABLE_CURVATURE=-DENABLE_CURVATURE            EXE_FROUNDING_MATH=-frounding-math            USE_F2C=-DCGAL_USE_F2C            CGAL_LIBDIR=-L/opt/local/lib            LAPACK_LIB=-llapack            BLAS_LIB=-lblas            CGAL_LIB=-lCGAL            CGAL_BOOST_LIB=-lboost_thread-mt            CGAL_MPFR_LIB=-lmpfr'
Making dependency list for source file surfaceFeatureExtract.C
SOURCE=surfaceFeatureExtract.C ;  g++-mp-4.6 -m64 -fsignaling-nans  -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100 -DENABLE_CURVATURE -frounding-math -DCGAL_USE_F2C -Wno-old-style-cast -I/opt/local/include -I/opt/local/include -I/opt/local/include -I/opt/local/include -ICGALPolyhedron -I/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/src/finiteVolume/lnInclude -I/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/src/meshTools/lnInclude -I/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/src/edgeMesh/lnInclude -I/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/src/triSurface/lnInclude -I/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/src/surfMesh/lnInclude -I/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/src/sampling/lnInclude -IlnInclude -I. -I/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude -I/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64Gcc46DPOpt/surfaceFeatureExtract.o
surfaceFeatureExtract.C: In function 'Foam::scalarField calcCurvature(const Foam::triSurface&)':
make[2]: Target `/Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/platforms/darwinIntel64Gcc46DPOpt/bin/surfaceFeatureExtract' not remade because of errors.
WM_USE_MACPORTS is set to 1.
PS: In the previus post you would be able to download my log file, if you needed it.
Old   May 22, 2013, 06:34
Assistant Moderator
Bernhard Gschaider
Hm. But the libraries get correctly created. So I wouldn't put too much thought into it
+ echo
+ echo
+ '[' -n 1 ']'
This seems to be a problem with the most recent version 4.2 of CGAL (OpenFOAM uses 4.0). I solved it by downgrading to version 4.1 (MacPort allows you to do that).
Old   May 29, 2013, 07:43
rdbisme's Avatar
Ruben Di Battista
Sorry for my late response but i was busy with an exam
Anyway, i downgraded cgal and used openmpi from system and i have just two errors:
cp -f ../bin/[agm]* /Users/######/OpenFOAM/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46/scotch_6.0.0/bin
cp: ../bin/[agm]*: No such file or directory
make: *** [/Users/######/OpenFOAM/OpenFOAM-2.2.x/platforms/darwinIntel64Gcc46DPOpt/lib/libSloanRenumber.dylib] Error 1
Boost is installed:
The following ports are currently installed:
  boost @1.53.0_1+no_single+no_static+python27 (active)
What could you tell me about especially the last error?
Old   May 29, 2013, 13:40
rdbisme's Avatar
Ruben Di Battista
EDIT (19:32 29/05/13):
I tried to run the motorbike tutorial
./Allrun
Running surfaceFeatureExtract on /Users/rubendibattista/OpenFOAM/rubendibattista-2.2.x/run/motorbike
Running blockMesh on /Users/rubendibattista/OpenFOAM/rubendibattista-2.2.x/run/motorbike
Running decomposePar on /Users/rubendibattista/OpenFOAM/rubendibattista-2.2.x/run/motorbike
Running snappyHexMesh in parallel on /Users/rubendibattista/OpenFOAM/rubendibattista-2.2.x/run/motorbike using 6 processes
Running patchSummary in parallel on /Users/rubendibattista/OpenFOAM/rubendibattista-2.2.x/run/motorbike using 6 processes
Running potentialFoam in parallel on /Users/rubendibattista/OpenFOAM/rubendibattista-2.2.x/run/motorbike using 6 processes
Running simpleFoam in parallel on /Users/rubendibattista/OpenFOAM/rubendibattista-2.2.x/run/motorbike using 6 processes
Running reconstructParMesh on /Users/rubendibattista/OpenFOAM/rubendibattista-2.2.x/run/motorbike
Running reconstructPar on /Users/rubendibattista/OpenFOAM/rubendibattista-2.2.x/run/motorbike
And opening the SnappyHexMesh log
sudo nano log.snappyHexMesh
I get:
Users/rubendibattista/OpenFOAM/OpenFOAM-2.2.x/bin/tools/RunFunctions: line 75: mpirun: command not found
In fact if i do in a terminal:
mpirun -V
it can't find the command.
If I, differently, do:
openmpirun -V
I get:
openmpirun (OpenRTE) 1.7.1
Report bugs to http://www.open-mpi.org/community/help/
so i managed to edit the ~/.alias file including
alias mpirun='openmpirun'
it works in the terminal but Runfunctions still can't get it.
(Same things appear to happen with paraview. I created an alias in ~/.alias file. It works from outside the OpenFoam image but if i do
paraFoam
/Users/#####/OpenFOAM/OpenFOAM-2.2.x/bin/paraFoam: line 267: paraview: command not found
it's like it can't recognize aliases inside OpenFoam directory).
Old   May 29, 2013, 20:14
Assistant Moderator
Bernhard Gschaider
./Allrun
I get:
mpirun -V
openmpirun -V
I get:
paraFoam
Welcome to the wonderful world of shell-initializations.
mpirun vs openmpirun: I wouldn't consider that a bug of the Mac-patch but an inflexibility of the RunFunctions. If you really have to run those scripts create a symbolic link somewhere in the PATH named mpirun pointing to openmpirun
paraFoam: I don't know which paraview you're using. I use the Kitware binaries. If my patches find that at /Applications/paraview.app they modify the path correctly. If not you're on your own.
Also do I not support the paraFoam reader but I use the reader built into paraview. Not because the paraFoam reader is bad but because I don't want to spend my time compiling paraview
Old   May 29, 2013, 20:21
Assistant Moderator
Bernhard Gschaider
Boost is installed:
In OF the library is called boost_thread-mt (no idea why). Check in $FOAM_SRC/renumber/Allwmake if you have something like
if [ -n "$BOOST_ARCH_PATH" ]
then
    if [ -n "$WM_USE_MACPORT" ]
    then
        export BOOST_THREAD_EXTENSION=-mt
    fi
    wmake $makeType SloanRenumber
else
    echo
    echo "Skipping SloanRenumber"
    echo
fi
there. Especially the WM_USE_MACPORT-part. Anyway. I wouldn't spend too much time on this library. It is not something you use every day. Unless you use the renumberMesh-utiltiy on a regular basis
Old   July 4, 2013, 07:44
Smile
  #53
Michael
lithos is on a distinguished road
Dear all,
thanks to Bernhard for the patches for the new recent version. In fact I spent the last half year with OpenFOAM-ext, so I did not need the other branch.
However, today I tried to compile OpenFOAM 2.2.0 source on a MacBook Pro with OS X 10.8.4. I could confirm some traps I ran into as well:
There is some sort of cp in Paraview.app, so I just deleted it, problem solved. If not this will prevent Scotch from compiling. Marked already here:
http://www.cfd-online.com/Forums/ope...tml#post416872
Concerning surfaceFeatureExtract I would be glad if somebody could tell me where to find cgal 4.1. I tried with port to localise it, but it seems that only 4.2 is in the repository. Problem stated here:
http://www.cfd-online.com/Forums/ope...tml#post429164
Then I also had to use an alias for mpirun as stated here: http://www.cfd-online.com/Forums/ope...tml#post430798
Last but not least I followed http://www.cfd-online.com/Forums/ope...tml#post430868 and exchanged line 21 to 28 in $FOAM_SRC/renumber/Allwmake
then
else
    echo
    echo
fi
by
then
    then
    fi
else
    echo
    echo
fi
but I still got
+ export BOOST_THREAD_EXTENSION=-mt
+ BOOST_THREAD_EXTENSION=-mt
+ wmake libso SloanRenumber
make: ***  [/Users/mplagge/OpenFOAM/OpenFOAM-2.2.0/platforms/darwinIntel64Gcc46DPOpt/lib/libSloanRenumber.dylib]  Error 1
So in the end I added manually -mt in $FOAM_SRC/renumber/SloanRenumber/Make/options in line 9
    -L$(BOOST_ARCH_PATH)/lib -lboost_thread-mt \
Then it worked just fine:
wmakeLnInclude: linking include files to ./lnInclude
SOURCE=SloanRenumber.C ; ccache g++-mp-4.6 -m64 -fsignaling-nans   -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra  -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2   -DNoRepository -ftemplate-depth-100 -I/opt/local/include  -I/Users/mplagge/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude  -I/Users/mplagge/OpenFOAM/OpenFOAM-2.2.0/src/parallel/decompose/decompositionMethods/lnInclude   -I/Users/mplagge/OpenFOAM/OpenFOAM-2.2.0/src/renumber/renumberMethods/lnInclude  -IlnInclude -I.  -I/Users/mplagge/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude  -I/Users/mplagge/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude    -fPIC -Ddarwin -c $SOURCE -o  Make/darwinIntel64Gcc46DPOpt/SloanRenumber.o
'/Users/mplagge/OpenFOAM/OpenFOAM-2.2.0/platforms/darwinIntel64Gcc46DPOpt/lib/libSloanRenumber.dylib'  is up to date.
So if anybody of you could let me know about the cgal 4.1 issue I would appreciate it. If I can spare some time I will set up a new manual and maybe we could write some sort of prerequisite check for Mac. Even if it is not that important I would rather have a fully working image. Just in case I ever need it later.
Have a nice day.
Cheers,
Michael
lithos is offline   Reply With Quote
Old   July 8, 2013, 14:55
Assistant Moderator
Bernhard Gschaider
I think I made it compile with 4.2 with the attached patch. Wanted to report it to the upstream but I first wanted to verify whether this is a fix to a MacOnly-problem
Bernhard
SurfaceCGALFix.patch
Old   July 9, 2013, 07:22
Smile
  #55
Michael
Bernhard
Dear Bernhard,
thanks a lot for the patch. It worked perfectly.
Cheers,
Michael
Old   August 9, 2013, 02:24
karlvirgil's Avatar
karlvirgil is on a distinguished road
My OpenFOAM-2.2.x installation goes fine except for one item. The Allwmake script for third party complains about a missing ../../etc/wmakeFiles/scotch/Makefile.inc.i686_mac_darwin.shlib-OpenFOAM
file. This file doesn't exist.
Any thoughts?
karlvirgil is offline   Reply With Quote
Old   August 11, 2013, 18:34
Assistant Moderator
Bernhard Gschaider
Any thoughts?
It seems to be missing in the first version of the ThirdParty-patch I uploaded but is in the second one
Old   August 16, 2013, 08:16
Question Compilation errors
  #58
Davide D.
dav.dap83 is on a distinguished road
I tried to compile the 2.2.1 version. I followed the instructions posted above, but it seems that the compiler does not find the source files:
could not open file <path of every source file>
and then the compilation stops after a while. The files are of course present in the path above.
Any ideas?
Thank you
dav.dap83 is offline   Reply With Quote
Old   August 18, 2013, 19:10
Assistant Moderator
Bernhard Gschaider
Originally Posted by dav.dap83 View Post
Any ideas?
Thank you
No idea. Have you sourced etc/bashrc before the compilation?
Old   August 19, 2013, 06:13
Davide D.
Yes, I have.
Perhaps it may be more helpful to upload the log file.
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 08:51
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker rt08 OpenFOAM Installation 1 February 28, 2016 19:00
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 13:36
