Compile OF2.1 with Intel Icc and Intel MPI
Old   February 7, 2013, 12:56
Default Compile OF2.1 with Intel Icc and Intel MPI
hewei is on a distinguished road
hi everyone,
I am trying to install OF on Linux Mint with Intel Icc and MPI, first I test that intel mpi works
then I set
66 export WM_COMPILER=Icc
85 export WM_MPLIB=INTELMPI
also I add the mpi path in settings.sh
549 INTELMPI)
550 export MPI_ROOT=/opt/intel/impi/4.1.0.024 # mpi installed path
551 lastCharID=$(( ${#MPI_ROOT} - 1 ))
552 if [ "${MPI_ROOT:$lastCharID:1}" == '/' ]
553 then
554 MPI_ROOT=${MPI_ROOT:0:$lastCharID}
555 fi
556
557 export FOAM_MPI=${MPI_ROOT##*/}
558 export MPI_ARCH_PATH=$MPI_ROOT
559
560 if [ ! -d "$MPI_ROOT" -o -z "$MPI_ARCH_PATH" ]
561 then
562 echo "Warning in $WM_PROJECT_DIR/etc/config/settings.sh:" 1>&2
563 echo " MPI_ROOT not a valid mpt installation directory or ending in a '/'." 1>&2
564 echo " Please set MPI_ROOT to the mpt installation directory." 1> &2
565 echo " MPI_ROOT currently set to '$MPI_ROOT'" 1>&2
566 fi
567
568 if [ "$FOAM_VERBOSE" -a "$PS1" ]
569 then
570 echo "Using INTEL MPI:"
571 echo " MPI_ROOT : $MPI_ROOT"
572 echo " FOAM_MPI : $FOAM_MPI"
573 fi
574
575 _foamAddPath $MPI_ARCH_PATH/bin64
576 _foamAddLib $MPI_ARCH_PATH/lib64
577 ;;
578 *)
579 export FOAM_MPI=$FOAM_LIBBIN/impi/4.0.024/bin64
580 #dummy
581 ;;
582 esac
/home/wei/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64IccDPOpt/lib/openmpi-1.5.3/libPstream.so: could not read symbols: Invalid operation
make[3]: *** [/home/wei/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64IccDPOpt/bin/refineHexMesh] Error 1
make[3]: Leaving directory `/home/wei/OpenFOAM/OpenFOAM-2.1.1/applications/utilities/mesh/advanced/refineHexMesh'
make[2]: *** [refineHexMesh] Error 2
make[3]: *** [/home/wei/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64IccDPOpt/bin/selectCells] Error 1
make[3]: Leaving directory `/home/wei/OpenFOAM/OpenFOAM-2.1.1/applications/utilities/mesh/advanced/selectCells'
make[2]: *** [selectCells] Error 2
after I add #undef EIO in the readMechanicalProperties.H it still has erros
so what should I do?
Thanks you all
W.
hewei is offline   Reply With Quote
Old   February 10, 2013, 06:20
Retired Super Moderator
Bruno Santos
Greetings hewei,
I think you forgot to start a new terminal or at least to reset your OpenFOAM shell environment. I say this because it's still using the "openmpi-1.5.3" paths to Pstream!
If you have doubts about the "OpenFOAM shell environment", try this blog post of mine: Advanced tips for working with the OpenFOAM shell environment
Best regards,
Bruno
Old   February 10, 2013, 14:21
Originally Posted by wyldckat View Post
Greetings hewei,
Best regards,
Bruno
thanks Bruno reply me, today I deleted all and re-install OF from the beginning and just change the etc/bashrc file. at beginning it seems running good but later there are many errors coming out. like
ld: note: '_ZN4Foam8UPstream9nRequestsEv' is defined in DSO /home/wei/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64IccDPOpt/lib/4.1.0.024/libPstream.so so try adding it to the linker command line
/home/wei/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64IccDPOpt/lib/4.1.0.024/libPstream.so: could not read symbols: Invalid operation
make[2]: *** [/home/wei/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64IccDPOpt/bin/MRFMultiphaseInterFoam] Error 1
someone in this forums left a word "delate //front in settimes" but without more details. and what files should I add ,modified or delete? I really have no idea now, then what should I do? and how did other solve this problem? thanks for advance
Old   February 12, 2013, 05:31
Bruno Santos
Hi hewei,
This is very strange... which exact version of Linux Mint are you using?
Best regards,
Bruno
Old   February 12, 2013, 07:23
Hi hewei,
Best regards,
Bruno
hi Bruno
I use Linux Mint 13. its low temperature performance appears me the most
the above error doesn't appear yet, i found this
/usr/local/include/mpi.h(2087): catastrophic error: cannot open source file "openmpi/ompi/mpi/cxx/mpicxx.h"
#include "openmpi/ompi/mpi/cxx/mpicxx.h"
It seems my intel mpi setting has problems, why OF link to openmpi?
I test this
$echo $MPI_ROOT $MPI_HOME
/opt/intel/impi/4.1.0.024/intel64 /opt/intel/impi/4.1.0.024/intel64
$mpiicc -v
mpiicc for the Intel(R) MPI Library 4.1 for Linux*
Copyright(C) 2003-2012, Intel Corporation. All rights reserved.
icc version 13.1.0 (gcc version 4.6.0 compatibility)
and in the /home/.profile I also setted
PATH=$PATH:/opt/intel/impi/4.1.0.024/intel64/bin
is it enough?
this time I upload my setting.sh and the make log
thanks
wei
Old   February 12, 2013, 07:30
Bruno Santos
OK, we're getting closer. Check the following:
  1. Run:
    ls -la /opt/intel/impi/4.1.0.024/intel64/include64
    ls -la /opt/intel/impi/4.1.0.024/intel64/include64/mpi.h
    Do these two commands show anything? More specifically the second one.
  2. You should be able to change this path in "wmake/rules/linux64Icc/mplibINTELMPI", as shown here: https://github.com/OpenFOAM/OpenFOAM.../mplibINTELMPI
Old   February 12, 2013, 09:08
  1. Run:
what a good hints and good news! thank you very very much
OF cann't find the mpi location, so I change / wmake / rules / linux64Icc / mplibINTELMPI
PFLAGS = -DMPICH_SKIP_MPICXX
PINC = -I$(MPI_ARCH_PATH)/include64
PLIBS = -L$(MPI_ARCH_PATH)/lib64 -lmpi
into
PLIBS = -L$(MPI_ARCH_PATH)/lib -lmpi
in my case
after that, the relevant errors disappeared and the left errors are about EIO and solidEquilibriumDisplacement
fPIC -c $SOURCE -o Make/linux64IccDPOpt/solidDisplacementFoam.o
readMechanicalProperties.H(78): error: expected an identifier
IOobject EIO
readMechanicalProperties.H(80): error: expected a type specifier
"E",
readMechanicalProperties.H(81): error: variable "runTime" is not a type name
runTime.timeName(0),
readMechanicalProperties.H(81): error: expected a ")"
readMechanicalProperties.H(85): warning #12: parsing restarts here after previous syntax error
readMechanicalProperties.H(94): error: no instance of constructor "Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField [with Type=Foam::scalar={Foam::doubleScalar={double}}, PatchField=Foam::fvPatchField, GeoMesh=Foam::volMesh]" matches the argument list
argument types are: (int, Foam::fvMesh, Foam::dimensionedScalar, const Foam::word)
readMechanicalProperties.H(109): error: expression must have class type
EIO.readOpt() = IOobject::MUST_READ;
readMechanicalProperties.H(114): error: no instance of constructor "Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField [with Type=Foam::scalar={Foam::doubleScalar={double}}, PatchField=Foam::fvPatchField, GeoMesh=Foam::volMesh]" matches the argument list
argument types are: (int, Foam::fvMesh)
compilation aborted for solidDisplacementFoam.C (code 2)
make[2]: *** [Make/linux64IccDPOpt/solidDisplacementFoam.o] Error 2
make[2]: Target `/home/wei/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64IccDPOpt/bin/solidDisplacementFoam' not remade because of errors.
make[2]: Leaving directory `/home/wei/OpenFOAM/OpenFOAM-2.1.1/applications/solvers/stressAnalysis/solidDisplacementFoam'
make[1]: *** [solidDisplacementFoam] Error 2
make[2]: Entering directory `/home/wei/OpenFOAM/OpenFOAM-2.1.1/applications/solvers/stressAnalysis/solidEquilibriumDisplacementFoam'
SOURCE=solidEquilibriumDisplacementFoam.C ; icpc -std=c++0x -Dlinux64 -DWM_DP -wd327,654,819,1125,1476,1505,1572 -xSSE3 -O2 -no-prec-div -DNoRepository -I/home/wei/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -ItractionDisplacementCorrectionStress -I../solidDisplacementFoam -IlnInclude -I. -I/home/wei/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/wei/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/solidEquilibriumDisplacementFoam.o
../solidDisplacementFoam/readMechanicalProperties.H(78): error: expected an identifier
IOobject EIO
../solidDisplacementFoam/readMechanicalProperties.H(80): error: expected a type specifier
"E",
../solidDisplacementFoam/readMechanicalProperties.H(81): error: variable "runTime" is not a type name
../solidDisplacementFoam/readMechanicalProperties.H(81): error: expected a ")"
../solidDisplacementFoam/readMechanicalProperties.H(85): warning #12: parsing restarts here after previous syntax error
../solidDisplacementFoam/readMechanicalProperties.H(94): error: no instance of constructor "Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField [with Type=Foam::scalar={Foam::doubleScalar={double}}, PatchField=Foam::fvPatchField, GeoMesh=Foam::volMesh]" matches the argument list
../solidDisplacementFoam/readMechanicalProperties.H(109): error: expression must have class type
../solidDisplacementFoam/readMechanicalProperties.H(114): error: no instance of constructor "Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField [with Type=Foam::scalar={Foam::doubleScalar={double}}, PatchField=Foam::fvPatchField, GeoMesh=Foam::volMesh]" matches the argument list
compilation aborted for solidEquilibriumDisplacementFoam.C (code 2)
make[2]: *** [Make/linux64IccDPOpt/solidEquilibriumDisplacementFoam.o] Error 2
make[2]: Target `/home/wei/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64IccDPOpt/bin/solidEquilibriumDisplacementFoam' not remade because of errors.
make[2]: Leaving directory `/home/wei/OpenFOAM/OpenFOAM-2.1.1/applications/solvers/stressAnalysis/solidEquilibriumDisplacementFoam'
make[1]: *** [solidEquilibriumDisplacementFoam] Error 2
make[1]: Target `application' not remade because of errors.
make[1]: Leaving directory `/home/wei/OpenFOAM/OpenFOAM-2.1.1/applications/solvers/stressAnalysis'
make: *** [stressAnalysis] Error 2
make: Target `application' not remade because of errors.
anyway this solver I am not using now, the others work very well, Thank you very much!!
wei
Old   February 12, 2013, 16:18
Bruno Santos
Hi Wei,
The last two problems are already fixed in OpenFOAM 2.1.x.
Best regards,
Bruno
intel, of2.1
installation with Intel MPI and Intel compilers achim OpenFOAM Installation 12 November 10, 2011 05:56
Error compiling OpenFoam 1.6.x with intel compiler icc mak_04 OpenFOAM Installation 5 October 28, 2011 07:06
Compiling with Intel icc gellert OpenFOAM Installation 9 November 29, 2006 07:07
