openfoam 1.6.ext installation
Old   February 10, 2013, 18:28
Default openfoam 1.6.ext installation
Arjang Behnoud
AmirBaqa1987 is on a distinguished road
hi everyone
i'm installing openfoam-1.6-ext on ubuntu 12.04 LTS, in the compilation step of installation process
(i mean the command:
cd $WM_PROJECT_DIR
./Allwmake >& log.Allwmake &
tail -f log.Allwmake ) terminal shows:
In file included from yPlusRAS.C:52:0:
/home/amir/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude/wallDist.H:66:27: fatal error: cellDistFuncs.H: No such file or directory
compilation terminated.
make[3]: *** [Make/linux64Gcc46DPOpt/yPlusRAS.o] Error 1
make[3]: Target `/home/amir/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64Gcc46DPOpt/yPlusRAS' not remade because of errors.
make[2]: *** [yPlusRAS] Error 2
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/amir/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels -I/home/amir/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels -I/home/amir/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/incompressible/RAS/RASModel -I/home/amir/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/amir/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/amir/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64Gcc46DPOpt/wallShearStress.o -L/home/amir/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc46DPOpt \
-lincompressibleRASModels -lincompressibleTransportModels -lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/amir/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64Gcc46DPOpt/wallShearStress
/usr/bin/ld: cannot find -lincompressibleRASModels
/usr/bin/ld: cannot find -lincompressibleTransportModels
/usr/bin/ld: cannot find -lfiniteVolume
collect2: ld returned 1 exit status
make[3]: *** [/home/amir/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64Gcc46DPOpt/wallShearStress] Error 1
make[2]: *** [wallShearStress] Error 2
make[2]: Target `application' not remade because of errors.
make[1]: *** [wall] Error 2
make[1]: Target `application' not remade because of errors.
make: *** [postProcessing] Error 2
make: Target `application' not remade because of errors.
what should i do to overcome this problem?
thanks a lot
best wishes
arjang
AmirBaqa1987 is offline   Reply With Quote
Old   February 12, 2013, 03:50
Default istallation openFoam-1.6-ext problem
Arjang Behnoud
hi Dear friends
when i enter command:
./Allwmake >& log.Allwmake & tail -f log.Allwmake (compile openfoam-1.6-ext)
compilation process getting start and after some minutes stop and show some fatal errors like:
renumberMesh.C:42:21: fatal error: faceSet.H: No such file or directory
faceSet.C:33:27: fatal error: topoSetSource.H: No such file or directory
refineWallLayer.C:39:21: fatal error: cellSet.H: No such file or directory
what should i do?
please help me
thanks a lbest regards
arjang
Old   February 12, 2013, 04:54
Retired Super Moderator
Bruno Santos
Hi Arjang,
Please do the following steps:
  1. Compress the log file "log.Allwmake" by running:
    tar -cf  log.Allwmake.tar.gz  log.Allwmake
  2. Attach the file "log.Allwmake.tar.gz" to your next post. You'll need to use the advanced post edit mode in order to be able to attach the file.
I ask this because the first error is usually the one that tells the whole story.
Best regards,
Bruno
Old   February 12, 2013, 08:14
Default openfoam-1.6.ext installation problem
Arjang Behnoud
Hi Dear Bruno
here is the file which you want me to attach:
log.Allwmake.tar.gz
thanks a lot
arjang
Old   February 12, 2013, 16:41
Bruno Santos
Hi Arjang,
This is a very strange error... I suggest the following commands:
wcleanAll
The first command makes it clean up the files that were built so far. I'm suggesting this step because something very strange seems to have affected the build, and probably only a good clean up will make sure things build as intended.
The second command is the one you've already executed before.
By the way, how much RAM and how many cores does your machine have?
Best regards,
Bruno
Old   February 13, 2013, 05:06
Arjang Behnoud
Hi Dear Bruno
(my machine has quad core(corei7)& 8 gig ram)
i did those two commands which you've suggested me.
after compiling process there is no error and the end of log.Allwmake is like below:
/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64Gcc46DPOpt/yPlusRAS.o -L/home/amir/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc46DPOpt \
-lincompressibleTransportModels -lincompressibleRASModels -lbasicThermophysicalModels -lspecie -lcompressibleRASModels -lfiniteVolume -lmeshTools -lsampling -lOpenFOAM -liberty -ldl -lm -o /home/amir/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64Gcc46DPOpt/yPlusRAS
is everything ok?
and also i installed paraview by command :sudo apt-get install paraview
but when i type paraFoam terminal display:
amir@amir-VPCF22CFX:~/OpenFOAM/OpenFOAM-1.6-ext/tutorials/incompressible/simpleFoam/pitzDaily$ paraFoam
created temporary 'pitzDaily.OpenFOAM'
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Calculator" under id 119
"Histogram" under id 134
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Integrate Variables" under id 135
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Intersect Fragments" under id 145
vGlobal Variables Over Time" under id 137
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Plot On Sorted Lines" under id 139
"Threshold" under id 123
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Warp By Vector" under id 127
bytesRead < bytesLeft
bytesRead 0 bytesLeft512
Read float past end of buffer
is there any problem?
thanks a lot for your attention
sincerely yours
arjang
Old   February 13, 2013, 05:19
Bruno Santos
Hi Arjang,
you didn't need to do:
because 1.6-ext builds its own ParaView version...
But anyway, try the following steps:
foam
sed -i -e 's=\.OpenFOAM=\.foam=' bin/paraFoam
Then go back to the case you were testing and run:
paraFoam
Best regards,
Bruno
Old   February 13, 2013, 16:05
Arjang Behnoud
hi Bruno
I did those two commands and now paraFoam command works.
but there is some red text at terminal after performing paraFoam command:
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Calculator" under id 121
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Annotate Time Filter" under id 156
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Clip" under id 123
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Contingency Statistics" under id 150
void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Contour" under id 122
what are these red text?
i asked this question because these red text does not appear when i use openFoam 2.1.1
thanks a lot
sincerely yours
arjang
Old   February 13, 2013, 16:24
Bruno Santos
Hi Arjang,
I think you can safely ignore those messages.
The only reason I can deduce for the differences between OpenFOAM 2.1.1 and 1.6-ext, is because 2.1.1 uses ParaView 3.12.0 and Ubuntu's version is ParaView 3.14.1.
Best regards,
Bruno
Old   February 14, 2013, 04:38
Default appreciation
Arjang Behnoud
hi Dear Bruno
thanks a lot for your tips.
best regards
arjang
[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 electrosin OpenFOAM Installation 40 May 31, 2016 05:11
[Discussion] Restructuring the Installation page at openfoamwiki.net wyldckat OpenFOAM Installation 16 November 2, 2013 11:43
Openfoam 2.1 installation in ubuntu 12.04 jsm OpenFOAM Installation 11 May 7, 2012 04:56
Installation of OpenFOAM 1.7.1 to OprnSUSE 11.2 superfxfund OpenFOAM Installation 3 November 11, 2010 02:15
Some Query on Installation of OpenFoam lzgwhy OpenFOAM Installation 1 July 15, 2009 03:20
