wmake error
Old   March 27, 2013, 09:01
Default wmake error
Raymond.Leoi is on a distinguished road
Just installed OF 2.2.0 to my cluster. When I test to compile icoFOAM, errors occurred as the following. How to fix it?
/opt/openfoam220/wmake/wmake: 222: /opt/openfoam220/wmake/wmake: make: not found
/opt/openfoam220/wmake/wmake: 223: /opt/openfoam220/wmake/wmake: make: not found
wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /opt/openfoam220/applications/solvers/incompressible/icoFoam
Raymond.Leoi is offline   Reply With Quote
Old   March 27, 2013, 17:04
Retired Super Moderator
Bruno Santos
Greetings Raymond.Leoi,
I can only guess that you installed OpenFOAM 2.2.0 by following these instructions: http://www.openfoam.org/download/ubuntu.php
Those only provide information on how to install OpenFOAM, in order to use the existing binaries.
For building OpenFOAM source code, you'll need to also install the packages for compiling and building, such as make and gcc. For those, you can follow the specific section "System Requirements" from this page: http://www.openfoam.org/download/source.php - more specifically the instructions for installing the necessary required packages for Ubuntu.
Best regards,
Bruno
Pressure outlet boundary condition rolando OpenFOAM Running, Solving & CFD 62 September 18, 2017 06:45
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
